Question about Exercise & Fitness
My treadmill is a pro-form crosswalk 480 but it does not tun on. when i put the key it looks like everything its ok but the belt does not move i can select the speed or 1 of the 6 programs but it wont start. i checked the belt and it look new. in the circuit board i can see a red light on but the motor not start. when i press the start button i can hear some beeps but thats it. please gave me some advices thank you much.
    Brigadier General:
  • 3,917 Answers
Hi
You may have a bad lower board. We need to try a test.
Stand on the side of you treadmill and push the belt with one foot.
Push the start button and keep pushing the belt. If your treadmill belt starts to run, you may have bad motor brushes caused by a dirty or worn belt and deck.If it doesn’t start but the speed is being read then you could have a bad lower board.
A loose motor wire could do this too.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 29, 2010
How to remove dust cover from pro-form crosswalk 480 treadmill
go to website of the manufacturer
www.iconservice.com
Nov 08, 2013 | Exercise & Fitness
Pro-Form Crosswalk 395 - Incline goes up and down with no tread movement. Calibration doesn't work - only on display.
test the main board, with the output voltage from board for input voltage motor. If there are NOT voltage the board is faulty.replace see the block diagram, how the main boad control about 80% of the machine motion.
God bless you
Sep 29, 2012 | Proform Crosswalk 395 Treadmill
Pro-form 370e crosswalk treadmill when the start button is pushed it starts up then stops immediately.
1)Lube the deck belt, this a problem by lack of maintenance, this produce enough friction and shut down the machine, by protecting the electronic system.
2) Test the input voltage motor, if there are voltage, the motor need repair.
3) Test the output voltage board, for input voltage motor, if there are NOT voltage the board is faulty.
God bless you
May 15, 2012 | Proform 370E Treadmill Walking Belt
My pro-form crosswalk 397 the track will not work. The lights display and it makes a sound but the track stays in place. I bought this on Black Friday and have only used it 3 times. Help!
INMEDIATELY LUBE the deck belt, maybe is WORN. and adjust the roller bearing see the diagram attached.
2) Test the input voltage motor, if there are the motor need repair.
sincerely. God bless you
Apr 23, 2012 | Proform Crosswalk 397 Treadmill
Pro form 780 cs console does not respond
Dear Sir:
Thank you by your request. I hope everything is fine in union with your family.
Now I will help you inmediately.
Please do the following:
ercupa190.jpgSchematic for Reed Switch
Thank you in advance, sincerely. God bless you.
If you need further assistance, please contact us.
E.CUADRA MANAGUA, NICARAGUA. C.A.
Sep 27, 2011 | Proform 780 CrossWalk Treadmill with...
I own a pro form Crosswalk model 405 and the instructions were lost in a move. How can I obtain a new copy?
This is probably not your ideal solution but just in case it is helpful here is a list of the models of the proform crosswalk 405, if you select your exact version you can purchase a new owner's manual.
Jul 20, 2011 | Proform CrossTrainer Treadmill
Jerky treadmill
Please check out this tip I wrote. Please let me know if you need anymore help.
Apr 08, 2010 | Proform Crosswalk 500 Treadmill
How to do you adjust the belt on a Pro form crosswalk 380? The belt is getting loose and I lost the manual.
To adjust the belt: Less Belt Tension: turn both adjustment bolts on back of treadmill in a counter-clockwise direction. More Belt Tension: Turn both adjustment bolts equally in a clockwise direction. Center Adjustment (moves belt center to the left): Turn left-side adjustment bolt counter-clockwise. Center Adjustment (moves belt center to the right): Turn the left-side adjustment bolt clockwise.
An over tightened walking belt can raise the amp draw of your treadmill, contribute to seam separation on the walking belt, or both, so do not over tighten the walking belt.
You should be able to lift the belt in the center on the side by approximately 2” to 3”, if you cannot lift it by 2” to 3”, the belt is too tight.
Feb 20, 2010 | Proform 730 Folding Treadmill Model...
Exercise & Fitness Logo
121 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
