Question about Lite On LiteOn LH-20A1P - Disk drive - DVD±RW (±R DL) / DVD-RAM - 20x/20x/12x - IDE - in Burner
My multi dvd writer door opens every time I insert a disk it opens by itself
  • 108 Answers
Check for loose contact, dry solder at the power connector end, try cleaning the lens, most of the times the rubber belt that is used to drive the tray gets loosened due to time factor and usage
Posted on Jul 29, 2010
I have supermulti dvd writter but they not read some times for same dvd disk
the dvd writer must be old or lens may have moister. So try to use lens cleaner or change the writer.
it may be beacuse of one more reasons DVD you are using must have lot of scratches.
Jan 02, 2011 | LG Super-Multi GSA-4163B 16x8x16x DVD+R/RW...
How to format disk
When you recorded the Disk - you should see an option in the writer softer to finalise the disk - often disk are left open to add more information - called multi-session
have a look at the options page for the burner software you have , see if you have finalise or to unselect multi-session.
If you comment back on what software you are using to burn the Disks - I can see if i can find the option
Apr 01, 2010 | Philips DVDR3380/05 DVD Recorder
I have a Lite-On DVD writer that will not open unless disk is in.
The problem is with ur DVD Writer Tray, Some of the reason ur dvd writer tray get jammed. For the temporary purpose you can use the manual eject pin hole Technique.
Nov 07, 2009 | Computers & Internet
Cd/dvd burner will only recognise blank cd discs not blank dvd discs
Find some "older" blank DVD-R, or DVD+R, or DVD-RW disks, and insert them.
If they are recognized, then access LG's web-site,
and look for a downloadable "firmware update" for your model.
The newer firmware adds support for "newer" DVD media.
If all else fails, replace the CD/DVD device.
Nov 06, 2009 | LG GMA-4020B Super-Multi...
CAN NOT READ SONY DVD-RW 1.4 GB DISK FROM COMPUTER DVD WRITER
your dvd has scratches on it. See if it is visible then it can not be repaired
Oct 03, 2009 | Sony Mini DVD-RW 1.4GB 30 minute ( 8cm - 3...
HOW TO GET NERO7 TO BURN ON DVD +RW
probably you are interested in making a multi-session disk using Nero ...yep ..there is a way ...the only thing after you choose the files to burn ,the device ..( dvd writer ) ...name teh project ...and look that at some point there is a case to be checked and allow you to burn multi -session data disk ...this means that the disk will be able to be used again for the space that remain ....
if you are talking about the re - writable disk ...this is simple ..any RW disk ..can be deleted using Nero ...the feature its on the lower on the session window ...its says something like "more " and it offers information about the disk you inserted...and the possibility to erase it ...I believe that this is the exactly used word...erase disk (feature) ..
Sep 15, 2009 | Computers & Internet
Dvd external trouble : i have dvd lightscribe supermulti DVD RW, hardware can operated normally, i can hear souding from drive motor wen inserted a disk, but next appear box contain Please Insert a Disk,...
there ll be a lens in dvd writer which ll be corrupted and disk ll rotate properly even if lens of the dvd writer is spolied...
u hv said u hv warranty right do register for a replacement of the dvd disk
Jul 09, 2009 | Computers & Internet
My LG multi dvd writer lightscribe tray wont open. the green light is steady. no matter how many times i try to eject the tray ang it wont open. there is dvd+r inside.
use a unfolded paperclip and insert it into a small hole below the disc tray. This is the manual eject port. Stick it straight in and push, a little bit of pressure will be needed.
Apr 20, 2009 | LG Super-Multi GSA-4163B 16x8x16x DVD+R/RW...
Lite On LiteOn LH-20A1P - Disk drive - DVD±RW (±R DL) / DVD-RAM - 20x/20x/12x - IDE - in Burner Logo
70 people viewed this question
Top Lite On Computers & Internet Experts
Rommel Balcita
Gbenga
Alun Cox
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
