Question about Sony KP-51HW40 51" Rear Projection Television
After the tv is on the picture starts going red until it turns totally red.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 132 Answers
It sounds like a bad crt on the red picture tube, but impossible to tell for sure w/out seeing it. These sony's have a lot of trouble w/ the tubes and crt's.That would be the first thing I would check. From the front of the set, you can gently tap the neck of the red pic. tube w/ the handle of a screwdriver while the set it on, and watch to see if the set flickers or if the red changes. You may want to let a tech take a look at it and give you an estimate. If this is the problem it will probably be fairly expensive to repair. You may be better off to get a new set.
Posted on Jul 29, 2010
LNT5265F when first turned on new, small red light came on, played a little tune, then picture came on. About 7 months ago, after the tune played the picture didn't come on, the red light would go...
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board...
If the capacitors is faulty your TV turn on after a lot of attempt until the TV is totally turn on...
In that case you need to replace the bad capacitors on the power supply..
How can you find where is the faulty capacitors? The bad capacitors is usually leak/bulged on top in that case you easily find it through visual check...
Sep 10, 2011 | Samsung Televison & Video
Hi i have lost instruction manual for my total remote urc 11-4110 b02 Universal Remote could you tell me how to code it to tv manually please
@font-face { font-family: "Cambria"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0cm 0cm 10pt; font-size: 12pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; } SET UP
TV
The Search Method
If your device does not respond to the TOTAL CONTROL after you have tried all the codes listed for your brand, try searching for your code. The Search Method allows you to find the code for your device by scanning through all the codes contained in the memory of the TOTAL CONTROL.
To search for your TV code:
1 Switch your television on (not on standby) and aim your TOTAL CONTROL at your TV.
2 Press the TV key on your TOTAL CONTROL.
3 Press and hold down SET UP until the red light blinks twice. (The red light will blink once and then twice)
4 Press 9 9 1. The red light will blink twice .
5 Now slowly, alternate between POWER and TV, over and over, until your television turns off. You may have to press these keys many times (up to 150!), so please be patient.Remember to keep pointing the TOTAL CONTROL at your television when you press these keys.
6 As soon as your television turns off, press SET UP.
The TOTAL CONTROL remote should now be ready to operate your device. Turn your device back on and try all the remote’s functions to ensure they are working
properly. If some of the TOTAL CONTROL’s commands are not operating correctly, try the search method again. You may be using the wrong code.
Once you have Set-Up your TOTAL CONTROL, you can blink back your SET-UP CODE for future reference.
Example: To blink out your Television code:
1 Press TV once.
2 Press and hold SET UP until the red light blinks twice (The red light will blink once and then twice).
3 Press 9 9 0. The red light will blink twice.
4 For the first digit of your four-digit code, press 1 and count all the red blinks. If there are no blinks, the digit is "0".
5 For the second digit, press 2 and count all the red blinks. If there are no blinks, the digit is "0".
6 For the third digit, press 3 and count all the red blinks.
7 For the fourth digit, press 4 and count all the red blinks. If there are no blinks, the digit is "0". Now you have your four-digit code.Make sure you write your Television code for easy future reference.
Aug 12, 2010 | Televison & Video
Red
Sorry, your red crt (picture tube) is bad, last time i called sony they were no longer available. Have your tv guy turn down the red drive on your screen control (inside the tv chassis , you should not do this !) it may stop the bright red for a while.
Jun 11, 2009 | Sony KP-61HS10 61" Rear Projection...
Green Screen
Hi, how is the cable box hooked up to the TV? Is it HDMI cable or componet (red/green/blue) ? When you say totally green, do you mean the the picture is only green with the other colors missing or every color looks green ?
Mar 14, 2009 | Protron PLTV-37 37 in. LCD Television
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Powers on by itself
TV worked FINE for the past 2 yrs---this morning we woke up and the screen is totally BLACK! No sound..nothing. REmote doesn't do anything to the TV. Red light says ON unless we unplug it. Remote won't turn off the TV.
Any advise? Picture tube??
Worked great w/out any problems until we woke up today!
Thanks,
Tina
Jun 01, 2008 | RCA 32V420T 32" TV
Red picture
Assuming this is a TV with a picture tube and not plasma or LCD; I'm afraid that your picture tube is dying on you one electron gun at a time. From what you said your green electron gun is almost totally dead and the two remaining blue & green guns aren't far behind. Eventually you'll have no picture at all and I would estimate that to be about 6 more months but whatever the time eventually it will go totally black. These blackout periods will get longer and longer. The only way to fix your problem is a new picture tube but my will probably find it less expensive to just get a brand new TV set.
Apr 14, 2008 | Toshiba 36A50 36" TV
Prima plasma 42
sir,,,kindly check out the chroma section,,,,,thnkss and hope too help you
Feb 01, 2008 | Televison & Video
Picture and sound disappeared
your red crt bulb is starting to go bad. somtimes you can tap lightly on the neck of the red and the prob. usually short term will go away. if not tube replacement is necessary. this is sometime a pricey repair. but worth it! john
Sep 08, 2007 | Akai PT4298HD Rear Projection Television
Sony KP-51HW40 51" Rear Projection Television Logo
63 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
