Question about Total Gym 1100 Home Gym
We stored away folded for approx 1 year. Can't remember how to release the height adjustment to set up for use.
  • 38 Answers
Call the service that provided the home gym. ask them.
Posted on Jul 29, 2010
I have a John Deere LX178 lawn tractor and the mower deck will not raise/lower. It is all the way down and pushing in the button is how i've ALWAYS adjusted the height. It will not budge
1) NEVER adjust to where the deck wheels touch the ground. The wheels are to ride 1/4" off the ground. 2) The long lever to your left which raises & lowers the deck has 3 settings. 1- Fully back toward you which has the deck raised (called transport mode). 2- Halfway down which is the normal mowing mode (called float mode) 3- Fully away from you which sets the deck fully on the ground. This mode is ONLY used for VERY rough terrain where the deck risks getting pushed into "transport" or "full up" mode & getting stuck there. 3) On front-to-back tilt, the front should be 1/2inch lower than the back for least damage to the grass. Ok-now to adjust "cutting" height. 1) Park on a level, flat surface. 2) Pull the deck lever fully back toward you to put the deck into "transport" mode. 3) twist the "cutting" height knob (just below your seat) to the height you want the grass cut. Has choices by 1/2" increments from 1" to 3.5". The deck in "transport" mode is 4". 4) Lower the deck lever to the midway/"floating" mode point. 5) Adjust each deck wheel with its own peg & pin to have at least 1/4" clearance from ground. Thats it for "cutting height" adjustments
call your deere dealer,
Troubleshooting
Service Mower
cant find info for you,call dealer
Jun 03, 2015 | Garden
I need to adjust my scag mower deck
The mower deck can be adjusted from a height of 1.0 inch to 6.0 inches at 1/4-inch intervals. To adjust the cutting height:
1. Disengage the power to the cutter blades.
2. Push the cutting height adjustment foot pedal all the way forward using your right foot until it locks in place
3. Insert the lanyard pin into the cutting height index at the desired cutting height. Push forward on the deck lift foot lever, hold in place and pull back on the deck release lever. Slowly release the foot pedal. A deck height decal is located on the cutting height index as an aid in adjusting the deck to the desired height.
Aug 18, 2013 | Scag STT61V-27CH Hydrostatic, Gas Turf...
Front wheels on manual mower lock when pushing for awhile.
1 Locate the height adjustment lever on the inside of the left rear wheel.
2 Kneel next to the mower and push the left height adjustment lever toward the center of the mower. This will unlock the lever from the locking pin on which the height is currently set.
Read more: How do I Adjust the Height on a Great States Reel Mower? ' eHow.com http://www.ehow.com/how_6834215_do-great-states-reel-mower_.html#ixzz21NOr1e8d
3Rotate the lever toward the front of the mower to lower the height of cut, or toward the rear of the mower to raise the height of cut.
4 Release the lever over the locking pin closest to the desired height of cut.
5 Repeat these steps with the adjustment lever on the right-side rear wheel. Be sure to set the right wheel lever to the same position as the left-side wheel's lever for an even cut.
Jul 22, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What is a folding table?
A folding table is a two or four legged table that can be flattened via hinges on each of the legs. Folding tables are very convenience because they tend to be very light weight and can save space.
May 29, 2012 | Furniture
Hi have a bebecar travel city but dont know how to fold it down.help
To fold down a Tracker City, firstly make sure that the front wheels are locked into fixed, non-steering mode, and that the adjustable-height handle is in one of the middle positions.
Look at the twist-grip in the middle of the handle. Press the button and simultaneously twist the collar in the direction of the arrow. The chair should begin to close at this point.
Next, find the secondary lock device, which is operated by means of a lever/tab on one side of the handle. Pull this upwards, tilt the chair forwards and continue the closing action until it is fully closed.
Align the front wheel using your foot, if necessary, to prevent the rear wheel from hitting it. To store the chair, fold down the height-adjustable handle.
Don't forget to keep the pushchair well lubricated, preferably using a silicone spray.
Why not ask service@bebecar.co.uk for a user-guide for the Tracker City?
Nov 06, 2010 | Bebecar Tracker City U319 Stroller
2010 Craftsman Lt 2000 deck height adjustment?
just bought a new craftsman riding mower. model lt1500. 17.5 hp with 42 inch deck. first time using I had the deck hight handle set on 6 the highest setting and still cuts grass to short, matter of fact it scalped the grass. anyway to set the deck higher. Its only 3 days old and still under warranty but the sears store is 20 miles away and I rented a trailer to go pick it up and hate to go rent another trailer to bring it back if its just a simple adjustment.
Jul 31, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
I can't fold it
If the dreami carrycot or the maxi cosi car seat are attached, these will have to be removed first. Apply parking brake Release the handle bars by unclasping the silver clips on the frame. Push down handlebar to lowest height as you press in the silver button under the quinny logo on the very top of the handlebar( in the middle of the foam padding) with a downward thrusting motion. The chassis should then collapse for storing. To unfold then release the transport clip on the left hand side with the red sticker on it and unfold upwards adjust handlebar to required height and lock by closing the silver clasps either side of the frame. HTH
Jun 30, 2010 | Quinny Freestyle 3 XL Stroller
Folding Quinny speedi Sx Stroller
In the middle of the underneath of the pushing handle, below where the hand brake lever is there should be a button. If there is, this is what you do.
1) put the foot brake on so the rear wheels wont turn.
2) unclip the clips on the frame that allow you to adjust the height of the pushing handle, they open up, and leave them open, like this the handle you push the buggy with should slide up and down.
3) pull this handle out to its tallest position
4) Hold the handle and press the button mentioned at the start in and hold it in
5) Then quite quickly push the handle down as though you were either pushing it to lower its pushing height, or shoving it away in a temper. It needs to be a firm and quick movement.
Ta da!! After a couple of tries it should click and fold up.
I hope this helps.
Apr 09, 2009 | Quinny Buzz Jogger
Diamond TV
The vertical height driver that controls the height of your picture has weakened and needs to be adjusted. If you are somewhat handy you can do this yourself. It requires that you gain access to back of the set & remove the cover. Once removed, locate the vertical height & centering adjustments. Sometimes they are located on the main board & other times are located on the color gun driver circuit board that is plugged into the end of the picture tube.
Respond to this post if you need additional assistance. Good luck!
Mar 14, 2008 | Televison & Video
Belts keep burning up
It sounds like you have a roller problem. This machine has a carbon fibre roller suspended on plastic end caps. When dirt and hair etc. gets in and damage the bearings, the belt will be the first thing to go. If the roller is noisy, that indicates that it is off centre and is rotating unevenly. You will probably have to replace the roller.
Take the belt off and rotate the roller slowly and observe the ends. If it is off balance, it will not rotate evenly. The plastic caps unscrew to reveal the brngs and usually you will find hair and other junk gumming up the works. If the roller is damaged, you will be able to see melted plastic and chards of carbon fibre there.
Feb 15, 2008 | Hoover U5172900 Fold Away Widepath Bagless...
Total Gym 1100 Home Gym Logo
272 people viewed this question
Top Total Gym Exercise & Fitness Experts
Marvin
Marvin
Tom Chichester
Jason Steuber
Jason Steuber
Level 1 Expert
Are you a Total Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
