Xerox 8830 Plotter -- How do I clear an E4-04 error message which states PLEASE OPEN THE CUT SHEET FEED-IN SHELF AND CLEAR THE EXIT AREA? The error message remains preventing printing even though the cut sheet feed-in shelf and exit area are clear.
3 Suggested Answers
  • 51 Answers
SOURCE: E4-14
pls check stripper finger assembly
Posted on Dec 12, 2010
  • 122 Answers
SOURCE: Paper exit tray broken
ebay might have another printers like yours that you can buy cheap
.r got to dell there's a phone no for customer service there. and if it looks like it was installed at the factory it might be part of the printer case.
Posted on Jan 11, 2009
Code:08-100,what this code means?
Error means the leading edge of the sheet of paper did not arrive at the preregistration sensor in time, causing a jam.
To fix - Open the inverter door and clear area 14. Open the printer right front door and clear area 2. Retry printing.
Nov 06, 2014 | Xerox WC 4150 NETWORK ACCOUNTING...
Line appears on copies from top to bottom of the sheet, Approx 7 7/8 in. It happen both off the glass and when ripping a job to machine
With lines showing up with both coping & printing, you are most likely need a general cleaning and if that will not work, odds are you are going to need a new OPC drum & drum cleaning blade and a new developer change..... Good Luck
Nov 09, 2012 | Xerox 8830 AccXES N5T Wide Format Digital...
I have a xerox workcentre XL2130. It had a bad paper jam. I cleared it - now it has an error code E4. I've turned it off and on - hit the clear button - nothing is clearing it? Help! Thanks, Stacia
YOU STILL HAVE A PROBLEM IN THE PAPER PATH...
DOWNLOAD THE USER MANUAL
Clearing the Paper Path
- E-1, E-2, E-3, E-4, E-5
When a paper misfeed occurs the red misfeed indicator flashes
on the WorkCentre diagram, and an E status code will flash in
the Display Window. Paper misfeeds may occur in the areas
shown below. Follow the steps below to locate and clear the
misfeed.
Note: Ensure that the alternate paper tray is lowered
(XL2140df only).
Caution: Do not touch the shiny drum cartridge surface.
Scratches or smudges will result in poor copy quality.
Do not remove paper through the bypass. Unfused toner may
adhere in the area, resulting in smudged copies.
E-1
Steps 1-2 for XL2140df only
1. Lower the right Side Tray 2 Access Door.
2. Remove the misfed paper.
3. Close the Access Door.
If paper cannot be removed, open drawer (2) clear misfed paper.
4. Close the Side Cover.
E-2
1. Press the Release Latch to open the Side Cover.
Exit Area
Paper Feed Area
Fuser Area
Side Cover
35
- E-1, E-2, E-3, E-4, E-5 (continued)
Caution: Do not touch the shiny Drum Cartridge surface.
2. Carefully remove the misfed paper in the direction shown.
If paper cannot be reached, open the paper trays and remove
misfed paper.
E-3
Fuser Area
Warning: The fuser area is hot. Take care when removing
paper from the fuser area.
Note: Ensure that the Alternate Paper Tray is lowered
(XL2140df only).
1. Press the Release Lever to open the Side Cover.
2. Pull down on the fuser lever.
• This will release pressure on the paper.
Caution: Do not pull paper up through the fusing unit. Unfused toner
may adhere in the area, resulting in smudged copies.
3. Remove the sheet of paper in the direction shown.
E-4 and E-5 (2-sided Reverse Copy XL2140df only)
Exit Area
1. Pull down on the fuser lever.
2. Gently pull the paper out through the exit area.
36
3. If not accessible, turn the knob in the direction of the arrow
to move the paper to the exit area.
4. Gently pull the paper out through the exit area.
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Feb 12, 2011 | Xerox WorkCentre XL2130f Laser Printer
I have a Xerox 8830, that is getting a LL43 error
An LL43 is a fuser temperature error.
When you first turn on the printer it should display printer warming up and after a little while display the LL43. If the fuser is still cold then you probably blew the thermal fuse and it will need to be replaced.
Oct 01, 2009 | Xerox 8830 Copier
When I send to print some file not printing, the plotter indiquet procesing and not printig ,plotter can scan, No. IP is correct, Submasc is correct, the conection is correct
before you print go to the page setup and din adjust the bottom or gutter and try to print preview and look carefully the area you want to print if completely present or try to uninstall the microsoftword and install again
regards
fdlixboy
Jul 08, 2009 | Xerox 8830 Copier
I have a Xerox 8830, that is getting a LL90 error after printing a couple jobs. I can restart and the error will clear but than comes back after a couple jobs. Is this a sensor or is it some other problem?
LL-90 and LL-91 refer to low toner and too much toner. If low, the cartridge is nearly empty, if too much, tape off half the holes on the cartridge.
Jun 15, 2009 | Xerox 8830 Copier
Error code A7 on brother mfc-420cn
Hi there
(A7 One-line feeding timeout error. )
Brother Error Codes RAM clear (most models)
Quickly press function * 2 8 6 4
Display should read maintenance
Press 0 1 for a full ram clear, or 9 1 to retain user data
Display should read reinit for a few moments then redisplay maintenance
Press 9 9 to exit the maintenance mode
Other maintenance mode switches:
01 ram clear (see 91 below)
02 scanner initialize (feed a white sheet, then a black sheet)
05 white level
09 print test
10 modify soft switches
11 print configuration list
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
75 display drum life (if enabled on laser models)
76 reset drum life counter (laser models)
91 parameter initialize (user programming remains intact)
95 protection
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 05, 2009 | Brother MFC 420CN All-In-One InkJet...
E4-14
Mar 16, 2009 | Xerox 8830 Copier
Installed new 084K18470. Error e2-3 will not clear.
E2-3 is paper jam at tray 3 check paper path as paper exits this tray.
-Carl, please let me know if this helps.
Jan 21, 2009 | Xerox Phaser 4500/YDX Printer
269 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
