Question about Intertherm P3RA-048K Air Conditioner
Im not getting enough cold air in my house to keep it cool during the day my air runs 24/7 but it remains hot the only time it cools down is at night
    President:
  • 1,515 Answers
Hi, I will give you some things you can do as far as some service on this unit. What happens, is when the ambient temperature rises, so does the internal freon pressures in the system which in turn, causes the unit to work much harder and at a 95f degree ambient temperature, most all residential units loose up to 45 to 50% of there efficiency!! This is a fact. Then you walk into a shopping center and its over 100 plus outside and a nice 72degrees inside, so you start wondering why my unit is not that cool. Well, being a A/C, Heating, & Refrigeration Contractor for 33 years, I know what goes on. Most all home units as I say are made to work good up to about 95 degrees ambient. This is for a 2 to 5 ton unit. 1 ton of cooling is 12,000 btu's, while on the roof of these shopping centers and strip malls they have 15, 25, 75, and even higher tonnage units!! So back to yours, I just wanted you to learn a little about the size and tonnage of a unit. You can do this first. It's showing you have a complete package unit, all in one not a split. I don't know when the last time you had it serviced but, take your garden hose, kill the power to the unit first. Go to the unit and the wrap around coil give it a good washing out. They make a coil cleaner but you have to be a contractor to buy it. Water will be fine. This should be done once a year in the Spring. Careful not to bend the aluminum fins flat on this coil, but do clean it very well. Dirt is drawn in by the condenser fan motor on top. Start washing from the fan area out first, and go around the outside and wash in. Do this until you see no more dirt, as this is very important. This keeps the high head pressures down to normal in your system, and if its dirty you can lower this high side pressure up to 100 p.s.i. The unit is made for outdoors, so don't worry about getting it wet. Try not to spray water on the main electrical box of course. Keep your filter cleaned or changed as this is also very important. Here is a rule of thumb I will tell you about air conditioning temperature you will know. If you can, pick you up a dial or digital type pocket thermometer at a hardware store, and take these readings at the supply air vents,1 or 2 of them and record it, and at the return air which is where the air returns back through your air filter. This is called your temperature split, or TD (temperature difference). If your unit is running properly as far as freon charge and so on, it should be between 18f to 25f degree difference!! Any higher or lower indicates a problem, low on freon, compressor valves are weak, plugged evaporator coil or dirty filter, many things, dirty condenser coil. Check this before you wash out your coil and let it run and dry out first, and recheck to see what you have. Your unit runs 24/7 trying to capture the load and can't keep up. May be do to age, or just needs some TLCare. So again, the TD check, lets say your supply air coming in is 58*F. Your return should be close to 76*F to 83*f, a 18 to 25*F degree difference. 18*F to 20*F would be awesome, but this is the rule of thumb we use. If it's 105* outside, you will be lucky to have a indoor temperature of 80*F!! A 25* difference. If after recording all of your temperatures and noting them, cleaning the condenser coil and making sure the filter is clean, after the unit runs for 1/2 an hour, recheck the sa&r/a and see what you have. If the coil was very dirty, this may have solved your problem. If after all of this, you may need to have your freon level checked, lets hope not. I have a feeling that it is in need of a good service. Please keep me posted on this, and I am sorry for such a long answer, but I just wanted to share some things with you to remember. Please get back to me to let me know the out come and please rate me kindly as I know you will.
Sincerely,
Shastalaker7
Posted on Jul 29, 2010
    Scholar:
  • 66 Answers
First thing to try is cleaning everything. Use a garden hose and spray out the coils on the outside unit. Make sure there is not anything blocking the air. next clean the evaporator coils and filter. After cleaning watch the inside a coil with unit running. Does it have condensate all the way to the top? If not you may need to adjust the refrigerant.
Why can't I lower my honeywell 8500 below 67 on cool?
With a two story house you have to be aware that cold air flows downwards so any cold air coming from an ac unit will flow downstairs( normally down the stairway) so unless you can close off the down stairs then the up stairs unit will be cooling downstairs as well. Ac units have a thermostat located in the air intake and it cools until the cold air has risen to that point. In effect the space above the ac unit will be hotter than the floor. Knowing how they work ,you can see that the upstairs unit will never reach the set temperature because the cold air is continually heating from the house and will never get to the top thermostat.
So your solutions are
1-- fit controls that restrict the cold air from leaving the upper floor (Doors)
2--don't run the upper ac unit unless you are living up there (waste of money
)3 place an ac in each upper room and keep the room door closed
Aug 12, 2014 | Heating & Cooling
Tip
How to Keep House Cool Without Using Air Conditioning
The expense of running the air conditioner is just too much. You open the house doors and windows up to try to cool the house down. But the house just seems to get hotter. Maybe you are going about it all wrong.
Here is a way for many people to have their houses cooler without running the air conditioner at all. Now I live in an area of the United States that has many cool nights even in the summer time. And I have found that this works very well for me. This will not work for everyone in every climate all the time but for a great many people at certain times of the year and under the right conditions they can save a ton of money with a minimal amount of effort and fore thought.
The trick to this is to cool your house off at night and then trap the cool air in the house during the daytime. When the sun goes down and it starts to cool off outside, open up all the windows and the doors too if that is practical where you live. Let them open all night long, even if the temperatures get rather cool over night. The idea is to get the house to cool down as much as possible.
Hopefully by morning your house is very nice and cool. Now before the sun has time to warm the air temperatures close your house up as tight as if it were wintertime. Try to limit the traffic in and out of the doors if possible. The idea now is to conserve the trapped cool air inside of the house. By doing this you will have a nice cool house all day long until evening when you do it all over again.
The best thing about this process is that is does not cost you anything. A bit of time spent opening and shutting doors and windows could save you a bundle on your electric bill. The process seems like it would not work that well but once you try it and see the results you will love the savings!
on Dec 06, 2009 | Heating & Cooling
What should I do in order to make sure my dog house stays cool in the summer?
In order to keep your dog's house cool during hot summer days, consider to do the following:
  • Place the dog house in the shade so it doesn't get too hot from the sun.
  • Make sure that the house is ventilated so warm air can come out.
  • If it gets really hot inside the house, you should put a fan to cool the house down or buy a small air conditioning unit made for dog houses.
  • Place a cooling mat on the ground of the house. This will help the dog to cool down during the hot summer days.
Oct 25, 2012 | Dogs
SPLIT AC CONDENSER TRIPS AFTER 1 OR 2 MINS, ONLY DURING THE DAY TIME
The condensor is not cooling fast enough. Try cleaning the condensor coil. Also check that the fan goes on. At night the outside temperature is cooler and does not need much work to cool down the condensor.
Jul 15, 2012 | Haier Heating & Cooling
The Cool mode wont cool. It's just like fan mode. I cleaned all the dust off the panels and still wont blow cool air.
First the weather is extremely hot mid 90's and humid.I have a Trane combination a/c heat pump system. The A/C was pumping out warm air.I called for a technician and the problem was the compressor was not working.The solution/fix was to replace compressor start capacitor.The technician was here for about an hour.The compressor was running before he left however I informed him the air coming out of the a/c ducts after one hour of run time did not feel as cool as usual. It took from 1pm until 10 pm at night to cool the house air down to 80 degrees and the system ran constantly.I left it on 80 as that is where I usually leave it. Today again it is running all day barely able to keep the house at 80.My home was built in 07 block house, well insulated with thermal double pane insulated windows.I suggested to the tech to check the refrigerant level but he did not think it necessary and did not perform the check while here. The unit will cool the house down to 80 degrees but runs constantly.My question is: Should I have a technician come check out the system to insure proper refrigerant levels and pressure????????
Jul 30, 2011 | Haier HWR06XC6 Wall/Window Air Conditioner
Our carrier air conditioner failed to cool down the house last night. changed the filter and still struggling to cool house down.
is it cooling some at night but none during the day basically ? Outside unit clean also ? Good airflow ? if yes on all of these feel the copper pipes that go inside the house from the outside and once a/c has been on for a few minutes the large line should be very cool or cold to where it would condensate.. Sometimes it may take up to 15 minutes..
Aug 20, 2010 | Carrier 38CKC024 Air Conditioner
My fans keep turning after i turn my car off
the coolings fans are designed to run for a little while to dispense heat they dont do it all the time turn usually during higher hot days w/ac on or higher hot days goes off automatically
Jun 10, 2010 | 2001 Chevrolet Impala
What causes my fridge to run hot? It thinks its an oven! It was working fine prior to transportation, after which it was left for three hour prior to switching on when it ran hot.
I believe it may have been laid down during transport. Leave it unplugged for another 24 hours and allow the compressor oil to return back down to the compressor. This is a very common problem if laid down on side during transport. After this time replug the power cord and listen and feel to insure warm air blows from bottom of refrigerator and cold air in freezer. The oil is to thick and heavy to be pushed through the capillary tube. Just be patient and not try to push the time getting it to cool again as the compressor will continue to overheat if oil remains in the cap tube. Thanks Sea Breeze
Mar 12, 2010 | Maytag MSD2454G Side by Side Refrigerator
Day / Night HVAC is running cool air BUT the furnace is running 2
Strange. Does the thermostat control both the air conditioning units and the furnace. If not make sure the furnace thermostat is turned down to below 65 degrees.
Jun 29, 2009 | Honeywell Programmable Thermostat Heater
Intertherm P3RA-048K Air Conditioner Logo
488 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
