I need the user guide for my indoor air condionar:Renus DF-188C Air cooler
5 Suggested Answers
burzerko
  • 254 Answers
SOURCE: Everything happens in proper sequence,
This appears that you probably have a serious leak in the system. You will need to find this leak repair it. Then recharge the system.
Hope this helps You
please rate me
Posted on Jul 24, 2008
fireman23
  • 6 Answers
SOURCE: Hot Air from the cooler
check the a/c unit. make sure you dont have any leaks around your system. sometimes when you have a small leak it will take time to lose out of system. but you may need to charge your unit up again. Also your compressor may be out of service. check and make sure compressor is running
Posted on Apr 01, 2009
  • 674 Answers
SOURCE: indoor air flow slow comiing...
Have you checked your air filter(s)? Is the fan running? A weak capacitor will make a fan run slower sometimes. Also try turning the fan by hand while its off and make sure it spins freely. If its hard to turn you probably need a new fan motor.
Posted on May 22, 2010
  • 1044 Answers
SOURCE: jdp_1940@hotmail.comi need a user guide
Try first from the retailer where you bought the machine. If it does not work out go to the following links and download the manual.
http://www.panasonic.com.au/Support/Customer+support/Downloads+and+documentation
http://homeappliance.manualsonline.com/manuals/mfg/panasonic/panasonic_air_conditioner_product_list.html
http://www.retrevo.com/samples/Panasonic-Air-Conditioner-manuals.html
Posted on Jul 26, 2011
What do i need to do to gt the inside unit to blow cooler air
Ensure the AIR FILTER is clean; and ensure that the INDOOR AIR HANDLING COILS are CLEAN. Also, ensure all of your AIR DUCTS are tightly secured with sheet metal screws and good aluminum duct tape.
Aug 26, 2014 | Heating & Cooling
Keep getting code e1
According to page 24 of your owner's manual, the E1 error is indicative of a short circuit in the Indoor Air Thermistor. The unit will likely require service.
Good luck,
Marty
Jun 21, 2014 | LG Electronics LP0910WNR Portable Air...
Unistar DF - 268A air cooler/humidifier/ionizer
I would like to help you but you need to post exactly what the problem is. There is no information about what the problem is.
Jun 20, 2014 | Heating & Cooling
To clean the filters
Instructions on how to clean the filters are in any air conditioners user guide, a scheduled maintenance section. Just choose the necessary one according to your air conditioner make and model, download it and find the needed information Air conditioner hvac user manuals
Mar 21, 2014 | Heating & Cooling
Need User's Manual
Fedders made exact same unit for Maytag. Juts a different model number. The link below is for the Fedders Owners Manual. You can download and print the pdf format for the manual,
http://www.retrevo.com/d/df/document.pdf?doc=1361468de71c8749530c445c5e979550&ts=1304020994998&rk=0.4552581818908856
Hope this helps you.
Apr 28, 2011 | Maytag MEY12F7E Air Conditioner
Error code Df and e4
E4 Outdoor activation of low pressure switch/ less suction pressure.
Check back pressure, which should be 60 PSI when ambient temp 98 degree.If not Short of gas- find leak and arrest. And do gas charging. Even due to indoor coil dust blocked also e4 arise. Clean the coil and reset it.
Nov 25, 2010 | Napoleon NHPS12 Air Conditioner
WE have a broome wade air compressor model 300 df that is used for instrement air inside our facility. Our problem is with high temperture at discharge after the after cooler and after the trap. We changed...
hi i have come across this many times the 300 df is a great compressor but in normal mode lacks the cooling and seperation recqired for instrumentation your solution is to fit a seperate cooler and bigger seperator/trap the compressions must be A1with no c/case blow back hope this helps merlin v12
Aug 13, 2009 | Air Tools & Compressors
I have a GE window unit. I do not hear or see any water draining.. and I do not hear any change in the way the unit runs like I used to when it would blow really cold air. The air is cool - but not cold...
May need to wash out the out door coil. Normally spray through rear coil at about a 30 degree angle. try not to spray water directly into fan motor. If unit is freezing up it may be low on freon. if it is real hot out you may need to run 24 hour a day. High indoor humidity will affect its output also. could have weak compressor. check temp drop accross indoor coil. Shoud be 20 - 30 degrees in most cases cooler than room temp.
Jun 23, 2009 | GE AJCQ08ACB Air Conditioner
LG split system cooler/ heater heater not working
This could be a problem with the interconnecting wiring or a control board problem with either the indoor or outdoor unit. I would have these issues looked out.
Hope this helps
Mat
May 28, 2009 | LG LSC091PMA Split System Air Conditioner
Heating & Cooling Logo
143 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
