Question about A-Top XBlade Mid-Tower Case
To fix front usb and audio to the mother board
The pins on the mother board have nothing writen on them how am i spose to work out wich 1 goes where
    Novelist:
    Scholar:
  • 194 Answers
Consult the user manual for the motherboard. It should have a layout diagram showing all connections. Or go online to manufacturer's website and download the user manual there. Also, using a bright light and magnifier you may be able to read the small print on the motherboard by the connectors.
Posted on Apr 30, 2008
  • 51 Answers
You can download the manual from the manufactures web site. The pin lay out will be in there. Most motherboards support the 10-1 AC97 but some have support digital output so make sure to follow your manufactures diagram.
Posted on Jul 09, 2009
Can you please help me to connect the front pannel USB to my pentium4 mother board?
There will be pins on motherebord like :::::: and with these pin front usb writen. Now you have for clips one is one will gre
now connet (1) with one pins in a line and (2) pins with 2nd line.
Jul 12, 2011 | Intel Motherboard
How to fix the usb pins into motherboard. how to
Here is the link to Official Intel Product Guide with all the information about Intel D102GGC2 Motherboard and its front panel connections etc. Refer to Page -39
Let me know if any further clarification is required
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 07, 2010 | Intel D102GGC2 Motherboard
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
Need help, put in new mother board and need help putting in usb connection to front of computer have mach speed motherboard, does anyone have a map for this?
There are probably cables coming from the front of the computer. On the motherboard, you will see 2 or more groups of pins where these cables go. Unfortunately, sometimes the cables don't have a single plug, but have one plug that has 3 holes and then 1 that has one. Many times, too, there are 2 sets. So--let's see if this helps:
The pins will be labled something like USB and then several numbers.
The pins look like this ::::. (hope that shows up OK)
If your usb cable end has one large (3-hole) plug and one small, the large one goes over the first 3 pins from left to right. The one on the left is labeled VCC. The separate plug goes on the 4th pin.
You can use the top row of pins or the bottom. Nothing goes on pin #5 on the bottom.
Does this help? If so, rate it accordingly, please.
Apr 19, 2009 | Mach Speed MS945G-GLV Motherboard
MY COMPUTER WONT TURN ON !!!
for connecting these sw
just see on mother board there you see nearabout 16 pins on right hand bottem of mother board
there you have an integation of connectorfrom right hand corner i.e 1-3 for reset sw, 2-4 for power sw and last switches for front usb and audio
if you have p-3 then you dont attech audio and usb cables on *********** board
Apr 07, 2009 | Computers & Internet
Dell optiplex gx260 mother board
It would be easier to order the cable and front panel board assy as one. easy on ebay.
I have worked on them for years and never bothered to trace them out. and dell doesn't post the pinout anywhere.
If you can't find one I can get it for you cheap.
Mar 02, 2008 | Intel Motherboard
Connecting Speaker
Dear Big Timmo,
To connect the Speaker Pins u have to check left or right side of u r mother board where u r power wire, reset wire and Hard disk led wire connected to the mother board. it has 12 or 13 male pins. There u will find in writen speaker in the motherboard. I hope now u can connect u r speaker pins..
Regards,
Bittu_8
Feb 15, 2008 | Intel Desktop Board D845GERG2 Motherboard
Where is the audio output to front napel?
The ECS page is here;
http://www.ecs.com.tw/
Enter your model number in the search box and you'll be able to download the manual, which has the info you want.
Oct 15, 2007 | EliteGroup PT800CE-A Motherboard
A-Top XBlade Mid-Tower Case Logo
720 people viewed this question
Top A-Top Computers & Internet Experts
David Payne
David Payne
Are you an A-Top Computer and Internet Expert? Answer questions, earn points and help others
