Question about Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer
My dryer is stopping after about two minutes and displaying message code F22. What is wrong?
    President:
  • 2,468 Answers
Its an open temperature thermistor located in the exhaust vent housing,usually between the blower and the rear exhaust opening that leads to the outside,the thermal fuse is also next to it on the tube
Posted on Jul 29, 2010
My cabrio dryer is overheating. I have replaced thermistor, thermostat, replaced control board but get f22 error code,
Dryers overheat because of reduced airflow. You need to fix that first. Remove the rear vent completely and check the hose for lint and birds nests. Check the flaps on the wall vent that they move freely. Then strip the machine down and clean all the ducting and the fan.
F22 Error Code
http://www.shopyourway.com/questions/1146749
Jan 24, 2017 | Dryers
Maytag dryer 3000 fault code f22
Replace the door latch. Fault code F22 is for the door latch.
Oct 12, 2015 | Maytag Dryers
Dryer shuts after one minute
If it heats then you're getting 240 to the dryer. Take off the vent hose and look for a lint build up in the hose and where it connects to the house. Restriction will cause the dryer to shut off the heat to avoid a fire.
Oct 20, 2014 | Whirlpool Dryers
How do i find out what the frigidaire gallery series dryer error messages are
Hello Friend, this is Z. I appreciate your post!
To get the error code your dryer may be experiencing, attempt the following:
Wake your dryer by pressing any button except for CANCEL.
Press and hold the "CANCEL" and "START PAUSE" buttons simultaneously for 6 seconds to show the error recorder code your dryer may have. The error code normally appears in the display as an E followed by two numbers.
If your dryer shoes, E00 it indicates no failure code was detected.
I ask that you please follow up with a comment on the post, at your convenience, to advise if you receive an error and if further troubleshooting is needed.
Thank you!
Jul 17, 2014 | Frigidaire Dryers
Problem code F22 flashing
http://www.appliancepartsquick.com/MaytagBravosDryerFaultCodes.html exhaust thermister in simple terms is a small round can shaped sensor which turns on/off heating element as the air temp exiting machine rises or falls to stop machine getting to hot and burning out components,reletivly cheap to buy and faily easy to fit depending on youre capabilitys ,if in doubt call a friend who can help or quallified engineer
Dec 31, 2013 | Maytag MEDB400VQ Dryer
DRYER DISPLAYS CODE F22. What does this mean?
"F22" is a door lock issue Press the "Stop" button twice to cancel the cycle if "F22" shows. Check that the washer door is firmly shut--open it and shut it and try again. Make sure there aren't items blocking the closing of the door. Don't overload the basket. Try the cycle again.
Nov 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Error code F22 after 1 minute of drying with brand new Maytag 3000 Series dryer
If it is new, you should call maytag to repair under warranty terms. The unit could be defective.
1 (800) 344-1274 U.S.
1 (800) 688-2002 Canada
Nov 12, 2009 | Maytag MEDE300V Dryer
Kenmore He5 dryer, a service code f22
just remember error codes are always going to be stored on every machine ,, shoukd not have a problem ,, but does it work
Nov 29, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer HE2
my kenmore he2 gas dryer runs for 2 or 3 minutes the shuts off, flashing an f22 error code
May 05, 2008 | Kenmore 85871 Electric Dryer
Display reads F22, dryer shuts off after 1 minute
To enter the diagnostic mode, choose any selector button other than Pause/Cancel and do this little keyboard dance:
Press and hold for three seconds,
release for three seconds;
press and hold for three seconds,
press and hold for three seconds.
You’ll know you’ve entered diagnostic mode because all the indicators on the console will light up for five seconds and you’ll see the code “88” in the Estimated Time Remaining display.
the F22 Code you are getting is the exhaust block or overheat!!! DO NOT USE YOUR DRYER UNTIL YOU CLEAN THE EXHAUST OUT! this is a MAJOR fire hazard
it may also be as simple as a lose wire or something like a bad sensor but chances are that your dryer is doing what its supposed to so that you dont have a fire :)
~lee
admin @ WhyPayForHelp.org
Apr 29, 2008 | Dryers
Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer Logo
153 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
