Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
How to adjust the mowing deck properly? - Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
    New Friend:
  • 14 Answers
I use a string level just sit it on deck level front to back
Posted on Feb 21, 2015
    New Friend:
What is the proper way to adjust the deck height on a gravely pro stance 52" fixed deck? Should it be level or pitched to front ?
Posted on Jul 31, 2014
  • Craftsman Master
  • 8,404 Answers
Find a level surface (concrete garage floor for example) ... adjust front to back ... use a tape meadure to mneasure floor to deck edge ... then adjust side to side.
Posted on Jul 29, 2010
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
How to adjust mowing deck to mow field and why is my-right side lower then left side deck
you should be able to see adjustments under mower . without any idea what you have for mower its hard to say
but you can start by making sure tires are inflated equally
Sep 27, 2015 | Garden
Mowing lower on right side than the left
Loosen the adjuster on one side of the deck and level off the deck and retighten. This should be done on top of a solid surface so u get it perfectly parallel to the ground.
Aug 30, 2015 | Husqvarna YTH22V46 46" 22HP Lawn Tractor...
Clutch adjustment for engaging dec
You clutch is probably OK. This sounds like some binding in the mowing deck.
  1. Take off the deck.
  2. Clean the underside of the mowing deck.
  3. Remove the belt and be sure all the moving parts move freely. If something is bound, try to free it up with oil.
  4. Replace any bound up bearings. Bearing are a very high maintenance item on a mowing deck.
Good luck.
Apr 05, 2015 | Garden
How do you level the mowing deck?
There should be an adjustment on both sides of the deck. Move the nut up or down to raise of lower it.
Jul 03, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Ariens raise deck
the arms to the deck are adjustable or the wheel fittings will be adjustable
indications are that the cutter deck is either down at the front or the back where it should be level
Jan 28, 2018 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
408 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
