Question about Frigidaire FRS26KF6E Side by Side Refrigerator
I have ocean fridge freezer and the freezer part not working i.e not freezing properly. Many thanks i await for your reply.
    President:
  • 2,468 Answers
The ptc overload on the compressor is not working and needs replacing,its located on the compressors side body under a spring clip,merely unplug it and get a replacement and plug it back in and its good to go
Posted on Jul 29, 2010
Pkg says to freeze put bag in freezer but bag has small holes (came that way) - will the berries get freezer burn or is this part of freezing - brand ocean spray
The holes are to stop mould and mildew. Put the bag in the freezer as is and then when frozen put them into a Ziplock freezer bag and try and remove as much air as you can. This will prevent freezer burn.
If you bought them for Thanksgiving you can keep them in the crisper of the fridge for a couple of weeks.
Do you need a great recipe for cranberry sauce? I am a chef :-)
Nov 18, 2015 | Cell Phones
Refrigerator side freezing
Either the damper also known as the diverter door is not functioning properly or the thermostat tempreture control is not working properly. You could also have a defrost issue which you could visually notice if you seen frost build up on the rear wall of the freezer. If you have any questions message me back I await your reply.
Thank you
Rick
Jul 12, 2012 | Jenn-Air Refrigerators
I want to replace faulty freezer thermostat in whirlpool side by side fridge mod ed22dqxew01 --am having trouble removing cover for freezer-refridgerator control dials. I removed two screws in rear of
First question why are you replacing the freezer thermostat? Do you have an ice build up on the rear wall of the freezer? This build up if you do have it is not due to the thermostat control for the freezer. It is termed as a defrost issue due to a fault condition being present in the defrost thermostat, the defrost heater, or the defrost timer or adaptive control depending on which type of refrigerator you have. I will await your reply as to why you are replacing the control thermostat and if you do have any ice up condition before posting further how to solve this situation. I await your reply
Thank you
Rick
Jan 01, 2012 | Refrigerators
Hi I have a very old KIC fridge freezer the freezer is cold and works well the fridge is not icing up on the back board in the fridge everything going off in the fridge what could be causing this?
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Nov 01, 2011 | Refrigerators
Fridge won't cool but freezer working fine
Oct 31, 2011 | Refrigerators
FREEZER WORKS FINE FRIDGE NOT WORKING WHATS WRONG HOW DO I FIX IT
Oct 28, 2011 | Refrigerators
My fridge is not working, freezer ok model no er 80341
Oct 22, 2011 | Refrigerators
Fridge/freezer not working
check the condensor fan if that aint it unit may be low on charge
Apr 24, 2010 | Freezers
Whirlpool sidexside m-gd25dq does not cool properly
Sounds like bad cold control. Replace it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 15, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezer not working but fridge is
tratra72
You said,
I opened my freezer today and everything was defrosting. The fridge is working fine. I thought maybe did not shut properly so made sure it was closed and 8 hours later it is still not freezing. The fan is working but the air is refrigerator. HELP!!!
1.Try unplugging the fridge for 5 minutes and then restarting it! This may reset the system!
2.If the freezer is so full that the rear vents are blocked then this may happen. Because the fridge and the freezer share the air!
3. If not then the freezer and the fridge have different controls and the freezer control if faulty!
then you need service. ur site has good service companies in your are for our customers!
Bless You,
please give me a good rating before you sign off!
thank you
Sep 14, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Open Questions:
Frigidaire FRS26KF6E Side by Side Refrigerator Logo
187 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
