Question about HP Photosmart M447 Digital Camera
Hello, I have the following problem: I cannot delete images neither take new pictures. When i try to delete pictures it shows the following message: The card is locked, unlock the card to access delete features. When i try to take a new picture it shows the following message: LENS ERROR Try turning the camera off and on again (before this message it says card locked). Thanks for help!!!
    Brigadier General:
  • 11,967 Answers
Unlock the card by moving the slide switch on the side of the card. Solve your lens problem with these: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 29, 2010
How can recover the deleted pictures in picasa
When you delete photos or folders using Picasa, they are sent to the Recycle Bin (Windows) or Trash (Mac). If you have not emptied this paper, follow these steps to recover your photos:
Windows:
Double-click the Recycle Bin on your desktop computer.
Click your right mouse button on the file you want to retrieve.
Select Restore.
Mac:
Click the trash icon.
Find an image or folder you want to recover and drag to the desired location.
Keep in mind that
Picasa is an application that acts as a photo organizer and editor. It does not store the image files, but simply accesses them when the user wishes to either view or edit the file
Hope this helps (remember to rating this answer, and leaving some testimonial comment.
Oct 08, 2011 | Global Star Software Picasa for PC
How to delete pictures on my L20
For deleting pictures on your Nikon Coolpix L20 please follow the instructions below.
1. Highlight the picture you want to delete on the monitor.
2. Press the delete button ( button on right bottom of LCD monitor having a symbol of an open basket )
3. A window showing YES or NO for erasing the image is displayed on the monitor
4. Use the multi selector switch ( UP OR DOWN) to select YES
5. Press OK
This will delete the picture.To exit without deleting the picture choose NO and press OK.
Jun 19, 2011 | Nikon COOLPIX L20 Digital Camera
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Cameras
Hello, i took some pictures a few days back, but theres some problem while retreiving some of the images....the image for the particular pictures having problem shows a blue blank screen with file...
Best way is to download the pictures to a computer through a card reader (optional). The blue blank screen could be deleted images using the garbage can icon. Retrieving those images can be done but it cost to have a recovery program used and there is no grantee that the images can be extracted because the card my have been written over or formatted. Once you have your images saved to a computer the memory card should be loaded bak into the camera and the memory card formatted to give a clean working surface for the camera to write new files to.
Dec 28, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Pictures hidden on Samsung S1075
Simply go into the camera menu and find "format"...follow the on-screen instructions to completely erase the card.
May 21, 2010 | Samsung S1050 Digital Camera
How do I recover images that I accidently deleted?
Yes, with a good image recovery software like asoftech photo recovery, it will be an easy job to recover deleted images from camera's memory card. follow the instructions here
http://www.asoftech.com/articles/how-to-recover-deleted-photos-from-camera.html
Dec 19, 2009 | Canon PowerShot A550 Digital Camera
Display imges and photoshare
Please follow below steps,
Login your yahoo messenger then click on your displey image ....then click Select (in Share my picture)
Image#1
now another box will open named as My Pictures, Delete all the pictures showing here one by one....
Image#2
after deleting all pictures now click on Browse....it will take you to pictures location where you saved pictures....
Image#3
select a picture or image from there and click Open then proceed with all OK...hope this you can do it easliy...Thanks for being with Fixya.....Good Luck..
Nov 18, 2009 | Yahoo Messenger
Format of sd card on canon ixus 60 lost pictures
Try PC Inspector "Smart Recovery" from the following listing. Select "Intensive" mode from the File/Settings menu. The program may need to run all night in this mode. If this doesn't recover the photos, am afraid then that they're permanently gone.
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
Jan 11, 2009 | Cameras
My Nikon L4 camera ..I can't figure out how to Delete all the pictures.
Power on your camera. Press the playback button (bottom left with right arrow in a box) to display a picture. Press the Menu button (top left) to get to the playback menu. Scroll down to the Delete selection and press OK. This will show another screen with a choice for Erase all images. Choose this and press OK. - done! -Vish
May 03, 2007 | Nikon Coolpix 4200 Digital Camera
HP Photosmart M447 Digital Camera Logo
51 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
