Question about RCA 20F511T TV
The Picture is black half way down the screen. It is staying like that.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
You simply replace electrolit condensator / elco in the vertical, ranging from 1uf/50v, 100uf/35V, 220uf/50Volt, 1000uf/50volt. elco among those already damaged. because it had dried the liquid electrolyte. to know which part of the vertical, you can check the PCB board. there is usually an area of vertical writing. or known from the IC vertical (standing) stuck to the aluminum cooling plate / heat sink. Part code to elco, with the inscription C. for example C231 etc. Hopefully helpful.
Posted on Jul 29, 2010
    Problem Solver:
  • 12 Answers
You have a problem in the vertical section of tv, take your fist and hit the top of the tv, if it flickers or fills out you have loose solder joints which is common in that model, if not you need a tv repairman. not to expensive to repair normally
Can you help me , my Apple iPad screen only shows half the screen . Can you help me ?
Loose connection internally or moisture...try putting it in a bag of rice
Jul 04, 2014 | Apple Ipad I-pad
Half screen is blank 42lg20 or 42lg50 when
This is likely to be the T-con board. If the entire screen glows but you have no picture on the second half of the screen then it is the main board, not the backlight inverter. If the screen is half picture and half gray it is the T-con board.
Replacement of one of the above will fix the issue.
Please rate if this helped :)
Mar 07, 2011 | LG 42LC2D 42 in. LCD HDTV
Sound stays on, but no picture- goes black and stays that way.
This unit should still be under warranty and should be taken in for warranty service. Any attempt to access the interior will void the warranty. It is important that a complete description of the problem like you entered here be taken along when you bring the set in for service. This will insure that the servicer be able to reproduce the problem and resolve it.
From your description (and as a servicer), I would be looking for a component that is heat sensitive. These types of problems are fairly easy to locate and resolve.
Please take this in for warranty service and update this when you find out the details.
Thanks,
Dan
May 04, 2010 | JVC LT-26C31 26 in. LCD Television
I am having a problem with my picture on the top
NEED REPLACED SU BOARD Manufacturer Panasonic Part Number TXNSU1HNTU Description PC BOARD
Feb 17, 2010 | Panasonic TH-42PX75U 42 in. Plasma...
Plasma only showing half picture
This is beyond consumer ability to repair. Please have it looked at by a qualified electronics service company.
Nov 23, 2009 | Panasonic Televison & Video
Half of the screen is black; picture only on the right side of the screen.
your tv has one the Y buffers defective.which half is black,the botton or the top? i believe that you have to call the repairman .
good luck
May 21, 2009 | HP PL4260N 42 in. Plasma HDTV
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
X1a powers on, then video dies
Check whether the menu comes on the Screen. then check the DMD circuit.
Jun 04, 2007 | InFocus X1A Multimedia Projector
Top half of screen black
The vertical circuit is going bad,this is the one in charge of opening the picture up and down,try taping on the side to see if the picture reacts ,if it does your set has a loose conection and the vertical IC will need to be resoldered only but if it does not react the IC will have to be replaced,if you are familiar with tv service this will give you a place to start but if you are not be safe and seek the help of a servicer,please let Us know how it goes.
Oct 11, 2006 | Sony KV-XA34M66 34" TV
RCA 20F511T TV Logo
101 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
