Question about HP Officejet Pro L7680 All-In-One Printer
I have a HP Officejet Pro L7680. When I feed docuent from the top feeder the copies have a black line down the right side about two inches from the edge of the paper. If I lay the document down on the glass and make a copy the line is not there. What could be the problem?
  • 23 Answers
Please follow the below web link steps to reslove the issue, if the issue persists, I request you to visit the nearest service center.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01895544&cc=us&lc=en&dlc=en&product=2512009
Posted on Aug 11, 2010
    Problem Solver:
  • 10 Answers
Is this event consistent? It seems that your document top feeder has a problem and that its feeding the paper improperly or there is in between your paper and the scanner thats why a black line is present, Please try to check and clean the feeder roller for possible obstruction. Worst is your roller is already worn out and needs replacement.
Posted on Jul 29, 2010
Vertical black line on scans or copies;
Hello James,
Please click Vertical Bands Lines or Streaks in Copies Faxes or Scans to access the troubleshooting steps that should resolve the issue.
Mar 03, 2014 | HP Officejet Pro L7680 All-In-One Printer
The copier feature of my new HP all-in-one Officejet Pro 8500A Premium is printing with vertical black line just right of center, whether black or color copy is selected. I have dusted, air compressed and...
lift up the feeder on top of machine where your big piece of glass is. to the side of that big glass is a small glass about an inch wide. most likely there is something on it. clean and you should be good to go.
razors
Jun 01, 2011 | HP Office Equipment & Supplies
Hp Officejet pro L7680, document feeder not working, need help.
I cleaned the feed rollers on my document feeder with alcohol and cotton swabs and its been working great ever since, Try that first if you can get to the rollers. I would not try it with the power on though unless tou are very careful
Feb 25, 2011 | HP Officejet Pro L7680 All-In-One Printer
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
Vertical line from document feeder
there is probably a dirt spot on the scanner glass where the document feeds in. try cleaning the thin glass under the document feed cover.
Apr 24, 2009 | HP Officejet J5780 All-In-One Printer
HP office jet feeder won't work when trying to fax
the little pieces of plastic are the sensor flags which is why it will not feed, those are required to let the machine know that the paper is present in the feeder. No flag no feed. Look at the plastic thing try to figure out where it goes in the feeder if you look close, you will see a spot where they go.
Apr 08, 2009 | HP Officejet Pro L7680 All-In-One Printer
L7680 all in one W/big & wide dark vertical line
Open the document feeder and clean the scanner glass.
Feb 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Lines appear when making a copy using document feeder tray
If the lines are vertical (in the direction the ADF feeds, 11in long for 8 1/2 by 11) You can try cleaning the glass the scanner uses when it's using the document feeder. Pull up the top left part of the printer where the documents feed, there's a little rib in the middle of the side to help you do this, then simply pull up the assembly underneath with all the rollers in it, you should see about an inch of glass underneath and a centimeter long strip of white plastic on the assembly (this serves as the white background when feeding slimmer papers) Clean them both. I'd recomend any glass cleaner, just don't spray it in there, spray it onto a cloth.
Jan 16, 2009 | HP Officejet 6310 All-In-One InkJet...
HP Officejst Pro L7680 All in one
Printer gives repeated "clear paper jam" messages and even though there is no paper anywhere in the paper path it will not clear.
Oct 10, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One Printer Logo
488 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
