Question about Dell UltraSharp 2407WFP 24" LCD Monitor
Dell 2407WFP 24 inch LCD F1 fuse specs
I have a Dell UltraSharp 2407WFP 24 inch LCD Monitor which suddenly lost any display.
Power and front LED's seemed fine - just no actual image.
I just fell out of the warrenty so I opened it up and found that a tiny fuse numbered F1 on the inverter board was faulty.
I bypassed this just to double check and the display seems to work.
However I really don't want to bypass the fuse, I want a replacement but I can't see any specs for this fuse other than the 20 it shows on the top.
Can anyone help me with the specs for this fuse so I can get a replacement from maplins?
See below for three images of where I found the fuse and what it looks like (fuse location highlighted in yellow)
http://www.cactushead.co.uk/f1/f1board.jpg
http://www.cactushead.co.uk/f1/f1location.jpg
http://www.cactushead.co.uk/f1/f1.jpg
Thanks for any assistance you can provide
  • Cactushead Aug 08, 2010
    Has anyone got a clue about this fuse? Thanks.
5 Suggested Answers
koraypek
  • 6 Answers
SOURCE: Dell 1702FP Blank Screen problem
Hi there, I had the same problem on two Dell 1702FP monitors and I solved them, now I am using one as an LCD TV and it's been working great since then. Solution: replace surface mount capacitors, 10uF 16V value, C604 and C507... I created an instructables web page for it, so please follow the link below: http://www.instructables.com/id/ELWXF03NV6EQZJIZM2/ Enjoy it! Koray.
Posted on Nov 24, 2006
  • 14 Answers
SOURCE: Dell 1800FP Dark, No Power but power supply seems fine. Help!
I just repaired 3 1800FP's - all dead, no lights.
Firstly a dead 2AS01 is 95% of the problem, because some fool designer left out the protective zener diode - cheapness.
Mouser Electronics does not have this part, but lists it at 37 cents in lots of 2500, and gettable at $2.66 somewhere else.
You must also replace the two small value electrolytics near this IC, as some had an ESR of 40 where <0.5 is where it should be.
I suppose as the electro's dry out, the spikes can zap the IC. The quacks on ebay flogging 2sa01's alone, probably hope to sell you another one down the track (at a fat markup).
There are 2 'Sam Young 2200uf' electros that really should be replaced, with ESR or 2-30 ! Ideally replace ALL electros, as the others will be off - but those 4 as a minimum and using a jewelers loupe, resolder other joints on the transformer and anything that looks more dull silverish, than the rest. A 1 inch used and worn paint scraper will get the case open easy.
DANGER, CAUTION : Finally when refitting the inverter board, ensure the steel tab is over the TOP middle of the board facing away from the power socket (SO YOU CAN SEE IT) . The board sides in flat. It is possible to scew the board down with a slight bend, with the tab pressing over the pcb tracks - very , very bad!
Now all I need is for some kind soul to improve the fix by stating what the value of the missing zener should be.
PS. Just because the caps are not bulging does not mean they should be OK. Most wrecked 10 year old power supplies have better ESR's, so the electronics must be hot under the cover.
I have seen bulging caps with a GOOD ESR, and non bulging ones with an ESR of 47.
Canberra
Posted on Aug 28, 2008
rtrahan
  • 741 Answers
SOURCE: I can Fix It if I Can Find The inverter.
The inverter is a pencil size tube between the front and back panels of your monitor...there is one on each side as it provides the backlight. good luck..pls rate this solution
Posted on May 28, 2009
RodK
  • 5 Answers
SOURCE: Dell UltraSharp 19" LCD Monitor power button
http://en.community.dell.com/forums/t/18671898.aspx
Posted on Aug 18, 2009
2407wfp padlock thx for your help :(
You can try to unlock the display/monitor by pressing and holding down the MENU button on the monitor screeb (OSD menu buttons) while the monitor is powered on. Hold it for about 9 to 15 seconds, then release it. Let us know how it goes.
Dec 25, 2011 | Dell UltraSharp 2407WFP 24" LCD Monitor
I have a 2407WFP monitor. The power turns on but there is no display even when I push the menu button.
You need to take it apart and check the caps in the power supply and fuses on the backlights inverter board, see my pictures here:
http://s807.photobucket.com/albums/yy352/budm/DELL/Dell%202408WFP%20Rev%20A02/#!cpZZ1QQtppZZ20
Read my guide to understand more:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Sep 02, 2011 | Dell UltraSharp 2407WFP 24" LCD Monitor
My power on/off button (on a Dell Ultrasharp 2407WFPb monitor)is stuck. How do I get the back cover off to unstick the button.
This is a very common problem, check the great solution for repairing the power button on Youtube:
http://www.youtube.com/watch?v=RXAQxwCTuuI&feature=related
Mar 05, 2010 | Dell UltraSharp 2407WFP 24" LCD Monitor
The on and off button won pop back out so that i can push it in to turn the monitor off and on.
Call dell with the 20 digit serial no at the back,if it is in warranty you will get a replacement monitor for this issue i had the same problem mine was replaced
Normally Monitor has 3 year warranty for parts
Dec 30, 2009 | Dell UltraSharp 2407WFP 24" LCD Monitor
Hi there! Dell 2407WFP - Front lower right green LEDs light, turn on and off, but screen is dark. I cannot even see a picture searching with a flashlight in the dark. So i believe it is not only the...
Probably the backlight then. If you take a look on eBay you can probably get one for this screen and do the job yourself, they're relatively inexpensive.
Dec 12, 2009 | Dell UltraSharp 2407WFP 24" LCD Monitor
How many inches is the W27OFP?
Should be 27". Can't find that model though.
Jun 07, 2009 | Dell UltraSharp 2407WFP 24" LCD Monitor
Cajun is an idiot. a BACKLIGHT is a pencil sized tube that provides light for the LCD. An inverter will take a small voltage and turn it into a large voltage, with a proportional decrese in current. Not nearly the same thing.
Go to LCDrepairs.com and buy the parts you need.
May 28, 2009 | Dell UltraSharp 2407WFP 24" LCD Monitor
Dell UltraSharp 2407WFP 24" LCD Monitor Logo
627 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
