Question about Canon SELPHY CP740 InkJet Photo Printer
My canon selphy printer is always said to me no ink and insert a cassettee but i am insert a new cassette but no solved in this problems what i do
3 Suggested Answers
  • 127 Answers
SOURCE: Color ink cassette stuck in canon selphy
I doubt very much that you need to reset the printer, or, even if you did, that this would make much difference. It sounds as if there is a menu item which you should be able to bring up on the display which then allows you to release and extract the cartridge. I have scoured the web for information on this one and Canon, naturally, only supply the software, not the manual. If you have a manual can you look up and quote the relevant bit in it which deals with changing the cartridge? If there is nothing there which says that you have to go to a menu item to release it then it sounds like a mechanical problem - as in 'needs a bit of a yank'. I'll keep looking.
Posted on Jul 10, 2009
SOURCE: CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7...
paper size is incorect
Posted on Oct 12, 2010
My ink cartridge is stuck. I tried to turn it off and on again and to push the paper leveler down but nothing helps.
My Canon Selphy CP740 start to jam ink ribbon and ink - Fixya
www.fixya.com/support/t10013530-canon_selphy_cp740_start
Jan 4, 2013 - My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. ... Question about Canon SELPHYCP740 InkJet Photo Printer .... SOURCE: CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7.
Selphy CP740 - Catridge Eject Solution - YouTube
? 0:46
https://www.youtube.com/watch?v=9TqHINBmbgQ
Sep 11, 2013 - Uploaded by Mahadhir Shaarani
Selphy CP740 - Catridge Eject Solution. Mahadhir Shaarani ...Replacing Ink for Canon Selphy - Duration: 6:23. Jenuine Crafts... How to Print Different Sizes with the Canon Selphy Printer - Duration: 12:08. Janet Wakeland ...
Color ink cassette stuck in canon selphy 'Canon SELPHY ...
Feb 03, 2016 | Canon Selphy Cp800 Compact Photo Printer -...
I have a Selphy 710 that I've seldom used. Now when I insert a new ink cartridge, it cycles to the end and error box says "Ink cassette is empty and must be replaced." I've replaced the...
I'm having the same exact problem with my CP730. The paper size and ink cartridge are the same size. I've tried two new ink cartridges, same result. Frustrating and expensive.
Mar 09, 2011 | Canon SELPHY CP710 Thermal Photo Printer
I have the paper in and replaced ink carr. and it is saying no paper or cassette incorrectly inserted
try to see if there is a paper jam.
If not try putting the paper back in and pushing it up against the back so it fits snug.
Also try taking the ink out and putting it back in.
Feb 22, 2011 | Canon SELPHY CP760 PHOTO Thermal PRINTER
The ink cartridge will not eject. It's stuck inside the printer.
Canon Selphy CP800. I had a cartridge ribbon break when it stuck to some photo paper I was trying to reuse and the cartridge became stuck and would not release. All you have to do is try to print a dummy print, the printer will then display that the ink cartridge needs replacing, it will then allow the cartridge to pop out when the release catch is operated. Beware of broken and torn ribbon inside the printer and try to remove the obvious loose pieces before inserting the new cartridge. Any remaining bits of ribbon should stick to the next photo you try to print but a ruined photo is a small price to pay as your printer should work ok once the debris is cleared. If you are adventurous you can dismantle the cartridge by inserting a small flat screwdriver into the retaining clips at each end of the cartridge cover. remove the used ribbon from the spool as it is only stuck onto the spool spindle. Re thread the unused ribbon onto the spool ensuring it travels round the deflecting spindle which is easily prised out and replaced over the ribbon. You must ensure that the new ribbon is wound onto the spool in the correct direction (check this by comparing the rotation with good cartridge by ensuring the ribbon tightens as it should) then wind the ribbon forward until the black line appears on the clear sheet of ribbon and carry on printing.
Dec 19, 2010 | Canon Selphy CP510 Thermal Photo Printer
I insert ink cassete into it"s selphy cp780 photo
Go to section on Error Messages at page 32 of the User Guide found at:
http://gdlp01.c-wss.com/gds/0/0300002060/02/SELPHYCP780_PUG_EN_03.pdf
It will tell you to remove and reinstall the ink cassette. Try this and make sure you install correctly as per instructions on page 11 of the User Guide.
If this does not resolve the problem, do a complete power down of the printer. Turn off and unplug from the power supply. Lets rest fro a few minutes and then plug back in to the power supply and if necessary turn on power. This should allow your printer to reset and hopefully recognize that a new ink cassette has been installed.
Trust this helps. Please vote. :)
Dec 17, 2010 | Canon Office Equipment & Supplies
I had to completely unscrew and disassemble the printer then cut or break the piece of plastic from the removable ink cassette that was blocking it from being removed. See attached pic.1_3_2013_5_05_41_pm.jpg
May 18, 2010 | Canon SELPHY CP760 PHOTO Thermal PRINTER
Please help!!! My ink came out through my printer with the picture... how do i get the ink cassette out? it is jamed..
Kindly open the cover of your printer or the cover at the back of your printer then make sure that the printer is on. Then wait the ink holder will stop moving and automatically stop in the center of the printer (if inkjet printer) then remove the ink cassette or if it is laser or toner then just remove the ink cassette automatically after you open the cover of the printer. Also to have more information kindly referto your printer manual to have more step by step instructions in removing and installing new ink cassette.
Thanks
Jul 31, 2009 | Canon SELPHY CP760 PHOTO Thermal PRINTER
Jul 08, 2009 | Canon SELPHY CP740 InkJet Photo Printer
Canon SELPHY CP740 InkJet Photo Printer Logo
1,983 people viewed this question
old marine
old marine
