Question about Sony Bravia DAV-HDX265 Theater System
Hi - I have a Bravia DAV HDX265 and cannot get the sound from the TV/cable to come out through the speakers. I am using HDMI cables. One from TV to cable box Two from the TV to the Bravia DAV HDX265 unit. It used to work fine set up like this until I disconnected everything when I moved. I have gone through the set up menus and done all that. Sound works fine for all other functions out of all speakers (5.1) on the Bravia, just cannot get it for TV/Video. Any help is appreciated...thanks.
  • EDBgarden7 Jul 30, 2010
    Hooked up the RCA cables from DAV HDX265 into cable box and got sound in surround! Thanks
  • 10,594 Answers
Plug audio RCA cable in Audio Input of DAV-HDX265 and cable box Audio Output. Set DAV-HDX265 to TV/Video Input to get cable sound in speakers.
Let me know if you have additional question.
Thanks.
Posted on Jul 29, 2010
  • 1 more comment
  • EDBgarden7 Jul 29, 2010
    Could I also use a Coaxial Digital Cable to accomplish this? Is one option better than the other?
    Obviously I want the best audio sound quality I can get, will be watching HD movies from HBO (via cable) and such on it...
    Thanks
  • Shahid Electronics
    Shahid Electronics Jul 29, 2010
    Does cable box has coax digital output?
    Yes, coax digital is better than usual RCA audio cable.
    I just checked DAV-HDX265 connections details, it does not have any coax digital audio input at rear so usual RCA Audio cable (red-white) is only option to hook it with cable box audio output.
    Thanks.
Sony bravia 285 and xbox surround sound.
a HDMI lead has sound and video cables
Jan 11, 2010 | Sony Electronics - Others
DAV-DZ260 + KDL-32V4000 - no audio from TV to DAV via HDMI
Check DAV amp menu and select DTS surround or any other digital sound option.
Jun 15, 2009 | Sony Audio Players & Recorders
Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Dec 23, 2008 | Sony BRAVIA® DAV-HDX576WF Theater System...
Hello, I need replacement speaker terminals
Please let me know connectors color at back of unit to provide you info for speaker cables.
Nov 29, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Sony Bravia Dav-HDX279W and comcast HDTV Cable box connection.
Like above, use an optical connection (need fiber optic cable) or a coaxial connection (single RCA cable). HDMI might also work, but I personally haven't checked. Connect the audio outs from the cable box to the audio ins on the home theater. The TV will only need a video connection from the cable box, as well as one from the home theater (for DVDs, onscreen menus).
This discussion can help you set up the universal remote.
Nov 18, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Problems with hearing sound from bravia LCD tv through bravia DAV-HDX275 theatre system
The fiber optic port on back on your bravia tv is only for when your using a over the air antenna and watching local atsc channels in your local market. You need to run the fiber optic from your hd cablebox if it has one or your hd sat box if it has one. If you don't have a set top box with the fiberoptic port on it you can use a digital coax cable from the cable or sat box to sound system. The only other way to get sound if you don't have a cable or sat box is to run the red and white rca audio cable from the tv to the sound system and got to the audio setup on tv and turn the tv speakers off and you might have to adjust the audio to fixed instead of variable.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 05, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
I cant hook my PS3 to the surround system for Sony DAV-HDX275W
what exactly is the problem? no connections? or connected and cannot get it to work?
Aug 31, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Audi but no picture when cable box conected through DAV-X1
It won't work as the DAv can only output to HDMI by bringing singal into the HDMI input.
why wouldn't you send it directly to the TV and Audio to the DAV? I sounds like you don't have an HD box anyway (otherwise why would you use an analogue S-video cable vs component or HDMI). Unless there is a distance issue then go to the TV.
Dec 25, 2007 | Sony DAV-X1 System
Kdl-40s3000 hdmi settings
JUNH-THE HDMI CONNECTIONS ARE VERY FRAGILE I'D RECOMMEND SUPPORTING THEM ANY WAY YOU CAN.THE HDMI INPUT ON TV IS POSSIBLY DAMAGED BY NOW AND MAY NEED REPLACING.JOE TV
Nov 27, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Please help with getting 5.1 sound from my TV!
You must run a Digital Optical cable from your PS3 to your reciever. Then press your function button on your recievers remote until you see SAT/CABLE on your recievers display. Next go to your PS3 settings and go to Sound settings, then Audio Output settings, and select Digital out (OPTICAL) then your done. This is the only way to get true digital sound from your PS3 to your reciever.
Oct 01, 2007 | Sony DAV-HDX500 System
Sony Bravia DAV-HDX265 Theater System Logo
113 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
