Question about iLO DVDR05 DVD Recorder
The tray on the recorder will not open - iLO DVDR05 DVD Recorder
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 132 Answers
You either have a belt or gear slipping, a bad motor, or a disk that is stuck. You can take the cover off and make sure a disc isn't jamed and inspect that the motor is trying to turn. I know that most recorders won't let you open the tray when it is recording. It's a long shot, but you can also try unplugging the power chord and plug back in and see if that will reset it. Does try to open at all? does it make a sound like it's going to open?
Posted on Jul 29, 2010
  • barrett1981 Aug 10, 2010
    Next time, give me your address and I'll fly to your house and I'll diagnose it until I find the problem, and then fix it for ya. Don't worry, I won't charge you anything. I just hope you'll give me a better rating if I do. Geez.
  • Swiftix Sep 18, 2010
    Is this thing a piece of junk or should I invest more in having it fixed?
The disk tray on the recording side of the recorder will not open.
use a paper clip to open. first strighten out the paper clip. make sure power is off to the unit. then with the paper clip insert into hole on the player. the tray will eject out. good luck.
Oct 24, 2014 | Audio Players & Recorders
Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Mar 30, 2010 | Philips CDR775 2-Disc CD Recorder
LG RH1757 (80 GB) DVD Recorder / HDD Recorder Drawer keeps opening Drawer keeps opening and closing and won't read discs! Rassie from Cape Town South Africa
Could be a timing issue with the tray mechanism - possible that somebody has given the tray "a shove" to make it close instead of using the open/close button and has put the timing out.or a worn tray loading belt
Mar 16, 2010 | LG RH177 DVD Recorder/HDD Recorder
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
Liteon DVD recorder LVW-5045 has disc inside and won't open tray
Use your knuckles to knock on top of cabinet just above disc tray door while at the same time pressing open button,99% of the time disc tray will open.The problem you have is caused by a worn out belt drive or the tray is out of alignment.The disc tray belts only cost $2,when tray is open you can see the minature belt that controls door to the right.Use twizzers to remove and replace.Belt size 1.9
Aug 02, 2009 | Lite On LVW-5005X DVD Recorder
LG DVD REcorder disc tray will not open
Most likely the tension band that is attached to the mechanical parts of motor and the tray detached. you'll need to disconnect the power and unscrew the cover open and put the band back in place.
May 21, 2009 | LG DR787T DVD Recorder
CD trays will not open.
Use a paper clip. If you push a wire in the holes of each tray it will release the trays. The proper holes look like little dashes on the face of each tray, one end or the other.
Feb 11, 2009 | RCA CDRW121 2-Disc CD Recorder
TDK DA 3826 disc tray not functioning
Is the motor spinning to try to open the drawer?Can you hear it? Can you get something under the tray edge to try to 'help' it out when pressing eject?
Jan 05, 2008 | TDK DA-3826 2-Disc CD Recorder
Philips CDR796 CD Recorder
You power off then power back on while holding down the fast forward and rewind buttons on the recording side simultaneously. The display moves through a sequence of numbers and the trays will then open.
Sep 18, 2007 | Philips CDR795 2-Disc CD Recorder
iLO DVDR05 DVD Recorder Logo
305 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
