Question about Fisher and Paykel GWL11 Top Load Washer
Nasty odour coming from inside machine even after numerous cleans with hot water, detergents, vinegar and bicarb of soda.These were done individually over quite a period of time but the smell still returns. So far it doesn't appear to have had any bearing on the clothes that have been washed but the laundry itself is starting to get an odour when the lid of the machine is open.
    President:
  • 2,468 Answers
You may need to remove the inner wash tub and access the outer tub to clean out all the spent soap,detergent,fabric softener that hasn't been drained during previous washes and have now created a sewage mold from just sitting there,also make sure all the drain hoses and the pump are clear and there are no hoses kinked all the way to the drain
Posted on Jul 29, 2010
Low water level
Clean the intake filter and drain pipes
Pour the vinegar into a measuring cup and head over to your washing machine.
  1. Add the baking soda mixture to the detergent container of your machine and pour the vinegar into the drum. ...
  2. Use a clean scrubber to rub around the opening of the washing machine, removing stubborn mold or residue.
How to Clean the Inside of Washing Machine
Sep 10, 2016 | Washing Machines
What lime scale / detergent remover can be used for regular cleaning of my front loader.
Front-loading washing machines are energy efficient and use less detergent than top-loaders, but they sometimes have a tendency to harbor mold and unpleasant smells. By giving your washing machine a quick clean once a month, you'll keep your front-loader fresh, which means cleaner clothes, too. This eco-friendly method doesn't use bleach, costs only pennies to make, and comes together with ingredients you already have on hand.
What You'll Need:
  • 2 cups vinegar
  • 1/4 cup baking soda
  • 1/4 cup water
  • Scrub sponge
Directions:
  1. Start by mixing together the baking soda and water in a small bowl. This is going to be the "detergent" for cleaning the washing machine. Pour the vinegar into a measuring cup and head over to your washing machine.
  2. Add the baking soda mixture to the detergent container of your machine and pour the vinegar into the drum. Set your washer to normal load at the hottest water setting. Close the door and start the machine, letting it do all the hard work for you. The baking soda and vinegar naturally break up mineral deposits and any mold growth while cleaning and refreshing your washing machine.
  3. Use a clean scrubber to rub around the opening of the washing machine, removing stubborn mold or residue. Wipe clean with fresh water.
  4. Your washing machine is sparkling clean and ready to do a load of laundry! Give your front-loader a cleaning once a month to keep your clothes smelling fresh and your machine working in tip-top condition.
Mar 20, 2015 | Washing Machines
I put thru a hot wash with bicarb and vinegar in my top loader Why does my machine leave suds after the rinse cycle now
You are using to much soap. todays machines are low water and todays detergents are concentrated.
Mar 15, 2015 | Washing Machines
How do I keep my front loading washer from smelling like mildew
Hi Cheyenne! There are a variety of ways to keep your machine smelling clean. The first and foremost is to make sure you are using the correct kind detergent for your machine.
Do you have a high efficiency washer? If so, be sure you should be using detergent that specifically states it's safe for use in a HE machine. There is a little HE emblem on the detergent bottle or box that clearly states it's safe for your machine, and the machine requires a very small amount when using the correct detergent. The wrong type can cause too many suds. The more suds = the more residue to get stuck in the nooks and crannies where mold can live and breed.
The next tip is to make sure you do not leave wet clothing in the washing machine, that isn't as easy as it sounds, I know ... but it is a big cause of mildew. Also try leaving the door open between washes to allow the interior to dry. With the door closed the water from the last load is unable to dissipate and will eventually mildew. But good news! Even if you've already developed that nasty smell, there are solutions!
Clean the inside of the machine by wiping the interior (drum, door, rubber seal...everything!) using bleach, white vinegar or your favorite household cleanser. They also sell tablets designed just for this problem in the same section you buy detergent and fabric softeners.
make sure you really scrub the the rubber seal, it is often the biggest culprit as there are a lot of nooks and crannies for the mildew to hide out in.
If you have an HE machine, remove the detergent tray and sterilize it
Finally, run a clean cycle on the machine by adding 1/4 cup of bleach or white vinegar to the detergent tray and run the machine through a hot wash cycle. Some machines have a "Sanitize Cycle, and this really does the job. Once that is done, air out the washer overnight: .
Another way to keep that smell from coming back is to put one tablespoon of baking soda in the drum after each load. This will continue to absorb smells while you aren't using the washer, and will be beneficial to the next load of laundry!
May 01, 2014 | Washing Machines
Dishwasher does not clean tea stains from teacups- we have tried a variety of soaps and have used sani-clean. Machine is only one month old- new fully integrated model.
Method #1
  • Wet a cloth then rub the inside of the mug with baking soda. If the stains are stubborn, soak overnight in hot water and baking soda.
Method #2
  • Soak the mug in bleach OR vinegar for several hours or overnight.
Method #3
  • Fill mug with boiling water, add two spoonfuls of dishwasher detergent then soak overnight.
Method #4
  • Try a paste of corn starch and vinegar, apply and let sit for a few minutes then scrub away.
Method #5
  • Drop two denture tablets in the mug, pour hot water over top then soak overnight.
After soaking mugs and removing the stains, rinse and wash very well before using-especially when using the bleach method.
May 06, 2011 | Samsung Dishwashers
How to clean the rubber seals of a front loading washing machine
You can use wire scouring pad with a cleaning agent, but it probably will not remove all stains, you will not harm the seal doing this.
The prob is originally caused by doing too many low temp washes, you should do a 95 degree wash without clothes in, but with the powder in at least once a month, it is called a maintenance wash, and all manufactures recommend you do this on a regular basis.
If it is really bad then the only satisfactory solution is to replace the seal, and keep doing a hot wash periodically.
Please rate my solution.
Thanks.
Oct 19, 2009 | Electrolux Washing Machines
Rid of Mildew Smell?
Make sure there are no leaks from the machine. look behind it and check the water inlet hose and connectors for any damage. Also look under the machine for any water as this may indicate a leak from the internal hose and pipe work and / or water pump. Also check that the outlet hose is completely clear of debris and soap scum build up and check that the filter is clean.
To keep the machine clean of waste build up and to keep any bad odours away
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Aug 22, 2009 | Bosch Nexxt 500 Plus WFMC5301UC
Musty smell
This problem is caused because the water does not get totally pumped out of the outer tub and sits in the bottom of the tub and in the front seals. Eventually a mildew type scum develops and causes the washer to stink and also impart the odor to clothes. Even though front loaders do use less water and energy, all of them have essentially the same design and therefore all will eventually develop this problem.
Run a load with just bleach (about 1 cup) and white vinegar (about 1 1/2 cups) poured directly into the washer with hot water and it seemed to help, but this does need to be repeated about once a month or so...
but with your wife's Asthma tho you could try
Typically the cause is the machine itself, but occasionally the water being used in the washer can be the source of the problem. If the smell resembles rotten eggs, you may need a water filtration system installed. After you eliminate any other possibilities, you can begin the treatment process. Create a mixture of baking soda and vinegar. Add 1/2 cup of baking soda to 2 cups of white distilled vinegar. 3Begin a wash cycle using the machine’s hottest setting. As the water rises, add the baking soda and vinegar mixture. Let the washing machine complete a full cycle. If you notice any residue that has been loosened, use a cloth to wipe the surface clean. Run a cold water cycle to complete the process. You should immediately notice that the smell has been neutralized.
Feb 09, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Scrud!
Try a descaling product, like ScalexPlus by Hillmark, through your unit.
It should help to clean the bowl out for you.
If the bowl is really caked with the scrud you may need to get an authorised service person to take the machine apart and use a high pressure hose to clean it off.
Oct 17, 2007 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
163 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
