Question about Canon iR 2016i Black and White Copier
Error f14 code
How to reset error code f14 in the toshiba e-studio 160 .
  • Canon Expert
  • 414 Answers
Press 08 simmilutery then 388 and enter
OR replace main board OR sram board
Posted on Feb 11, 2013
Showing error code F14 of estudio 225 toshiba machine. what should i do?
Hopefully you've turned it off and back on this illuminates many issues with a product that is more like a computer than a copier. Many of the hot section codes are F then 3 digits if you're not warming up at all it probably will need a Toshiba tech to either reset the code after insuring it won't go into thermal meltdown(you don't want that;trust me) and or replace a safety fuse that saved your machine by blowing. either way does it try to warm up? or it won't let you do anything from minute 1? some times on the newer models the user manual gives at least a clue to the origins of codes thrown, ie. check side door, or close fuser cover panel...... hope it helps but a thrown code is just that something needs a looked at and if it's not real obvious maybe a good service call is what you need. hint: All Toshiba tech's are required to clean/vacuum and make sure the copies are acceptable,it might be be hove of you to get rid of a peskie line going down your copies or even a ugly paper jam when you do double sided copies. good luck! Ex-toshiba tech 23years..~~~~~>SC
Sep 12, 2014 | Toshiba E-Studio 223 Multifunction Copier
How to reset error code f14 in the toshiba e-studio 242
reset wile switch on press and hold '08' enter 690 press start enter 2 press enter key.
Sep 03, 2013 | Toshiba e-Studio 242 Duplex Copier w/ 36...
I HAVE ERROR CODE F14 IN MY TOSHIBA e-studio 166 how i can reset this code
Jun 08, 2011 | Toshiba e-STUDIO166 Printer
How to reset error code f14 in the photocopy machine toshiba e-studio 160
guys please help me how reset error code F14 for Toshiba copier model no. 167
Jul 29, 2010 | Toshiba E-Studio 160 All-In-One Laser...
Error F14 in my Toshiba e-studio 166
how to reset error code f14 in the toshiba e-studio 160
May 12, 2010 | Toshiba e-STUDIO166 Printer
Error code F14 ON DISPLAY FOLLOWING MASSAGE "CALL FOR SERVICE" SUGEST SOLUCTION FOR THIS CODE
F14 indicates invalid backup counter.
After cleared below counter, problem is solved.
*Method: Just enter 08 setting mode-->key in "388"-->press Start button. Repeat again for "389"
*After cleared the counter, it will also reset the network settings where we need to reconfigure.
Aug 25, 2009 | Toshiba e-Studio 205 Copier
My Toshiba e studio 167 is showing a c44 error code. What should I do?
the c44 error is an error in the fuser if you know how to take the fuser out check for toner buld up on the thermistors.. the sensors with the thin strip that presses against the hot roller gets toner build up and cant read temp properly.. you could also try turning machine off and then on whilst pressing 1 3 and * buttons together this might reset it temporarily for you.. Good Luck A
Jun 30, 2009 | Toshiba E-Studio167 Copier
When the message call for service is displayed
press the C key and the 8 key at the same time
an alpha numeric code will appear eg: C47 etc
Post the error code and I'll tell you what it means
Jan 19, 2008 | Toshiba E-Studio 160 All-In-One Laser...
Canon iR 2016i Black and White Copier Logo
386 people viewed this question
old marine
old marine
