Question about ViewSonic VA1703wb Monitor
Screen got redish
Screen got red shade due to lightening in sky
  • 69 Answers
Well you need to go to settings and reset it to Factory default settings it's still under warranty then contact the vendor for replacement or contact the customer service.....goodluck!
Posted on Jul 29, 2010
I have an HP dv6707us laptop. The display started getting fuzzy and turning redish and would fail to display anything after a few minutes. I plugged in an external monitor and it works fine. I disassembled...
The screen replacement is defective or the part number is wrong, check the part number on the back of the original screen and compare it against the the one you replaced, it should match.
Jun 15, 2011 | HP Pavilion Dv6707us Entertainment...
I have a Minolta cs pro 2080 copier, shading on copies
3 possible causes:
1) The optics are dirty thus making your copy darker. The test for this is to manually lighten the copy using the exposure control on the panel of your copier. Lighten the copy several positions and see if the copy gets better. If it does then the optics need to be cleaned.
2) The copier is overtoned. This means that the toner to developer concentration is to high. This will require a trained technician to lower the toner ratio and then recalibrate the toner/developer ration using the F8 mode.
3) If the shading gets much worse as you run say 10 copies in a row then the drum cleaning blade would be the cause. So run 10 copies of something and compare the first copy out with the tenth copy out. Do you see a dramatic difference in the amount of background or "shading"?
Good Luck and thank you for using Fixya.
Mar 16, 2010 | Minolta EP4000/5000 CS/PRO Copier
My lapton R52 is working well except the screen the screen is dark or shaded. You can still see the screen but not bright.
Sounds like you back light has gone faulty, or perhaps the inverter, in any event it will have to repaired or replaced. If you cannot do it yourself, please get a firm "Quote" from a reputable service center/man..
Feb 25, 2010 | IBM ThinkPad R52 Notebook
I have a KF-42E200A Sony Bravia LCD tv. Recently we had to replace the lamp. Since then a horizontal line appeared at the top of the screen and it has grown to about 3 inches now. The picture itself is...
The lenses in the TV are more than likely misaligned due to heat from lamp. The heat can cause the lenses to move and the red shaded horizontal line appears over time because the lenses fall out of alignment.
You just need to have the lenses realigned and the red shading will go away.
Jan 07, 2010 | Sony Televison & Video
Game starts out fine and then colors like the sky and streets go to a redish color and the boxes that give instructions become unreadable.
Sounds like your GPU is overheating and you will need to stop this eventually you will get the 3 red lights. To stop this you need to get it repaired or fix it yourself using a proven guide
Nov 25, 2009 | Microsoft Xbox 360 Console
The colour on my television has changed to different shades.
It is obviously difficult to provide an acurate reply / quote by email.
I would estimate a repair costs of about £150 - £200 or so, perhaps less if you use reclaimed parts.
Your TV sounds as though it requires a Y-Sustain PCB.
Sep 06, 2009 | Akai PDP-42TD1 42 in. EDTV-Ready Plasma...
I forget how to brighten my screen...?
To adjust the contrast, follow these steps.
1. Press and release the [2nd] key.
2. Press and hold ↑ or ↓ which are below and above the contrast symbol (yellow, half-shaded circle).
· ↑ lightens the screen.
· ↓ darkens the screen.
Rate me, thanks.
Jul 11, 2009 | Texas Instruments TI-83 Plus Calculator
Shades of pink and green on screen
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Apr 03, 2017 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
ViewSonic VA1703wb Monitor Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
