Question about Intel Motherboard
I had put my Ram wrongly and it burned but after replacing it still it did not work
  • 69 Answers
You need to replce your Motherboard as the memory socket has gone faulty or you van try contacting Geek Squad @ 1-800-433-5778......goodluck!
Posted on Jul 29, 2010
    Problem Solver:
  • 14 Answers
You could have damage the motherboard.
If you didnt use up all your ram slots, try putting the new ram in the unused slots and see if that works.
If it doesnt you may have to get a new motherboard.
Burning way to much gas
Tire pressure, Dirty Air filter element, needs tune up, misfire, fuel leak, bad sending unit, etc... you need to troubleshoot logically. Are there any trouble codes? When was the last tune up? How big are your tires? What does it normally get for gas mileage? Etc..
Jun 18, 2013 | Dodge Ram Cars & Trucks
When i push the power button on my emachine the e screen flashes and it wont turn on what do i do to fix this?
If you just did a memory upgrade then the new chip is either not seated properly or the wrong type or even bad. Since it won't boot the problem is the ram in memory slot one. You need to rock it a bit to make sure it is seated before snapping it in. If it is the wrong speed or type you need to exchange it. It can also be bad but that usually means a counterfeit these days or you gave it a static shock and burned it out..
If you put your old ram back in you should be able to work again until you get the ram replaced.
Sep 02, 2011 | E-Machines 128mb memory upgrade for...
When i start my dell optiplex 330 pc, the power light will be blinking orange and all the fans on the pc do not work but the orange led on the motherboard works. It was running ok until I shift the RAM...
Youve burned something, You may have shocked your motherboard and burned it out. You don't need to see burn marks to fry it. or the ram stick is no longer good. try this, take out your ram stick, and the big watch battery along the wall, carefully not to touch anything else.. pull that out while off for 10 seconds, then re put it in. but it seems like somethings burned.. ive done that once, it was the ram stick, the other time i straight shocked the computer.. but try the bios thing, its a stretch but a possible jumpstart..
Sep 29, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Have a 1996 Dodge Ram 1500 4x4 i have high beams but no low beams why?
on rare occasions I have seen both low beams burn out I would buy one new bulb and replace either one in the truck if the low beam works with the new bulb then replace the other one as well if the low beam still does not work then replace the headlight switch also check to see if the headlight switch recall was done on that particular truck or if it was under that recall,they had a problem with some of the ram trucks burning up headlight switches but I would check to see if yours might have been one of them there is a wiring upgrade that they will put in at the headlight switch that will cure that,like I said though check to be sure first yours might have not been one of them.
Feb 02, 2010 | 2001 Dodge Ram 1500 Truck 2WD
Burned RAM
just remove the 256mb ram it is the main problem only insert equal memmory of rams in 2 slots, if u insert 1gb ram in one slot try to insert also 1gb ram in other slot, donot inser 2 unequal rams in one time
Sep 28, 2009 | Computers & Internet
I put the wrong type of RAM and it caused the computer to stop booting and gave out a burn electric smell. Now, the computer won't even boot. Any remedy to this?
Try with a different memory and check if the system works fine else Im afraid that the mainboard could be the issue.
The best remedy would be to get the motherboard replaced as the extent of short cannot be determined.
Sep 12, 2009 | ASUS P4S533 Motherboard
Prolem with DDR RAM 400
Hello, you might want to check hear http://www.crucial.com/ there is a good chance that you put the wrong type of ram in this computer.And it might need a new motherboard.
Oct 01, 2008 | Compaq Presario 5000 PC Desktop
I purchased a Dazzle DVDRecorder to convert our home 8mm tapes to DVD's. It seems simple enough. I plug the sound cables & video cable into our video camera and then into the Dazzle. I put the...
your pc may be struggling memory and processor wise especially if you have under 1GB ram fitted, as other applications will be taking u your ram also.
So instead of burning direct to dvd drive burn the dvd image to your hard drive first,(remember about 1 hour of video takes about 10GB of hard drive space) then burn it to dvd, so as your pc is only doing one task at a time
Aug 21, 2008 | Computers & Internet
Stopped burning
Its the burner... You'll need to replace it. you sound as if you know what you are doing so i doubth you are doing anything wrong.. Its the burner,,
Nov 10, 2007 | Pioneer DVR-S111B DVD RW Dual Layer Burner
Intel Motherboard Logo
32 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
