Question about GE WDSR2080D Top Load Washer
Ge model lat9304aae fills with water timer roates but nothing else happens
    President:
  • 2,468 Answers
Either a bad timer or a lid safety switch is bad
Posted on Jul 29, 2010
Dishwasher won't fill on start
Check the following to address this issue.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 18, 2009 | GE 24 in. GSD2220Z Built-in Dishwasher
GE Potscrubber Dishwasher Stuck on Cycles
Could be a defective cycle timer
Jan 30, 2018 | GE Dishwashers
No water going inside, but water to dishwasher fine
If it is supposed to be the filling cycle and you have no voltage to the water fill soleniod then a timer contact is not making connection or there is no voltage to the timer relay. Fix it!
May 07, 2009 | Dishwashers
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
GE TOP LOAD WASHER DOES NOT AGITATE OR SPIN
ck lid switch can be acessed by pressing clips at front edge of front anel and pulling panel off
Nov 20, 2008 | GE WWSE5200B Top Load Washer
Washer fills with water , then shuts off , doesn't move to another cycle
Since you know about the lid and check switches, they are located under the splash (control)panel. unplug the machine and remove the screws holding the panel on. Using a meter check the switches for continuity and replace if they've gone bad.
Jun 06, 2007 | Maytag Neptune MAH5500B Front Load Washer
Dishwasher Does Not Cycle
IA, these GE pumps have a habit of sticking if the unit hasn't been run for a while. First you want to verify that the motor is in fact getting power, this will eliminate the timer. You can use a meter on the quik connect from the motor while in the wash cycle. If the motor is getting power, see if the pump is stuck by turning the motor vanes (Do this with the power off). If it's hard to turn and then frees up than this was more than likley your problem. You remove the bottom toe panel and will be able to check this out without removing the dishwasher. Catriver..post back
Dec 29, 2006 | GE 24 in. GSD2230Z Built-in Dishwasher
GE WDSR2080D Top Load Washer Logo
89 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
