Question about Pentax Optio A40 Digital Camera
Dropped my camera with lens fully extended.can't turn it on or off, although the green light comes on when start button pressed and screen iluminates for a second befor turning off
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 29, 2010
I have a samsung TL205 and it wont come on.
This is Battery Issue, Charge the battery fully.
Also Wipe the contacts on the Battery and inside the Camera battery slot
It should work fine
Regards,
Suhail
May 20, 2012 | Samsung DualView TL205 Digital Camera
I put in my battery after charging and the camera opened but it will not take pictures. The lens will note retract. when I press the on button the green light comes on but the camera buzzes and nothing...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 24, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon G7 lens get stuck with no liveview image.
ur lens belt got creck send it for replacement
Jun 17, 2009 | Canon PowerShot G7 Digital Camera
Lens will not retract. orange and green lights come on, but preview screen remains dark and lens will not retract when I trun it off.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 02, 2009 | Cameras
E18 error on canon digital camera s200 powershot dropped it and now the lens is stuck halfway out/in The lens will not open, it was not dropped. I get e18 error.
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
http://www.e18error.com/repair.html
Hope this helps, let me know if you have a proble.
You can Try the following also;
Remove the batteries from the camera, wait a few minutes. Put a fully charged batteries back in and turn the camera on. if it doesnot work then,
2: Remove the batteries again, as also remove the memory card. Then install the newly charged batteries, when you turn it on it should come back to life.
3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful to overcome any grit or sand particles that may be jamming the lens.
Try the above and let me if its any help.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 07, 2009 | Canon PowerShot S200 / IXUS 178 Digital...
Battery died while lense extended and now will not power up.
Some of these cameras that have a lens that extends use gears to extend the lens. The gears can strip or get clogged with fine debris and jam the lens. Usung good quality rechargable batteries NOT ALKALINE will usualy have the power to drive the lens.
Ask yourself, how many cycles do you have on the pack? could the pack be weak and not power the camera fully?
Have you tried pushing firmly in on the battery while you power it up? If the camera will not power on with the door open, try and fold a small trip of paper and sit it between the battery and the door. This might push in on the battery enough to better the connection and solve the issue.
If the battery is fine then you may have a lens problem. The lenses can be jammed easy, dropped or an impact when extended is all it takes.
Jan 26, 2009 | Sony Cameras
Cannon G7 need help
Hi
Had the same problem a few months ago.There was a high pitchedwhisltle and I think the screen said "lens fault.turn off camera" or something similar.Bought a G9 to replace as the 7 was out of guarantee but sent the 9 back to the e-bay reseller as it was obviously secondhand with grit around the lens ring and the viewfinder.Ebay never again!.So 3 months ago ago I tried the G7 again with a fresh charged battery before I consigned the camera to the loft.I noticed that each time i switched on the whistle and message was there but the lens extended slightly further each timeso I kept rebooting until the lens was fully extended.Turned the camera off and on again and everything was back to normal.It seems that this may be Canons protocol when a camera goes back.Its been absolutely fine until today.It wont boot up at all.I have tried 2 fresh charged batteries and its dead.Any ideas anyone?
Nov 06, 2008 | Canon PowerShot G7 Digital Camera
NO LCD IMAGE / LENS STUCK
hi ban ive same problem bloody nusience lens wont retract what did u do with urs?
should i return it?
thanks leeanne
leeannehutchinson@btinternet.com
Feb 17, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
A95 Trouble
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
Dec 08, 2007 | Canon PowerShot A95 Digital Camera
Pentax Optio A40 Digital Camera Logo
85 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
