Question about Kenmore Elite 45986 Front Load Washer
I have a Kenmore front loader model # 417.40042990. My husband had to remove the drum from the back. Now how do you get the gasket and spring mounted back onto the front?
  • 209 Answers
SOURCE: front loader washing machine = black streaks on clothing
I am a recently retired engineer of 20 years once you have ruled out anything getting inside the machine by accident etc, like something in pockets or greasy overalls, then its likely to be the drum bearings, has the machine started to get noisy on the spin the drum bearings are covered by a rubber seal, this seal gets damaged or worn and water leaks into the bearings themselves washing out the grease back into the drum where the washing is, you could also notice slight water marks on the floor underneath the machine on the floor, take the back off and look for water marks coming from the drum outer casing behind the pulley, these marks will be brown and will originate from a small drain hole, if any of the above change the bearings before any real damage is done, either to the clothes or the machine, as repair can be expensive? sorry, hope i have helped you as to where to look at least,
Posted on Sep 19, 2007
jsrock516
  • 5911 Answers
SOURCE: replacing spring wire on kenmore front loader HE 2
This is often a very tricky process. The easiest way I know how to get the inner spring back in place is to use two sets of hands and work through the door and through the bottom panel as well. Follow these steps:
1. Remove the lower panel under the door.
2. One person reach through the door opening and insert the spring in the bellow groove, starting at the top.
3. Work the spring around to the 3 and 9 o'clock positions and hold in place by keeping your fingers on the spring in the groove.
4. Have a second person, laying on their back, reach through the bottom panel and grab the lower half of the spring on each side with both hands.
5. While the first person holds the upper portion in place, the second person pulls straight down and works the remaining portion of the spring in place.
This is the best way, I have been able to accomplish this. Make sure you use a type of applaince adhesive to reseat the outer portion of the bellow to the door frame if this is the glue on type. If you have questions, or require additional assistance, please let me know.
Posted on Jan 16, 2009
  • 109 Answers
SOURCE: Kenmore model #417 40042990 Front Load Washer is
I would firstly take the back cover off and check the belt has not come off. Then check that the drain pump is not blocked.
Posted on Jun 16, 2009
erpaalai
  • 999 Answers
SOURCE: I am trying to replace a belt on a kenmore 417
No. Just roll it on
Eric
Posted on Jun 26, 2009
  • 1937 Answers
SOURCE: what size drum on a kenomre 417-43052200 washer
This may or may not help but I'd check both the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=417.43052200+
and the users manual:
http://www.managemyhome.com//mmh/lis_pdf/OWNM/L0212203.pdf
Posted on Oct 25, 2009
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Kenmore Model 417.4414200 - during the spin cycle, there is a very loud knocking noise. I tried redistributing the load thinking that it was out of balance, that did not correct the problem. I am able to...
Could be drum bearing Front loader or a broken spring. If a lot of drum Play then its bearing fault quite a big job/Expensive, consult an engineer if in doubt...
Apr 01, 2011 | Kenmore Washing Machines
I have a kenmore front loader Model #11047512601 Type 832 and it will not wring out the clothes proberly I have an f code can you tell us what is wrong please.
An f21 code indicates that there is something blocking the drainage system. could be something clogging it like mine did. My problem was a washcloth stuck within the drain. My fix was to remove front panel below door using a 1/4" driver to remove 3 screws. You will need a 5 gallon bucket, towels to soak up water, and a pair of channel lock or large pliers to remove drain cap. let remaining water drain into bucket. remove large spring clamp holding rubber boot to drum housing and check to see if anything is in there. that was my fix. good luck
Nov 20, 2010 | Kenmore Elite 45986 Front Load Washer
Front dor seal has a tear in at at the bottom. It leaks as soon a
you will need to remove front panel 2 screws at bottom behind kickpanel removed with one screw next to filter cap one more screw behind soap draw ,then remove steel spring clamp holding door seal to outer cover push seal into drum so as not in your way pull down front panel it will then come towards you remove door lock connection and lift away fromt panel this will expose drum front there is another spring clamp on back edge of seal remove this and pull away seal reverse procedure to refit new one may need some detergent on back of seal to make refitting easier.
Feb 04, 2010 | Bosch Axxis WFL 2060 Front Load Washer
How to instruction on replacing felt gasket in the
easy, get some high temp adhesive before opening up.
then if lint screen on top, remove screws under cover, pull top forward and lift. it hinges in rear. remove 2 screws on front holding front panel to cabinet sides. disco door sw and lift front panel up to remove. undo belt from motor , note setup with spring roller.
if lint screen in door, remove contrl console, screws under end caps(pop off frame end caps from top). remove screws at rear of top holding it to rear panel. and slide forward. to remove. remove lower kick panel (use putty knife, hidden clips in seam), remove screws holding air duct to blower housing, disco wires to moisture bars at connector. remove screws holding front panel to cabinet, then at top and remove panel remove springs if necessary. pull tensioner away from belt and remove belt.
lift drum up and out. note gasket flange orientation and pull off. clean and sand off old as well as possible and apply glue to drum as you apply new gasket, it will be tight at end.
Apr 27, 2009 | Kenmore 63942 Dryer
Replace door gasket
It sounds like you have left the spring on the inside lip of the door opening when you removed the old seal,
You will have to take the seal off again and feel for the spring on the lip of the front of the drum, you will find it easier if you have something to hook it out with,it is fiddley, but you must get the spring out, or the seal will not stay on
Refit seal as before, and double it back inside the drum,then fit the spring in the groove that you can feel on the lip of the door seal. Work the spring all the way rond feeding it into the groove as you go round, you will find it a lot easier if you have someone there to hold the spring as you are are fittingit, it is very fiddley, stick with it!!!.
Plz rate this solution .
Thanks.
Dec 19, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Kenmore Elite shaking during spin cycle
Moved a Kenmore Elite and when we put it back in place it vibrates loudly. We tried leveling it and that has not worked. Any ideas?
Sep 27, 2008 | Kenmore 24032\24036 Top Load Washer
Washer Tub Gasket
remove gasket from cabinet - just held onto cabinet by a simple clamp and fold gasket inside drum. this will give you enough room to access the retainer. you may find it easier to remove the top as well
Sep 09, 2008 | Whirlpool GHW9400 Front Load Washer
Front loader washing machine = black streaks on clothing
Sep 18, 2007 | Kenmore 46462 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
47 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
