Question about Pioneer A509R Amplifier
Pioneer A-509R amplifier: whenever I try to use it, the standby function cuts in and I cannot turn standby off. Your advice would be much appreciated! Thanks! edowenmadrid@gmail.com
  • Pioneer Master
  • 17,130 Answers
It is possible that your amplifier is cutting off the power due to a protection in the system. The output or power circuit could have a fault that trips off the protection circuit to worrk. now this is ttricky and might need a lot of power board electronics experience as the fault needs to be traced . You can disconnect the poweer drivers and see if the poweer come on. If so the drivers must be chacked for short and replaced. Check also the speakers for any short and disconnect and check. hope you try. Good day
Posted on Jul 30, 2010
I have a sony s-master digital amplifier which will not power up: when I plug it i to power it takes about 30 minutes before the red standby light comes on but no other functions operate.
So the standby indicator never changes state? If so, more than likely, your amplifier has DC Offset(a damaged amplifier inside) which will keep the speakers off, and disable any use of the front or remote functions. If you are interested in having your Sony repaired, please refer to my website, audioserviceclinic.com. You may contact me there. Thank you.
Jul 11, 2015 | Audio Players & Recorders
Speakers cut out
Add an external amplifier to the speakers and you will never have this problem again!
Sep 17, 2013 | Pioneer Audio Players & Recorders
Stereo amplifier remains in standby mode
You should be able to find a Universal remote that will cancel the standby function.
Mar 31, 2013 | Audio Players & Recorders
The outputs on my Pioneer GM-5300T are intermittent and low
yes they are perfect whenever I turn up the bass it just trips on and off
Feb 07, 2013 | Pioneer GM-5300T Car Audio Amplifier
My pioneer gm 5300t amp cuts off at loud volume and will not kick back on until it is turned down and cools off, what is wrong with it?
You are over heating it,You have your speakers wired up for a lower,(OHM) Rate then the amp can handle, That why it cut out when you have it turn up
Nov 10, 2012 | Pioneer GM-5300T Car Audio Amplifier
Everytime i turn my gain up my amp cuts in and out an the only way to keep constant bass is if i keep the gain on one
When you turn the gain up you are probably exceeding the maximum input for the amplifier.
Try adjusting it on the amplifier itself rather than from the head unit.
Mar 28, 2011 | Pioneer GM-510T Car Audio Amplifier
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
Pioneer vsx-604s power problem
Pete,
The problem is not likely to be the power supply, but shorted output transistors. If you do not see the standby light, then the problem is likely to be either an open standby transformer (primary) or perhaps the 5V regulator transistor. You have given very little info to go on here. Can you provide a little more info on what happens when you try to turn it on?
Thanks,
Dan
Nov 02, 2009 | Pioneer Audio Players & Recorders
Pioneer A509R Amplifier Logo
258 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
