Question about Maytag SAV5710 Top Load Washer
I hear the belt floping around in my front loader washier,how do i fix it??
  • Maytag Master
  • 8,220 Answers
Get the service panel off. Then remove 4 large bolts and the washer motor and pump will come out. Put that on a work table and remove the pump.
Then you can replace the belt.I hear the belt floping around in my front loader - 97a7db3.jpg
Service Manual Amana/Speed Queen/Maytag washer
Posted on Jul 29, 2010
Tip
Drive Belt Installation on a Whirlpool Front Loading Washer
This advice is on how to replace the drive belt on Whirlpool Duet and Kenmore Elite front loader washing machines. To replace the drive belt on a Whirlpool Duet washer, follow these steps:
1. Unplug the washer and turn the washing machine around so you can access the back panel. Remove the rear panel by locating and loosening the screws around the perimeter of the panel.
2. Loop the drive belt on the drive motor pulley with the ribbed side on the pulley. Leave a one-groove gap between the belt and the end of the pulley.
3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
4. Hold the belt firmly in place and slowly turn the drum pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
NOTE: This may require some effort to get the belt in place.
If you have any questions, or are uncertain if these steps apply to your washer (some newer model Maytag front loaders are now manufactured by Whirlpool) please provide me with a model number and I can let you know if these steps apply. I hope this information is helpful.
on Dec 10, 2009 | Washing Machines
Tip
Drive Belt Installation on a Whirlpool Duet or Kenmore Elite Front Loader
on Sep 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool washer front loader is not spining, when i turn on I can hear the motor sound but inside is not moving. Please help me how to fix it. Thank
Possible that the belt had jumped off or has gone loose.Also check the agitator to see if this is free. Also if the bearing is defective and which could slow the revolution.
Jun 27, 2012 | Washing Machines
I have a top loader AMANA wash machine and its making a loud noise, and when I took the front panel off there was oil on the bottom of the washier is that from the transmission
Yes the transmission is the only place for oil to come from. There are rebuild kits availabe if your mechanically inclined and can do this work yourself, if not you need to call a technician.
Mar 12, 2011 | Amana NAV2330AW Top Load Washer
Washier problems
Check pump belt or restriction or kinked hose
Oct 21, 2009 | Maytag PAV2300 Top Load Washer
My whirl pool washing machine no longer spins. I just stopped on day. I can hear the motor trying to turn the drum but it doesnt.
Hi. This is a possible broken belt. You will need to access the drive assembly to confirm. The symptoms you have posted will often lead to a separated belt.
NOTE(IF this is a top loader, and you are hearing noise during the spin attempt, this will lead to failed motor coupler. Please disregard this note if the unit is a front-loader)
Oct 08, 2009 | Whirlpool Washing Machines
How do I put the belt on a frigidaire front loader washer
take the back of ,,might be 15 phillips head screws..around back,,than put belt on motor pully..and than on tub pully hold with one hand and turn,,either way..onthejob
Feb 01, 2009 | Frigidaire ATF6000ES Front Load Washer
How to replace the belt on a Samsung J845 front loader washing machine
Its on the back of machine and after you remove the back cover plate youll see that its very easy to install the new one.You shouldnt have to use any tools to put on the new belt.Just loop it around the motor pulley and around the large tub pulley that you see right in front of you.It may even appear to be too tight while your winding it on the pulleys but its not .
May 20, 2008 | Washing Machines
How to replace the belt on a Samsung J845 frnt loader washing machine
If you stand in FRONT of the washer, leaning over the top, the drive wheel is underneath the main drive motor, on the RIGHT hand side.  Loop the belt over the drive motor wheel, then over the main pully, and it should be good to go!
May 20, 2008 | Samsung WF337AA Front Load Washer
Maytag SAV5710 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
