Question about Kenmore Refrigerators
Model 106.57789704 - ice wont release into door bin
Kenmore Model 106.57789704 side-by-side - ice won't release into door bin. there is frozen ice in the ice maker. little red light is blinking by the on/off switch inside freezer when door is open. we had power failure a few days ago (in case that matters), but I don't see a Power Outage Reset button on our model.Thank you!
  • Kenmore Master
  • 3,740 Answers
This probably is not what you wanted to hear but... I recommend you to the human manual defrost method to free things up as a result of the ice that built up post power failure. That somewhat messy method being:
1. Unplug the unit.
2. Remove Freezer contents (You do not need to empty fresh food contents)
3. Place a fan blowing into the freezer section for around 2 hours. (Messy part so be ready to tend to the drips with rags & mop)
AFTER 2 HOURS
4. Take a rag or sponge and remove most of the water out of the ice maker as best as you can after the manual defrost.
5. Completely empty the ice bin of all ice or water paying particular attention to the auger making sure there is no ice at all in the auger.
6. Plug in the unit.
7. Reload Freezer contents.
This should get things back to normal. If not there is much more that can be attempted. At this time I really believe that the above procedures will normalize your unit. If and when you need more assistance just respond here I and I will gladly assist you.
Thanks for choosing FixYa.
Kelly
Posted on Jul 29, 2010
Kenmore refrig model # 10645423801 cannot remove ice storage bin
Could it be frozen in? If so, u may have bad door seal or ice door seal is not shutting properly.
Nov 04, 2017 | Kenmore Refrigerators
My refrigerator won't dispense ice cubes or crushed ice or water at the front door, I was wondering if it could be the Touch pad control panel on the front of the refrigerator. If it is can you give...
The front touch pad board /panel which you are referring is called dispenser board.To access the dispenser board assembly, click this link below:---
http://howtobyme.blogspot.com/2011/06/ge-side-by-side-refrigerator-will-not.html ------------ The dispenser board removal procedure is mentioned at the last on the link instructions.-------- -------------- But the engineer at your place has pointed you to right direction.The main control board is most probably the cause of problem.One more important thing.There are many other users too facing same problem with there ge side by side refrigerators.This problem occurs in many ge model refrigerators. There was service letter released by Ge for this problem.Click this link, to read the letter:--- http://howtobyme.blogspot.com/2011/07/ge-side-by-side-refrigerator-wont.html -----------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 28, 2011 | Refrigerators
Ice guide seems to be broken, how can i remove the cover to access on mod. ed22tqxfnoo.. what will it take to replace it ?? t
I have a Whirlpool side-side freezer-refrigerator model ED22TQXFNOO. When I try to use the ice dispenser in the door. nothing happens. No noise as if the motor is turning the spiral gear to push the ice to the end of the storage bin so the ice will drop in the shute to be dispensed. I cleaned out the storage bin for any build up of frozen chucks of ice. The storage bin is all the way in. There's plenty of ice, but it won't dispense.
(1) Is there a Micro switch in the lever I push to signal the motor to turn?
(2) What inergizes the switch in the back that lifts the bar to let the ice fall into the ice dispenser?
Nov 29, 2010 | Whirlpool Refrigerators
The part where you would press to get ice, well up in side is not releasing the ice and closing back
On mine, using crushed ice will cuase a build up of ice along the shoot. I take off the storage bin and manually open the door cleanining out the shoot. Make sure to check under the removed storage bin before replacing.
Aug 30, 2010 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Ice Dispenser clogged with frozen ice
I have the same problem. Found this posting:
http://www.applianceblog.com/mainforums/sears-kenmore/10491-kenmore-ice-maker-dispenser-door-shute-clogging-missing-heating-element.html
Maybe our heater is not working?
Jul 05, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
I have a GE side by side fridge. Model # GSH22VGRBWW It does not make ice. We was purchasing bagged ice and putting it in the ice dispenser tray and we could get ice now it will not release the ice. You...
Remove the ice bin,with the freezer door open ,press the pin switch at the top of the door opening, then press the ice dispenser ...if the forks on the auger motor rotate its ok... if they dont the motor is frozen
Jun 28, 2009 | Refrigerators
Ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Mar 23, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Refrigerators Logo
258 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
