Question about Diesel Watch Style # DZ7006 Watch for Men
How to disable week alarm on Diesel watch type DZ7142
Hi, my Diesel watch type is DZ7142. There is a funktion called "week alarm". It´s a daily reminder for every day of the week in a specific time. I want to disable this alarm, but I tried everything and the alarm is still activated. In the manual there is not a word about switching off this kind of repeating alarm. Can you help me?
2 Suggested Answers
  • 79 Answers
SOURCE: Diesel DZ7069 watch - how do I set the correct date/time?
ok ,here it is .
Instructions To Set The Time On The Diesel DZ7071 Watch
Ok the first and most important thing to know about this watch is that it has an unusual timezone function (unusual to me at least). This allows the watch to display two different times. Time 1 (or T1) is the primary time (the time of the place where you spend most of your time!). The time can only be adjusted whilst the watch is in the T1 mode (T1 should be displayed in the bottom left corner of the screen). Holding down the top right button for one or two seconds will temporarily replace the current T1 time with the T2 time. Holding down this same button for several seconds will toggle the current time mode to T2 and the watch will continue to function in the second time zone until you toggle it back to T1.
The second most important thing to know is that you can only set the time whilst in the T1 mode. When in T1 mode hold down the top left button until the watch enters the settings menu (it should say "Light" at the top of the screen) now use the bottom left button to toggle through the settings menu until you get to the time settings. I think this part of the process if sufficiently straight forward so I'm not going to go into more details here, all I'll add is that once you have the watch set to the desired time mode 12h/24h time and date you just need to press the top left button to save the settings and return to the main time screen.
To set a secondary timezone time you have to first toggle the watch to the secondary time zone mode (hold the top right button for several seconds and the T1 indicator should change to T2 (and the watch will now be displaying the time that is currently set for the secondary timezone). This time is based on the primary time by simply telling the watch a number of whole hours ahead or behind the primary time. To adjust this hold down the top left button for several seconds, the watch will then say "offset" now use the buttons on the right to add or subtract hours from the primary time. Once set press the top left button again to return to the main time screen. Finally hold down the top right button for several seconds once more to return the watch to the T1 mode.
Posted on May 15, 2009
How do I unhide alarms 2 and 3?
Set multiple alarms. If any alarm is active,(picture of alarm hear) appears in time display A. Press MODE repeatedly until ALARM appears, followed by ALM1. Press STOP/RESET to select Alarm to set. B. Press SET/RECALL to set alarm. HOURS digits will flash. Press +/- to change HOURS. C. Press NEXT and +/- to set MINUTES, AM or PM (if primary time display is in 12-hour format), DAILY, WKDAYS, WKENDS, or day of the week (weekly alarm). D. Press DONE to exit. E. Press +/- to set different Alarm. Set as above. F. In Alarm mode, press START/SPLIT to turn Alarm ON or OFF. TIP: Alarms apply to selected Time Zone of watch display. Backup Alarm sounds after 5 minutes if no button is pressed. Turning off any Alarm or backup will not affect other alarms. http://assets.timex.com/user_guides/W191_M131/W191_M131_NA_EN.pdf
Dec 01, 2015 | Timex Sports Ironman Triathlon 100-Lap...
On the casio a158w how do I turn off the hourly chime? Thank-you
Hi Ms. Sophie Desro,
If the alarm has sounded, press "A" (top left-hand button) to stop the sound.
To switch the Daily and Hourly Time Signal on and off:
Press "C" (lower right-hand button) while in alarm mode in sequence:
a. }}}} + BELL = Both alarms on.
b. Display Blank = Both OFF.
c. }}}} = Daily alarm on only.
d. BELL = Hourly Time Signal on only.
Test the alarm by holding down "C" to sound the alarm.
Please note b. and c. to turn off the alarms.
For more information, Casio has an Operational Chart for your watch, Module QW-1275. You may download a PDF file here:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1275.pdf
Try this and let me know if this works. Thanks.
Regards, Bill
Sep 16, 2010 | Casio DW290 1V Classic Alarm Chronograph...
I have a Casio 50M. I can't stop the alarm function. It seems to beep when it wants to. This watch has the REM feature. Help !!!
Hi trapmanjohn,
Man what an aggravating problem! Try this procedure.
1. To turn the daily alarm and time signal on and off:
2. In the Alarm mode, press "B" , upper right button, to cycle throught the on and off settings as follows:
Alarm on Indicator/Hourly Time Signal On Indicator
a. }}}} with Bell = Both alarms on
b. Display Blank = Both alarms OFF
d. Bell = Hourly time signal on only
The Alarm ( }}}} ) indicator flashes while the alarm is sounding.
The Alarm ( }}}} ) indicator and hourly time signal on BELL indicator are displayed in all modes.
To Test The Alarm: In Alarm Mode, hold down the "B" to sound the alarm.
Your Module number is #3171. Down an Operation Guide for the 3171 from here for more clarity:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3171.pdf
This should help you with nuisance...Good luck.
Regards, Bill
Sep 08, 2010 | Watches
Can't turn off the alarm on a timex Expedition Watch
buy a Casio wrist watch at KMart for around $17.00. They last five years, then the
band breaks and you buy a new watch. I timed the traffic signal system of our city for 20 years from a Casio wrist watch. Now in retirement, I have a Time Expedition which has several alarms which I do not need, and can't turn off. We change the time twice annually, so having alarms and chimes go off without warning ca bve a nuisance.I found some instructions on a website which shows how to turn the alarms off.
Jun 02, 2010 | Timex T41091 Expedition Watch
An alarm sounds every hour. How do I disable the alarm?
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please .
Apr 19, 2010 | Diesel Digital Dz7069 watch
Seiko chronological alarm watch
I looked at the Seiko web site and found only one of the listed watches was described as a "chronometer" and that one did not have a daily alarm.
To review the instructions, go to "seiko.com", then "support" and click on "instruction booklets".
There is a diagram showing where the information is that should be entered to give the instructions you need.
Alternatively, below the diagram is a list of watches which you may be able to find your watch .
Feb 16, 2010 | Watches
Hi i have an alarm clock digital it is called an ascot by kripplwatches the serial number is... po5623 type .. hsd110b it is only a cheap thing but i like it and can not fiind instruction manual can you...
to set the time: switch to timedisplay and hold the "S" key for three seconds, then adjust with the arrow key´s
to set the date: same prcedure as time but first switch to the date display
Jan 03, 2010 | Watches
Diesel DZ7076 beeps every hour
Press all the buttons at the same time. It's so annoying...
Jul 22, 2009 | Diesel Audio Diesel Watch
Casio Illuminator
I used the online CASIO web site to locate the appropriate manual and followed directions. Use the bottom left (C) button of the watch to keep pressing between the various modes until I was in the ALARM Mode. Then PRESS the upper right (B) button to toggle the DAILY ALARM and HOURLY CHIME to "OFF", "DAILY", "HOURLY" and "BOTH" on/off.
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1950.pdf
http://support.casio.com/manual.php?rgn=1&cid=002
Jan 17, 2008 | Casio W94HF-3AV Wrist Watch
Diesel Watch Style # DZ7006 Watch for Men Logo
551 people viewed this question
Top Diesel Watches Experts
Ansel Alberto
Ansel Alberto
randymanfive
Are you a Diesel Watch Expert? Answer questions, earn points and help others
