Problem Event Name: APPCRASH Application Name: sftlist.exe Application Version: 4.6.0.551 Application Timestamp: 4aba5ba9 Fault Module Name: sftfsi.dll Fault Module Version: 4.6.0.551 Fault Module Timestamp: 4aba5ba0 Exception Code: c0000096 Exception Offset: 00129d4b OS Version: 6.0.6002.2.2.0.768.3 Locale ID: 1033 Additional Information 1: e51a Additional Information 2: 4c0d4d78887f76d971d5d00f1f20a433 Additional Information 3: e51a Additional Information 4: 4c0d4d78887f76d971d5d00f1f20a433
5 Suggested Answers
SOURCE: I can't open my ebook library
Here are the instructions by solving this problem:
1. Right Click My Computer
2. Click Properties
3. Click System Protection
4. Click Advanced
5. Under Performances Click Sittings
6. Click Data Execution Prevention(DEP)
7. Click Turn on DEP for all Programs and Services except those I select
8. Click add
9. Under File name: type in ebooklibrary.exe click open.
Make sure that while doing this process your Portable device is connected to the computer. otherwise you will get a message telling you that ebooklibrary.exe file not found. it took me a while to figure this out. I hope that this will help.
Posted on Jan 12, 2009
Nitin_Master
  • 846 Answers
SOURCE: Problem Event Name: APPCRASH
try this
http://www.microsoft.com/downloads/details.aspx?FamilyID=b0c7136d-5ebb-413b-89c9-cb3d06d12674&DisplayLang=en
Hope It Solved Your Problem
Good Day
Posted on Apr 13, 2009
Saigua
  • 981 Answers
SOURCE: Lenova computer running Vista crashes
Weird category.  Seems OS- or program-specific enough.
The exception codes are supposed to give you insight into what's going on, (Intel exceptions C000 00029 and E043 4F4D in the context of Vista or your CPU in particular, say) but perhaps you should try the Vista equivalent of WinXP's RunAs options, where you can run them as older applications and dodge some incompatibilities.
Similarly, you might want to create a VM (or runtime jail; many, many options to be had there...) and try it in that context, so that if the program's spoiling things at least your system won't need to worry or crash.  The easiest thing of course is to find updates of those programs that promise to play well with Vista.
Posted on Aug 24, 2009
  • 9 Answers
SOURCE: Problem signature: Problem Event
Try this
  1. Go to the Control Panel and click Printers
  2. Right-click on the white space and click "Run as administrator > Server Properties"
  3. Click on the "Drivers" tab, click on the offending printer and click on the "Remove" button.
When prompted, click "Remove driver and driver package."
Answer "Yes" when prompted to delete the driver.
4.You will then see a dialog indicating that driver package information has been collected. Click on the "Delete" button.
5. Back in the printer list, delete the offending printer by clicking on it and pressing the Delete key on your keyboard.
For really stubborn printers that refuse to delete, note the files the printer driver uses and delete them while in safe mode. To do so, on the "Drivers" tab (see above), click the printer and click properties. Sort the "File" column alphabetically by clicking on the heading. Write down the files involved and also write down the "driver path" above the "File" column. Delete these files in safe mode, then repeat the removal procedure above.
OR if problem is due to a corrupted spool queue
Open up c:\windows\system32\spool\PRINTERS
Delete the contents of the directory (not the directory itself).
Retart the print spool service
Posted on Feb 01, 2010
Problem Event Name: APPCRASH Application Name: QuickUp.exe
here -
http://www.faultwire.com/solutions-exception/Quickup-exe-has-stopped-working-*834.html
Nov 13, 2012 | Computers & Internet
Http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
Application Name: arma2OA.exe
Dec 02, 2010 | Computers & Internet
Please try disable the Data Execution Prevention(DEP) or add the Yahoo messenger.exe in Data execution protection (DEP) exclusion list. This error is comming because you have enabled DEP. I think it will help you to fix the issue.
Thanks for joining Fixya community...Good Luck
Dec 09, 2009 | Yahoo Messenger
Sst programing on saitek X52pro , ones install I clik on the place that Im suppost to setup , then got messge error : Problem signature: Problem Event Name: APPCRASH Application Name: ProfileU.exe ...
sst programing on saitek X52pro , ones install I clik on the place that Im suppost to setup , then got messge error : Problem signature: Problem Event Name: APPCRASH Application Name: ProfileU.exe Application Version: 4.3.4.17 Application Timestamp: 44fd31e8 Fault Module Name: ProfileU.exe Fault Module Version: 4.3.4.17 Fault Module Timestamp: 44fd31e8 Exception Code: c0000005 Exception Offset: 00001fda OS Version: 6.0.6002.2.2.0.768.3 Locale ID: 1033 Additional Information 1: 253c Additional Information 2: 287b034b0bef0590cba0ccef4c4b4b77 Additional Information 3: 7de0 Additional Information 4: bfe79fb32a74e3eb99cc45f1169d5e8b
Aug 07, 2009 | Computers & Internet
T is constanly coming when i play brian lara cricket 07..i'm having windows vista ultimate.is there any solution to this prob.If so pls send it to me as soon as possible. Problem Event Name: APPCRASH ...
Problem signature:
Application Name: ICC2007.exe
Application Version: 1.0.0.1
Application Timestamp: 21444c52
Fault Module Name: ICC2007.exe
Fault Module Version: 1.0.0.1
Fault Module Timestamp: 21444c52
Exception Offset: 001212f0
OS Version: 6.0.6000.2.0.0.768.3
Locale ID: 16393
Additional Information 1: 8a65
Additional Information 2: a977d7b616fbef91d447986a1e395fda
Additional Information 3: 902c
Additional Information 4: d3100cb634d31eedbe4c3e2cdaa33f77
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
when i play brian lara 2007 it shows this error plz help me
Mar 13, 2009 | Codemasters Brian Lara International...
Computers & Internet Logo
155 people viewed this question
Alun Cox
David Payne
David Payne
