Question about HP PSC 750 All-In-One InkJet Printer
The 750 printer has has a low voltage plug point on it what type of power pack is this and whats the voltage where can it be obtained? we have the printer but we will be needing the power supply to opperate.
  • 2,272 Answers
You can buy the required adapter from any local printer repair shop.This printers adapter is easily available with them. You can also order this adapter from online site. to see how the adapter exactly looks for your printer.please click on the link below :--- http://www.ioffer.com/i/2880-power-supply-ADAPTER-HP-PSC-720-500-280-printer-104058987 ----------- Also if you require any other part for your printer then click on the another link below:-- http://www.partshere.com/hppartslist/hpparts.asp?part=c8424a --------- also this link sells the adapter http://www.nevershopping.com/ns017296.html ------------ Thanks. Keep updated for any more query. You can rate thissolution and show your appreciation.
Posted on Jul 29, 2010
Timing mechanism not working
Copy following link for power pack troubleshoot resources:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
-set power pack to ON and plug power pack into cheap wall timer
-take apart motor and clean gears, and add white grease
-use 5-year warranty coverage
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 08, 2013 | Intermatic Inc. ML121RT Malibu Low Voltage...
Power cord
this model has a 110v or 220v power supply built into it.
Make Sure it the matching required voltage on its case if you plug 220v power point into a 110v rated power supply inside the laptop it will let out lots of smoke and stop working !
The part number is 255135-AA1
USA ? https://www.ebay.com/p/3-Prong-18awg-AC-Mickey-Mouse-NEMA-5-15p-to-C5-Laptop-Power-Cable-Cord-15-Feet/1348595046?iid=252155340421
or
https://www.amazon.com/yan-3-Prong-18AWG-Mickey-Laptop/dp/B0722GF9DB
suggest search on
3 Prong 18awg AC Mickey Mouse NEMA 5-15p to C5 Laptop Power Cable Cord
Nov 26, 2017 | Compaq Armada 1700 Notebook
I just replace a light (not bulb) in my Malibu low voltage lighting system. That new light did not work and now all of the rest of the lights past this point no longer work. But the lights between this...
Working with the bulbs can cause other bulbs to go out.
Malibu suggests turn power pack off when replacing bulbs.
Also connections get loose and need to be re-attached.
Open following link for Intermatic/Malibu power pack resources.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 29, 2011 | Malibu Intermatic Inc. ML121RT Low...
I NEED A REPLACEMENT TIMER (PB912M10).
1.remove timer from power pack. this includes all wiring to timer and switch.
2. buy a timer at Home depot.
3. plug power pack into timer,
4. reattach low voltage output wires to garden lighting system or whatever you use the low voltage for.
this is the second time I had to do this remedy. the timer that comes with the power pack really stinks!
Feb 08, 2011 | Malibu ML600TW - Low Voltage Power Pack -...
Unit was working fine today. I was repairing some connections in the landscape lighting cables and checking each connection after completing it. At one point, I was testing the lighting and got nothing. ...
The power pack should make a humming sound when ON
1) Maybe power to the plug is off
Plug hair dryer into plug and see if it works
Check your GFCI resets in bathroom and kitchen
Check breaker in box
2) Maybe time of day needs to be set
Unplug power pack > plug back in > set on-off trippers
Rotate dial counterclockwise to present time
Then rotate dial two complete revolutions and return to present time
Malibu homepage
Malibu manuals
How to select power pack: # of lights and length of wire
Oct 10, 2010 | Malibu ML200RT - Low Voltage Power Pack...
No spark runns fine then loses spark wait 10 minutes starts
The spark plugs receives power to spark from coil pack.Check the power at the coil pack and also check the voltage at the coil pack with meter.If the coil pack shows proper power as well as voltage then its fault in spark plugs.Otherwise its faulty coil pack.The coil pack receives power from battery.so also check the voltage of the battery it should be exact 12 volt.
If the battery shows low voltage then the battery needs to be re-charged.
Then check out.
Thanks. you can rate this solution and show your appreciation.
May 20, 2010 | 1992 Pontiac Bonneville
HP PSC 750 All-In-One InkJet Printer Logo
88 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
