Question about Watches
Replacement glass for cerruti watch
Replacement glass for cerruti 1881 chronograph wrist watch
5 Suggested Answers
Noggin
  • 944 Answers
SOURCE: Rolex Daytona Wrist Watch
Try these guys for a manual; http://www.timemerchants.com/catalog.htm They have the 2000 daytona manual and several older ones available. Otherwise try your local Rolex dealer; http://www.rolex.com/en/collection/rolex-gallery/cosmograph-daytona/specification.jsp#/en/xml/inside-rolex/sales-service/affiliates/index Hope this helps :)
Posted on May 16, 2007
SOURCE: crack face glass
good after noon ! if you want to repair your watch can you bring here in my own watch center ,the exact address is ,MEDRANO WATCH and CELLPHONE CENTER located at b.laqui st.brgy.3 cuenca batangas philippines,thank you ! GOD BLESS !
Posted on Aug 29, 2008
bobint17
  • 270 Answers
SOURCE: Replacement glass for my Fossil ES9439 Wrist watch?
go to an autherised survice center and they can do it.
Posted on Feb 03, 2009
matt2414
  • 247 Answers
SOURCE: how can i clear a foggy wrist watch glass?
Try WARMING,not heating it with a hair dryer,but be careful not to overheat. If it gets too hot,it will distort the watch face.
Posted on Mar 26, 2010
How to switch 12 hour from 24 hour in cerruti 1881 digital watch
Hold down the C for about 2 seconds (set Hold) will appear and the time offset valve will flash on the display. Press B twice to display the screen for selecting 12-hour or 24-hour timekeeping. Press D to select (12-hour) timekeeping.
Note: The PM indicator appears between noon and 11:59 PM. After all the settings are the way you want Press C to exit the setting screen.
Jun 27, 2017 | Cerruti Watches
My cerruti watch always stop at 11:30
It sounds as if the watch has taken a knock, and the hands are no longer properly aligned (that is, no longer at right angles to the stem, so that they rise up and down with respect to the watch face as they rotate, and typically try to 'cross' at a particular time of day).
If this is the case you might be able to see it if you first pull out the winder to the time adjustment position, then look closely across the watch face as you rotate the winder.
If I'm right, it's not a big job to correct it, but not one for the enthusiastic amateur. If you value your watch then take it to a reputable watch repairer.
I hope this helps.
Oct 04, 2016 | Cerruti 1881 Watch
I am looking for a leather watch strap for cerruti 1881 grande classico uomo. Where can I find such a watch strap?
I am looking for a leather strap for Movado Vizio 1881. Where can I get such strap?
Aug 18, 2013 | Cerruti 1881 Watch
How to adjust day?
If the day is in a window next to the date, pull the crown out one position to the same position used for the date correction. Often turning one way changes the date, turning the other direction changes the day. If your day is on a small dial on the watch dial then pull the crown out two clicks and go around 24 hours at a time and you will see the day advance.
Dec 18, 2011 | Cerruti 1881 Watch
Cerruti watch strap cannot be changed in any watch specialists in middlesbrough and i am just wondering where i will be able to get it done
You probably will have to send it away to get sorted (make sure you send it insured and very well protected).
You should contact cerruti to see who the repair shop is in the UK, (not sure they have one.)
Failing that you may be able to buy a replacement strap of ebay and have a general watch shop change strap for you.
Or find a jewellers that sell straps, they should have one that fits.
Please dont forget to vote if you liked my answer
thanks
Feb 09, 2011 | Cerruti 1881 Watch
I cannot get my Seiko SNA304 chronograph second hand to reset after battery change. Keeps resetting to the 17 minute position, I have tried to use the manual instructions but with no success, Any help...
Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
  • THE CROWN
Pull the button on the side of the watch carefully, the crown, out to its most extended position. You will need to unlock the crown if your watch has a locking crown. To unlock, turn the crown counter clockwise. While the crown is pulled out in the setting position, the watch will cease functioning.
  • 12 O'CLOCK POSITION
Turn the crown clockwise to move the hands of the watch past the 12 o'clock position on the dial. The day and date will change to indicate AM setting but will not change for PM setting. It is recommended that you set a Seiko watch in the morning for instant day and date setting; however,this can be done manually.
  • FINISH
To finish setting the time, simply push the crown until it is flush with the side of the watch.
Good luck and thanks for using fixya.
Dec 18, 2010 | Seiko SNA304 Wrist Watch
Watch is working fine but the chronograph is not
sounds like it needs to be serviced under warranty. The clutch mechanism maybe jammed or broken.
Apr 26, 2010 | Sector 2653940025 Wrist Watch
Need instructions for chronograph wrist Watch
Follow this link:
http://www.raymond-weil.com/EN/Swiss_Watch_Company/Instructions_for_Use.html
Rate me, please.
Mar 27, 2009 | Watches
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
