Question about GE GSS23QSWSS Stainless Steel
GE GSS23QSWSS Stainless Steel Where is defrost timer location?
mikedurland
  • 481 Answers
SOURCE: I have a GE Profile
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Posted on Jul 01, 2008
Maanita
  • 1142 Answers
SOURCE: Trying to locate Defrost Timer GE PSS27NHN
the defrost timer looks like
Posted on Aug 07, 2008
  • 111 Answers
SOURCE: Defrost timer sticking
Your model doesn't have a defrost timer. Everything is controlled by the main motherboard in the back. The ONLY way to get an acurate diagnosis is to call GE FActory Service at 1-800-432-2737. There is proprietary software and the tech will be able to plug in a laptop to your refer to find out what is going on. No other companies have this or have access to this software. By the way that deforst thermostat you think you found isn't what you think it is. It looks like one but it only a saftey device. Trust me...!
Posted on Dec 16, 2008
  • 531 Answers
SOURCE: Location of Defrost Timer
you unit do not carry it carry a board it at the back off the unit
Posted on Apr 01, 2009
SOURCE: Where is the defrost timer located on GE
This model does not have a defrost timer. It has a motherboard. You must jump out the plug to the main board to test the defrost circuit. In order to do this take the cover off of the main board, find the three wire connector on the base of the main board, connecter is normally blue in color. On the board itself it will identify termials as line, defrost, and compressor. To test you must create a jumper wire.Install the jumper in the plug terminals identified as line and defrost.This will turn the defrost heater on. If the heater does not come on, look for a defective heater or a defrost thermostat(mounted on the top of the evaporator). If the heater does come on replace the thermister(located on top of evap, white in color and has two white wires part#WR55x10025)
Posted on Jun 05, 2009
Need to find defrost timers location model # gss20iepa-wh
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Jul 27, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Hi there, need help replacing defrost timer in my ge gsh25jstss refridgerator
What is the age of the refrigerator? GE usually mounts the timers behind the kickplate in front.
Feb 03, 2011 | GE GSH25JSTSS Stainless Steel Side by Side...
Defroster not working
First, locate the defrost timer which may hidden behindcorners of the fridge at the back bottom, in some models located in the ceilingof the fresh food section or behind the cold control cover. Once you locate thedefrost timer, slowly turn the screw in the middle of the defrost timer withstraight screwdriver until the fridge shuts off. Now it's in defrost. If thedefrost heater(s) starts, replace the defrost timer and defrost thermostat. Ifthe heater(s) does not start, unplug wire cord to check ohm test for continuityof heater. If continuity is there, plug cord wire which gives power 120volts(check specification) to heater. If heater no starts, bypass defrost thermostatby join the 2 wires in the defrost thermostat. If the heater now comes on,replace the defrost timer and defrost thermostat. If the heater itself is bad,replace it. Thanks and hope helpful.
Jan 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Why does freezer automatically defrost and then stay in defrost no matter what we do?
The defrost timer/control board whichever you have is sticking in the defrost mode....replace it...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 02, 2010 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator not cold
Your problem could be a defrost component issue (e.g.: defrost thermostat, defrost heater(s) or defrost timer). Contact an appliance service company.
Apr 13, 2010 | GE Profile PSW26P Stainless Steel Side by...
Refriger not cold but freezer is cold
Your defrost timer is inside the fresh food compartment and behind and inside the control panel. Part number WR09X0489. I will show you a photo location. Be right back, Sea Breeze
Apr 08, 2010 | GE GSH25JSTSS Stainless Steel Side by Side...
Freezer auto defrost doesn't work
Turn timer to defrost position and wait for 25 min.,If refrigerator starts auto. and compressor works. Replace Defrost thermostat.
Nov 17, 2009 | GE Profile PSW26P Stainless Steel Side by...
The refrigerator won't keep cold and the fan is not working and there is ice in the unit.
the defrost timer or heater needs replaced you can turn the timmer manually and see if it defrosts it is a round white knob sticking out of the timer box
Oct 19, 2009 | GE Profile PSW26P Stainless Steel Side by...
Temperature control lights are out, don't work. If you press the control buttons a few times "0" shows for a few seconds then goes out, but I can't adjust the control. The compressor and fans seem to work....
Sounds like the main control board is bad . First , check the door to cabinet connection receptical to make sure it is securly connected . If so , then board control is the problem .
Jul 14, 2009 | GE GSS23QSWSS Stainless Steel
Defrost timer
Can you check to see which of the following Model Numbers you have?,(All but the last one have the defrost built into the control board) PSW26PSRKS PSW26PSRS PSW26PSTS PSW26PSWASS
Feb 03, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE GSS23QSWSS Stainless Steel Logo
27 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
