Question about Dynex Televison & Video
RCA, 52", 16x19 HDTV Projection Monitor, serial #D52W20BYX1E222C30FT Won't Turn On
  • Rey Garza Aug 07, 2010
    I took tv in to get checked and they said the signal board is bad does that sound about right,
    and where can i get one
    thanks.
  • Dynex Master
  • 6,993 Answers
Does the monitor shows any standby light or does it give any sign of power entering into it?
If there is no standby light at all on your Monitor, then it means your Monitor is having a power problem. The power supply board is defective that's why the Monitor won't power up. Its receiving power but it cannot transfer the current to the necessary part of the Monitor because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the Monitor might not come on.
If you know about Monitor repairers, I would suggest that you open the Monitor and read the power board/panel with a meter, detect the bad component and replace it. Take note that Monitor stores a lot of current that can shock just like TV, so leave the Monitor for a while before you open it.
If you don't know about Monitor repairers, take the Monitor to the nearest repairman to fix the fault for you.
I wish you good luck.
Posted on Jul 29, 2010
  • Walesarumi
    Walesarumi Aug 07, 2010
    yes, it sounds right.
    We don't stay in the same vicinity, so I wouldn't know precisely where you can buy the part in your area. But you can shop/order for it online from e-bay or check for it in any electronics or computer accessories store/shop
    Take care.
My "50" RCA Scenium won't
That's usually caused by a bad lamp. However that chassis is famous for having bad caps on the power board. The repair kit is available at the following link and has repair instructions included. http://servicemanuals.vstore.ca/product_info.php/pName/rca-atc336-dlp-power-board-repair-kit/cName/repair-kits
Aug 16, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
HDTV monitor 52 in. Model #: D52W26 Serial #: G072CU07E colors are separated, warped screen and cannot find auto convergence
Very easy repair. The ITC222 and ITC222A convergence option missing repair kit available from www.tvrepairworld.com will solve that issue. Its listed under the RCA repair kits and has the parts and the CD with repir instructions.
Mar 31, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA, 52", 16x19 HDTV Projection Monitor, serial #D52W20BYX1E222C30FT won't turn on
Jul 29, 2010 | Dynex DX-L42-10A 42 in. LCD TV
Lately, my RCA HDTV monitor has been shutting off
Probably bad capacitors on the power supply board. There are about four that should be replaced all at once. The to of the capacitors will be "puckered" or bulged out. They are located toward the front of the power supply.
Oct 14, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDTV - problem turning on
It's on but you are on the wrong input. check your connections from your sources ( i.e. dvd, vcr or satellite/cable box) try pressing source or input button on tv remote
Jul 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19B makes high pitched buzz when on
Sounds like a coil is vibrating or a component is bad causing the transformer to whine. Could possibly just need soldering.
Jul 08, 2009 | Televison & Video
RCA D52W20 52 in. Rear projection hdtv problems
Check 3 capacitors on Power supply/deflection board cp150 2200uf 16v if it is bad replace 2 other caps in same circuit cp111 cp114 220uf 35v
Dec 01, 2008 | RCA D52W19 52" Rear Projection Television
Flashing green power light on TV
have the power supply checked out sounds like it went out
Jul 09, 2008 | JVC AV-56WP74 56" Rear Projection...
RCA 46" (maybe) Monitor Broken What do I do?
If you registered the set with RCA you shouldnt need the reciept just call RCA and explain the problem and they can set you up with an authorized warranty repair center in your area. Heres the number for RCA support you will need your serial number handy when you call its located on the back with the model number.
580-634-0151
May 19, 2008 | RCA HD52W59 HDTV Projection Television
Tv don't turn on
This set has problems with ribbon cable coming from front panel to ssb board. Check to make sure seated properly. For more info ctechnicians.com
Jan 06, 2008 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
24 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
