Question about Samsung HCM5525W 55" Rear Projection Television
We have a Samsung 5525 rear projection tv. It was working great and then all of the sudden it quit. It will act like it's going to turn on, red light comes on then blinks three time, then shuts back off....any idea what the problem may be?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 132 Answers
It's impossible to say w/out checking some components and running a few tests on the set first. There are several components that can cause this, and some are more expensive than others. Your best bet is to let a tech take a look give you an estimate. Wish I could be more help, but there are just too many things that can cause this.
Posted on Jul 29, 2010
60 inch has no red
Hi, you`ll need a tv tech for that one, either no red out from rgb chip, bad driver ic, etc. none of these repairs can be done without special tools, video-tek
Jun 29, 2009 | Philips 60P8342 60" Rear Projection...
Tv won't turn on
That unfortunately is the first most detrimental thing for the Lamp. The can lamp can be accessed through a cover in the rear of the set. Take it out and look at it, most likely is shattered. If it is try DLP Lamp Express for a replacement. If not, let me know.
Apr 30, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Samsung HCN4226W Green Tint Around Corners
sounds like the alignment of the convergence in that area needs to be preformed or you have a speaker or something in that corner
Mar 10, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung HCL5515W red convergence problem
sounds like your convergence IC's have fail and possibly a bad dcm. Some of there models have a small board with the ic's them. It may be cheaper to replace the board. But you can repair it if you have proper equipment
Jan 20, 2008 | Samsung PCN5425R 54" Rear Projection...
Samsung 55" TV does not turn on
CHECK YOUR RED ,GREEN AND BLUE CRT'S THERE MAY BE A SMALL CRACK ON THEM.MAKE SURE TO TAKE THE YOKE OFF AND INSPECT THE ENTIRE TUBE IF THER IS A CRACK IT IS CAUSING YOUR TV TO GO INTO SAFE MODE. ALSO CHECK THAT NONE OF THE COOLING FLUID HAS DRAINED OUT OF THE TUBES ON TO THE CRT BOARDS IF SO REPLACE THE BOARDS AND CRT IF CRACKED. YOU CAN FIND ALL THE PARTS AT PARTSTORE.COM HOPE THIS HELPS.
Sep 04, 2007 | Samsung HCN5529W 55" Rear Projection...
Samsung 54" rear projection PCL5415R Won't Turn On
Although I am not incredibly familiar with your model, There is most likely a small board mounted above the others near the crts, there is a small red connector with a blue wire if you unhook it it will remove power from the convergence IC's and if they are shorted it might come up with conv out, will need a new module.
May 04, 2007 | Samsung PCL5415RB 54" Rear Projection...
Samsung HCM5525W 55" Rear Projection Television Logo
105 people viewed this question
Jerry Greenberg
Jerry Greenberg
