Question about Alpine Air XL-15 Air Purifier
I have the living air xl15 its not working properly, I cant smell ozone no buzzing sound no uv light no green led coming on. I guess the only thing working is the fan. I don't have a manual and it blows my mind this company doesn't offer it online, what a joke. please help and try to really spell it out for me. Thanks
I have an extra user manual for the alpine. You have to clean the plates at least once a month to get maximum performance. Get back to me at nick61@telus.net for the manual. Also the ion emitter sometimes needs to be replaced. I use one of mine in my FIR sauna. It seems to be OK at those high temps. 50*-60* C..so far.
Posted on Aug 04, 2010
Hi-I have the Living Air XL. It's out for repair because I cannot smell the distinct clean smell it normally puts out. The repair guy just called and said it's fixed and running, but the green light bulb...
He probably cleaned the unit and restored the plaques. Green light or no green light, it doesn't affect the production of ozone. If still in doubt, when you go to pick it up, have him operate fit or you before you leave the store. I've had one 7years and the green light hasn't worked for three years. I clean it regularly and it still produces ozone when needed. Regular, routine maintenance is the answer.
Mar 28, 2011 | Ecoquest Living Air Classic Air Purifier
I have the living air xl15 its not working properly, I cant smell ozone no buzzing sound no uv light no green led coming on. I guess the only thing working is the fan. I don't have a manual and it blows my...
if you're sure you feel a breeze (fan is working), then this won't help. but make sure the rear filter is pushing in the metal tab at the bottom, or else it won't turn on. you can hold it in with a pencil to see if the machine works. also, are your plates in correctly, are any broken ? also, check/replace the internal fuse which you can find in the back.
Jul 29, 2010 | Ecoquest Living Air Classic Air Purifier
Green light is on, fan is blowing but we know longer smell the ozone from it; we have just changed the plate & cleaned it?
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
Apr 18, 2010 | Ecoquest Living Air Classic Air Purifier
I bought my Living Air XL15 in Ebay. It was
The ozone plate may need to be replaced.
Mar 01, 2010 | Alpine Air XL-15 Air Purifier
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
I have an Alpine Living Air XL15 which doesn't produce ozone . It has new plates but I,m told the plates should glow or sizzle. Can you tell me what the voltage should be at the grid plates. I had the...
The plates should not glow, but on High, you should hear a buzzing sound. But, you should also smell the ozone. I've only worked on two, but the reason they both didn't work was that the connectors on the wires leading to the plates were corroded beyond use. The top connector was the worst. Cutting them off and installing new ones solved the problem. Also, when you clean it, always clean the contacts where they touch the plates with alcohol. Look at the plates to see if they have more than one spot of glue around the center of the plate. (both sides) If so, they will be less noisy than older ones. Hint - Replace the plates when the glue on them turns dark brown.
Apr 01, 2009 | Alpine Air XL-15 Air Purifier
No Ozone
Mine has a switch lower right hand side that will stop the ozone.
Aug 31, 2008 | Ecoquest Living Air Classic Air Purifier
Alpine Air Living Air XL15 not producing Ozone or Deodorizing. New plates
Confirm that the appropriate sections of the circuitry are powered up and drawing power; check the interlock switch action; toss it back to the maker because the Hi-V transformer or ladder circuit or sense or hold caps were (if testing proves) never quite functional.
Dec 03, 2007 | Alpine Air XL-15 Air Purifier
XL15
The ozone plates need to be cleaned monthly to work effectively. You can get an owner's manual for free from the manufacturer's website, it's at:
http://www.ecoquestintl.com/support/US50300_Living_Air_Owners_Manual.pdf
The manual has a description of the type and frequency of cleaning of various parts of your air purifier. Hope this helps!
Oct 29, 2007 | Alpine Air XL-15 Air Purifier
Alpine Air XL-15 Air Purifier Logo
883 people viewed this question
Top Alpine Air Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Tom Chichester
Are you an Alpine Air Air Purifier Expert? Answer questions, earn points and help others
