Question about Sony Handycam DCR-TRV30E Mini DV Digital Camcorder
I have sony handycam video 8 model CCDTR350E and i have removed the viewfinder to use elsewhere. the viewfinder has only 4 cables coming out, 1 white, 3 grey. any idea on how to find with is the video signal, + - and voltage and current for whole apparatus?
SOURCE: How do I hook up a Sony Handycam Video 8 CCD-TRV41 NTSC to view on television?
I still have my CCD-TRV41 and the manual intack. You will just need a audio/video cable (2-colored or 3-colored) to view your movies.
Posted on Sep 09, 2008
SOURCE: how to transfer video from a sony handycam 105e to a pc
I solved the problem by searching the internet until I found the programme that fixed my problem.
Posted on Nov 16, 2008
welcomejee
  • 10594 Answers
SOURCE: i am having a sony hi 8 ccd trv 58 model handycam.
CCD-TRV58 is analog camcorder and can not be connected with computer directly as camcorder does not have USB or iLink/ DV ports.
Computer needs digital format movie data to store / edit files.
You need to hook camcorder audio-video out to DVD recorder and burn DVD of camcorder movie so you will get digital format of movie. Put that DVD in computer and copy files for further process.
Posted on Apr 19, 2009
SOURCE: I have a Sony Handycam DCR-TRV720 Digital-8
This model has iLink: IEEE 1394 firewire port. If you don't have a firewire card, you can probably find one pretty cheap on the internet (try ebay).
Windows has movie maker, which when the camera is connected, will allow you to capture the video from the camera on the comptuer, although there is no DVD burner software at least on the XP version (not sure about Vista). I use Nero for the whole process: capture, edit, burn to DVD.
Posted on Sep 17, 2009
SOURCE: how to save videos from sony handycam to my home pc
you need to put the camera into playback mode
then go into the menu and go to the setup menu
Then USB streaming and turn it on
That should enable the computer to recognize the camera
Posted on Dec 31, 2009
Where i get cable to connect my dell vostro 1015 firewire port to sony dcr-trv22e handycam
You can get these cables at electronics stores like Radio Shack or online from sites like Amazon.
http://www.amazon.co.uk/Firewire-Cable-IEEE-1394-1-8M/dp/B000747OIK/ref=sr_1_4?ie=UTF8&qid=1307019621&sr=8-4
Be sure to get the proper cable as they come in 4-pin to 4-pin or 4-pin to 6-pin. Check the ports on the dell for 4 or 6 pin.
Jun 02, 2011 | Sony Handycam DCR-TRV22E Mini DV Digital...
My handycam screen is blank and doesn't show anything
Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record.
NOTES:
* Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
* It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
1. Ensure the lens cap on the front of the camcorder has been removed.
2. Ensure a fully-charged battery is inserted in the camcorder.
3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
4. Turn on the camcorder and set it to the CAMERA mode.
5. Look to see if an image can be seen in the viewfinder or LCD.
IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
6. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshooting steps, service may be required .
Dec 23, 2010 | Sony Handycam DCR-HC40E Mini DV Digital...
Sony 8 MM HaNDYCAM PROBLEM
Yes It Is Possible.
1. Cable options you can use S-video or RCA.
2. VHS payer that has a recording option. Make sure that it supports the Sony Handycam 8mm.
3. The procedure on how to transfer the 8mm to VHS is the same as how you view your video on the TV.
4. S-video or RCA should be connected on the Handycam and the other end is on the TV.
5. You can follow the instruction on page 27 (Sony Handycam CCD-TRV37)
6. You can also follow page 52 (Sony Handycam CCD-TRV37 )
Go to this Link for the user manual and the full instraction on how to connect the cables.
http://www.derrybryson.com/manuals/Sony/Analog%20-%208mm%20&%20Hi8%20Camcorders/CCD-TRV57.pdf
Apr 03, 2010 | Sony Handycam CCD-TRV37 Camcorder
HANDYCAM USE
Go to any Sony dealer ask for NP-33 battery pack for your CAM
Cheers
Dec 08, 2008 | Sony Handycam CCD-TRV416 8mm Analog...
Sony Handycam Video 8 tr66
If camera has svideo connector you could get a cable and try that for better quality.good luck John
Nov 07, 2008 | Sony Handycam CCD-TR66 Camcorder
Rolling of picture
You camera is PAL and you are attaching with Ntsc TV or VCR. Both Pal and Ntsc are different systems and incompatible to each other.
If you want to see correct playback of your Camera, it requires Pal or Multi-System color TV.
Need further info, please let me know.
Oct 04, 2008 | Sony Handycam CCD-TRV68 Camcorder
Sony handycam dcr-pc300/330
Make sure the batteries are fully charged. It may be your batteries may show they are charged but are too leak to operate the camera. Try a new one
Apr 07, 2008 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam issue - repair/replace?
im assuming the ccd is bad call sony they have to replace a ribbon cable.
The problem is a bad CCD inside the camera. I Sony was providing free service for some of their other models but failed to provide service (recall) on these models. contact Sony at 1-866-703-7669
Feb 07, 2008 | Sony Handycam DCR-TRV740E Digital...
Sony Handycam DCR-HC36 wont playback on TV
if the sound is coming out on tv then the video cable has to be replaced. (You did not tell if the sound is coming out on tv)
Jun 25, 2007 | Sony Handycam DCR-HC36 Mini DV Digital...
Sony Handycam DCR-TRV30E Mini DV Digital Camcorder Logo
129 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
