Question about Sony Cybershot DSCW370 Digital Camera
Camera Lens Stuck Outside
I was taking photos all night but after I charged it I took 2 photos and the lens is now stuck outside and it tells me to power off then power back on, I have done this several times with nothing happening, as well as removed the battery and charged it and the lens is still stuck outside the camera.
    Problem Solver:
  • 12 Answers
Power on while pushing on the lens smack the bottom of camera on table top (half hard)
Posted on Jul 29, 2010
I was taking photos and evertime i took a photo i turned it off,(i was on a plane) and then went to turn it on again, and it opened then lens opener (two black things) and then beeps 2 times and turns...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success
Jan 20, 2011 | Samsung WB550 Digital Camera
My SAMSUNG TL100 CAMERA LENS STUCK OUT SIDE
It seems your camera Lens got stuck in open condition, This will happens due to two reason.
1) Either your camera battery got died or need to be recharged or replace.
or
2) Your camera is malfunctioning and need service (repair).
To resolve the problem. first check battery indicator on your camera, If battery indicator shows battery low, than you need to charge it or you need to replace your battery.
Follow the instruction to retract camera lens:-
1) Turn on your camera.
2) Press the Playback button on the back of your camera. The lens on your camera should retract.
If problem still not resolved then your device need to be serviced (Repair).
Rating the solution is highly appreciated...Good Luck.
Mar 04, 2010 | Samsung TL100 Digital Camera
The pictures I take outside are white.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 03, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Lens are stuck out. screen says "lens error"
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can not take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard for a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal. Make sure to clean the outside of the lense when fully open and keep it clean always. If this did not help, read 2.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inspect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on the camera and your camera would be back to normal.
Good luck!!!!!!
Jun 11, 2009 | Olympus FE-270 Digital Camera
Lens cover does not operate correctly
I fixed this problem on my Fuji FinePix A303 (though it took some hard work).
The problem:
Camera Lens Cover stuck open or stuck closed.
Power on, and get !LENS COVER error.
Lens fails to extend.
The solution:
Short answer: The motor driving the lens cover is weak and eventually breaks down. I manually open the cover now. This took a manual modification to the camera (and some work).
1. Take the camera apart. See here for details, and be careful around the flash, as you'll get a nasty shock otherwise! http://www.mathematik.uni-marburg.de/~haim/focuserr.htm
2. Once you can see this, you're just about there:
3. Take off the battery cover (in the picture above).
4. Wrap a wire around the sliding pin for the lens cover, and drill 2 small holes through the black structure underneath the battery case, and then to the outside. The wire goes from the pin to the outside via the two holes. You should be able to manually open and close the camera cover COMPLETELY now with the wire.
5. Reassemble the camera (actually, you can test that it's working when it's all apart, if you're careful).
6. To operate the camera now, close the shutter first while off. Power on the camera, and very soon after open the shutter all the way by pulling on the wire (from step 4). This basically mimics the action of the little lens cover motor. If you timed it right (you have about a second margin), the lens should extend and everything functions perfectly.
It would have been nice to have been able to simply buy a new motor, but that would probably be a pain and cost some money.
Hope this helps!
Matt Van Dyken.
http://mattvd.googlepages.com
Aug 16, 2008 | Cameras
How can i fix a stuck lens on a Nikon COOLPIX L11?
I have the same problem with my nikon coolpix s200. After 2 months the lens of my camera won't go inside. On the lcd screen stood lens error. I went to a shop with this problem. He took the battery out of my camera and press the off and on button for a while. Then he put the battery back in the camera and press the on button. The lens of the camera was now going inside en outside and inside and outside with a strange noise. And also on the screen stood lens error. Okey, the lens is inside the camera. But how can I fix this camera? What is the problem? What have you done? Please let know..!!
Jul 13, 2008 | Nikon COOLPIX S200 Digital Camera
I dropped my camara and lens is stuck on the outside
Dear pat123456,
If you dropped your camera and now the lens won't retract back into the camera, and it won't power on it sounds like you have internal damage. You need to have it looked at by an authorized service technician.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Apr 07, 2008 | HP Photosmart M425 Digital Camera
Casio camera lens stuck
hi
this is repairable u ask ur near servicecenter
Feb 18, 2008 | Casio Exilim EX-S500 Digital Camera
Olympus Camedia C5050 Zoom
The unusual beeps usually occur when the lens cannot be extended or retracted, often due to dirt in the gearing or the lens cap being left on.
Try using canned air to blow around the outside of the extension cylinder, and, putting a fresh set of batteries in the camera (it probably got stuck on since it couldn't fully retract the lens and didn't complete the shutdown).
If that doesn't work, try taking it to a camera store with repair technicians and having them take apart and clean the lens extension/retraction mechanism.
Aug 19, 2007 | Olympus Camedia C-350 Digital Camera
Lens is stuck out
push up on the inner lens housing,
Dec 24, 2006 | Kodak EasyShare LS753 Digital Camera
Sony Cybershot DSCW370 Digital Camera Logo
487 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
