Question about Fargo HDP600 Thermal Printer
FARGO HDP600 motherboard failure
Upgrading firmware had damaged the printhead as well as the mainboard which shows logical problems.
Need to buy the printhead and fix the firmware problems.
2 Suggested Answers
andi_bunkka
  • 102 Answers
SOURCE: Fargo HDP600
Fargo drivers for this model does not work with 64 bits.
I recommend you install a virtual host so you can work with 32 bit and so you can use your software.
Posted on Apr 30, 2012
Error code 03130031-2618
It mean "Vh voltage error" and can be cause of short circuit in the printhead . Sometimes you can get good result with printhead changing, but it is not guarantied because of possible printer electric parts (carriage board, flat cable, motherboard or power supply) damage. For printhead changing, delete paper and use Service mode (hold Paper sourse + Information while switching printer on).
Apr 13, 2015 | Canon imagePROGRAF IPF710 Printer
I have a Fargo HDP 600 printer, when I turn it on it states, "Loading printer settings now, please wait... and it stays like that. Is there any way to reset this printer? Now its not recognizing the usb
Physically disconnecting the printer from its power source, then reconnecting will force a hard re-boot of the printer itself. If this fails, try updating the device drivers & firmware (download directly from the HID Global website here: Drivers Downloads ).
If you get no relief here, it may require service. BUT, as this printer is an older model and out of support, your best option may be a replacement unit.
Jan 05, 2015 | Fargo HDP600 Thermal Printer
Transfer film not installed Fargo HDP600 cr100
Double check to make sure the film is installed correctly. The printer senses a chip, located on the roll, to determine - Type, Amounts and Physical presence.
If this problem persists, go to HIDglobal.com. Under the Support tab, click Drivers & Downloads. Populate the drop down menus with make and model. From here you can view all the recent software versions.
Scroll to the bottom of the page, under Misc. Download the Fargo Workbench utility. This program enables you to automatically update firmware. It is also a very useful tool in diagnosing issues.
Sep 24, 2014 | Fargo HDP600 Thermal Printer
Why do I have a white line across the cards?
most likely, your printhead has a damaged pixel on that portion of the printhead. it would need to be replaced. If you need a printhead, i can get you a couple companies including myself.
thanks
Aug 30, 2014 | Fargo DTC525 ID Card Printer
What cause the Error hardware 03130031-2F49 ?
Problem :
For errors 2618, 2F48, 2F49, 2F50, 2F51, 2F52 randomly occurring please follow the steps below.
Solution :
If the printer has the latest firmware installed (Ver. 1.25 or higher - iPF8300 Series), you only need to do the following:
1. Check if the Status Print or Print INF files indicate which print head experienced the error and replace it.
2. If the specific print head failure cannot be determined, replace both print heads.
NOTE: With the previous low level firmware installed, any printhead damage may have spread to other components. Upgrading to the latest firmware version prevents the other components from being damaged in the future. For the initial failures with the low level firmware, you must replace the other components that would have also failed.
Jun 04, 2014 | Canon imagePROGRAF iPF9000 InkJet Printer
Printer head error
Try updating, or reloading, the printers firmware using the "Fargo Workbench application. it can be found (along with the firmware file) in the "Downloads and Drivers" section, in the Support tab on HIDglobal.com.
Print head errors come in a few ways. Some common issues i see are:
"Print head voltage error"
1. The wire harness, from head to pcb, is loose or damaged.
2. Print head is Damaged and needs replacement. Usually you will see dull lines going straight across your final prints, consistently.
"Head life error"
This error is primarily a mechanical failure. the belts that drive the head life motor have worn, and need replacement.
Apr 24, 2014 | Fargo DTC550 Thermal Card Printer
I have a Fargo HDP600 and cannot install it on windows 7 is there a way to do it.
if you are using the printer as plug and play just go to the add printer if the usb did not ditect it automatically you can add it prom add printer select your Fargo 600 and install and if you have any problem of printing you can right click on the printer properties and change the port to USB virtual port.
Mar 15, 2014 | Fargo HDP600 Thermal Printer
Usb device not recognezide for window xp
Needs drivers for unit. Installation software should load.
Aug 26, 2012 | Fargo HDP600 Thermal Printer
Fargo HDP600
Apr 30, 2012 | Fargo HDP600 Thermal Printer
I have read somewhere that the P4P-800E motherboard has incompatibilities with Windows 7 however the upgrade advisor showed no problem. Is this true.
you can install win7 but some hardware may not detect...you can fixed it by upgrading the bother board bios firmware..
but bios upgrading is case sensitive...
May 23, 2010 | ASUS P4P800 SE (890552603657) Motherboard
Fargo HDP600 Thermal Printer Logo
101 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Computer Links
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
