Subject: 1974 Rover P6 3500 V8 Auto. After a few months lay up and after getting the car started, we noticed the oil pressure warning light was on and the pressure gauge was at zero. Is this a failure of the switch or something worse? Is it OK to run the car? Please advise Rodney Smith
    Brigadier General:
  • 6,966 Answers
In most engines, the oil pressure warning lights works in conjunction with the pressure gauge both of which detects the oil pressure circulating inside the engine. The pressure is brought about buy an oil pump which drives the oil around. Therefore, the light going on and/or the gauge reading zero indicates that either:
1. there is very little or no oil inside the engine; or
2. the oil pump is not working.
Another possibility is that the oil is too thick for the pump to work on.
All of the above has to be corrected prior to turning your engine.
It would be very rare for both the oil pressure sensor (that activates the light) and the oil pressure gauge to be defective simultaneously.
To my understanding, most if not all Rover V8 engines have an external/mechanical oil pump that is mounted on the front cover, the base of which carries the oil pressure relief valve and oil filter. This page has information about Rover's oil pump.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 24, 2008
Where is the valve lifter oil filter located on the 04 Yukon XL SLT 2500 6.0L V8 4X4 ? How do you get it out?
It's low or out of oil do not run engine check and add oil to fill on dipstick. Oil filter location depends on make and model your local auto parts store can point it out. But don't even start it till you get oil up to full
Jun 30, 2016 | Cars & Trucks
2008 Trailblazer oil pressure guage at zero but driving fine?
Replace the oil sending unit. On top of the engine, in the center by the fire wall.
Apr 19, 2015 | 2008 Chevrolet Trailblazer
2004 land rover discovery bosh engine shakes whole vehicle when start up for a while then goes away. sometimes shakes while driving. sometimes while coasting, sometimes when idling in park and sometim
have the lifters removed and check for leak down and blocked oil holes and worn plates, broken springs. have the injectors checked for blocked tips . Have the fuel manifold pressure tested to ensure adequate fuel pressure is maintained as that also causes misfiring.
Mar 02, 2014 | Land Rover Cars & Trucks
Oil pressure light on in my range rover
I would have the oil pressure checked with a mechanical gauge.
The gauge is inserted into the hole where the electric switch goes for the warning light.
The switch could be faulty, or you could be loosing oil pressure once the engine warms up.
Jul 18, 2012 | 1995 Land Rover Range Rover
I have a 1995 Oldsmobile Aurora with a 4.0 V8 engine. When the car is sitting still at a redlight etc., the "Low Oil Pressure" warning light comes on. When I start again it stops alarming until I come to...
I had this same problem. I put in a can of engine restorer and lubricant, the 8 cyliner formula and had no more problem with that light coming on. this is found at advanced auto at about 10.00 a can. it will restore your engine's compression.
Oct 12, 2010 | 1995 Oldsmobile Aurora
No oil pressure in my rover v8 engine. The car is a TVR 350i 1988 fitted with Rover V8. At the track today it lost oil pressure after a few laps and have no pressure and the oil light is also on. Engine...
You may have sludge in the "pickup tube" which would prevent oil from circulating through the oil pump into the motor. Remove the oil pan and inspect and use a long piece of weed trimmer line to unclog if the tube has any nasty sludge in it. Do NOT alter the length of the tube. Make sure to remove any sludge build up in the pan.
Jul 25, 2010 | 1995 Land Rover Range Rover
Could you tell me were my oil presher switch is on my 3.9 v8 range rover classic the year is 1990
check next to your oil filter. be sure to apply a light coat of black silicone or teflon tape(without getting ANY near the pressure hole)on the threads of the sensor to aide in sealing.
Nov 02, 2009 | 1990 Land Rover Range Rover
Flickering oil light
This could be two unassociated problems; the flickering oil light can indicate that the pressure sensor for the idiot light is failing- this is not uncommon, the other can be a failed temperature sensor sensor on the main radiator.
The low oil pressure condition may also be indicative of a worn engine part or parts. It would make sense to have the actual oil pressure checked in a shop to see if it is in the normal range which should lay between ~30 & 60 pounds depending on engine RPMs and engine temperature. The idiot lights trigger at around 4-5 pounds and this is really pretty late for a warning; if the pressure is actually that low, not only lubrication is too little but the cooling effect of the circulating oil is inadequate.
If it was my car, I would replace both sensors before getting too worried. The cost of these together (parts only) should be well under $50 US.
May 25, 2009 | 1999 Ford Taurus
02' Mercury Mountaineer 4WD V8 - High Temp & Low Oil Pressure
I am having the same problem. Changed the pressure switch and that didnt help.
Jan 01, 2009 | 2002 Saab 9-5
Computers & Internet Logo
174 people viewed this question
David Payne
David Payne
