Question about Ricoh Aficio 1085 Laser Printer
SC547 How do i resolve a SC547 on aficio 1085?
    Problem Solver:
  • 5 Answers
Try to replace power supply
Posted on Oct 19, 2008
Help with error code SC547-01
sc 547 mean fixing unit error ,you can reset by simply getting into simulation mode and then switch off an the machine ,getting into the simulation mode is simply by pressing 107 and press and hold c ,
Jun 19, 2013 | Ricoh Aficio 450 Copier
Ricoh afico 811 error sc689 and sc547
sc547 is a power supply error that can mean you have a faulty power supply. The service manual does not list an sc689, and it's not in the help desk support database either... are you sure that's the code that comes on the screen?
Oct 05, 2010 | Ricoh Aficio SP C811DN-DL Printer
Eror sc547
The error sc 547 refers to a "Zero cross signal malfunction".
This means that the applied power supply AC frequency was detected at over 66Hz or below 45Hz, and the zero cross signals are not detected within a certain period within 500 ms after the main power switch has been turned on.
Possible causes are:
- Power supply board defective
- IOCSS defective
- BICU defective
Try to reset the SC code by entering SP5810 and select 1.
Then hold down the photo mode key and the # key at the same time for at least 3 second.
Then turn the machine off and on again.
If the same issue still appears, try to replace the Power Supply Unit.
Jul 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Error sc547 aficio 180
Heat up failure in fuser area. Have tech check thermofuse and thirmistor for signs of wear or dirty
Jan 12, 2010 | Ricoh Aficio 150 Copier
I want download the engine firmware ricoh aficio 850 1085 105e
When I can download the firmware cicu / bcu 8.1 by ricoh aficio 1085?
Mar 27, 2009 | Ricoh Aficio 450 Copier
Use as a scanner .... How to ?
you must first connect scanner interface drive board
Jan 22, 2009 | Ricoh Aficio 1085 Laser Printer
How do i resolve a sc520 on aficio 1085?
this is a duplex jogger error prob, open up your printer and ensure that the duplex assy is completely fastened onto the machine, any loosed connection can trigger an error, pull and push back the unit duplex once again to reset it, make sure this is sitting correctly and close the machine.
if not there is too much load on the jogger mechanism w/c make it so hard for the unit to initialize, then this will also occur check for any mechanical binding, if not then there is no choice but to change the jogger motor
cheers
Nov 30, 2008 | Ricoh Aficio 1085 Laser Printer
Aficio 1085 - fuser
you need to cheack your electricty source must be 220 ~ 240
Press clear modes, 1, 0, 7, and press and hold clear/stop/ Enter copy sp
and off and on the power. If something in the fuser is bad, it will do it again. If it comes to ready, then the thermister is probably dirty
Apr 29, 2008 | Ricoh Aficio 1085 Laser Printer
SC547
Press clear modes, 1, 0, 7, and press and hold the clear/stop key. Enter copy sp. Select mode (5), and scroll to 5810 if it exists, and execute. exit back to the copy sp screen. Press data log (7), and scroll to 7807, and execure. Exit all the way back out to the SC547 screen. Turn the power switch off and on. Not the button on the control panel, but the actual switch. If it comes to ready, great, if not, there is somethong wrong with the fuser.
Apr 24, 2008 | Ricoh Aficio 1085 Laser Printer
Ricoh Aficio 1085 Laser Printer Logo
455 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
