Question about Moen & One Handle Tub & Shower Faucet
The water comes out very slowly. No pressure.
    Problem Solver:
  • 8 Answers
Check for debris in shower head. Could be calcium or other mineral buildup. Has the water dept. done any recent repairs/upgrades to water meter or mains? Sometimes this can loosen buildup in pipes & send it through the valve itself thus lowering pressure or stopping completely.
Posted on Jul 29, 2010
Testimonial: "The debris in the shower head was correct, thanks."
I have a toshiba washing machine model :aw-sd130sb: error code ec5. But this time solve the problem?
Ec5: Overloaded or insufficient water.
1. Your load of clothes is too large. Wash smaller loads.
2. If the water inlet valve is defective, the wash may fill slowly or not fill at all. The water inlet valve requires sufficient water pressure to function properly. First, check the water pressure to determine that it is adequate. If the water pressure is adequate, see #1. try cleaning the screens inside the water inlet valve hose connection ports. If the washer still fills slowly, replace the water inlet valve.
hope this helps
Jan 09, 2018 | Washing Machines
Mr freeze ice maker only making partial cubes
Oy, ice makers! This can happen if there is low water pressure, and that can happen if the water filter needs replacement. Another explanation is evaporation which can happen after even a few days. But if they come out of the ice maker small, it's probably the filter -- if it also has a water dispenser, you might notice that water comes out slowly. If the filter doesn't fix it, the actual water feed may not be providing enough water pressure for some reason ... maybe as simple as loosening the valve on the back ... but probably not likely.
Aug 03, 2016 | Refrigerators
My hand water pump in a Jayco dove when hooked to mains pressure the handle will slowly rise and will run constantly.
Chance s . Are to much water pressure . Install a pressure gauge at your inlet .
One other this you might do # 1. Tun off water go to your hand pump and unscrew your faucet that looks like a jay or hook . This is where your water comes out . Once removed the tab you push will also come loose with a little jiggling . Their is a all thread with a adjusting nut . Just turn it onev time . Put it back together and test .
Mar 02, 2015 | Jayco 2009 Eagle 313 RKS
Water pressure from water dispenser come out slowly
Lack of water pressure could be as a result of a new filter that has not been purged of the air by pressing the dispense cradle down for up to three minutes. If the refrigerator is new and
ice cube size has not been affected by giving hollow cubes it could be that there is a defective new dual water control valve that is not opening all the way, crimped water line blocked water line with debris. Try turnoff off the water supply and check both the waterline coming into the water control valve and the water exiting water valve. Place the water line into a bucket and watch
the flow. What is the model number? Sea Breeze
Jun 02, 2013 | Refrigerators
Hot water is very slow coming out spout. Cold water comes out fine with good pressure..
the anti scald is adjusted too low. its located under/behind the handle. it usually has am allen wrench head. remove the handle and adjust it all the all the way to hot that should fix it. on some models you can remove the entire thing,but on some that will cause the handle turn 360deg because in some models its also the stopping point of the handle. hope this helps
Dec 11, 2012 | Jacuzzi Home
Hot water slows to a trickle when lever turned to hot. Cold water has pressure. All other faucets in house have pressure
sounds like you have trash in hot side of value or cartridge...shut off water remove cartridge....check for trash....turn on water slowly to clear lines...may take 2 people to do this 1 to turn water on while other sees if water comes out both ports in value....look in cartridge to see if any clog....if you can get a bucket of soapy water before hand and wash cartridge under soapy water...reinstall and check....if water comes out off both ports without cartridge in...when you reinstall after cleaning it still no flow...you may need new cartridge,,,good luck
Jan 24, 2011 | Dmm Symmons Temptrol II pressure balancing...
Dial not working correctly, set on low numbers water comes out at high pressure, set it on high numbers and the water pressure comes out on low pressure ???? why.... the item in question is a Triton Madrid...
It sounds like the numbers are for the temperature indication and the higher the temperature the more slowly the water runs because it takes longer to heat it.
Apr 16, 2010 | Home
LG wm1832cw filling slowly
The water valves might be going bad, or there is a clog in the hoses. Also check the water pressure going into the washer.
Dec 03, 2009 | LG Washing Machines
Moen & One Handle Tub & Shower Faucet  Logo
223 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
