Question about Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television
Help unlock my Tv ,samsung SP42Q2HL 42 in. S/ 42013HDX60223K HDTV Plasma Television
I have this samsung 42" projectile color tv, my kids were playing with the remote and accendentially lock the channels on display, now i cant search the TV as it is lock with a symbol of a locked padluck coming up when i try to search it,i want to no how i can unlock it.
Thanks.
victor
  • Anonymous May 02, 2009
    how to i unlock my samsung lcd tv 26 inch
SOURCE: 43" samsung rear projection hdtv SP43W6HD 1080i
you have a bulb gone i have the same problem
Posted on Mar 02, 2011
SOURCE: samsung tv
as far as it turning off on its own I would get a fan on it and see if that make a difference make sure that the fan is able to flow around the tv especially through the back of it, if this stops it from turning off then it is an overheating problem
Posted on Mar 24, 2008
chrispurs1
  • 372 Answers
SOURCE: I have a samsung sp42q2hl,
Hi.
Use component to connect this will give yu HD picture,
On the back of the set you will see A group of 5 phono sockets Blue, Green, Red, These carry picture,
Then Red, White, these carry stereo sound.
Component video improves the picture quality even more by not only separating the color from the black-and-white portions of the picture but by further splitting the color information into two color-difference signals. When the picture signal is split up in this way, you get an unfiltered, uninterrupted image, with better resolution and greatly improved color saturation. And this is why component video is the predominant method of hookup from HDTV set-top decoders to HDTVs.
So this is how your set can produce HD picture from Hd source.
http://dysonmanuals.llc.nu/
Posted on Jun 22, 2008
97F350diesel
  • 1326 Answers
SOURCE: cant find component 1 on samsung tv
Use your input/source select button. Should display input 1,2,3,4 comp 1, comp2 etc in order then repeat. Make sure your using the correct component input. Most sets have 2. Turn on the device first so you'll know your there when you see the picture
Posted on Aug 06, 2009
eddiepeezy
  • 130 Answers
SOURCE: 50" DLP Samsung HDTV
That sounds like one of 2 things:
  1. Color wheel
  2. Light engine
Color wheel because of the losing color, but the light engine because of the picture freeze. It's very difficult to judge since I can't be there to see it. I'm leaning toward the light engine though. The only fix is to replace the DMD board, or entire light engine.
Posted on Feb 04, 2010
Samsung rear projector tv Model SP42Q2HL HDTV ready 1080i Looks like i should b wearing 3D glasses when watching tv, Is it game over?
No,is it not.It a repairable tv.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 12, 2010 | Samsung HCP4252W 42" Rear Projection...
I have a samsung dv3 television. it has started
try this with tv in standby press INFO / MENU / MUTE / STANDBY on remote the tv will come on with manufactures menu you will see RESET use ONLY DOWN NAVIGATION until reset is highlighted and PRESS RIGHT NAVIGATION this will reset all tv settings PRESS STANDBY TO EXIT and then re tune all stations
hope this helped
Nov 10, 2009 | Samsung SPN4235 42 in. Plasma HDTV
HP-R5072 50 in. HDTV Plasma Television Samsung Plasma TV is snowy/dotted. When I turn it
Most likely it sounds like a Logic Board problem. The Logic Board is what controls images on the screen. It's a somewhat expensive part to replace. Maybe in the $200 range. Being that the part isn't cheap, best to have a TV tech come to your house to take a look at the TV to confirm the diagnoses before buying the replacement part.
Oct 24, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
No tv picture
my less than 2 yrs. old hardly used Samsung plasma is turning off automatically for no reason within 10m minutes of watching. What could be the problem??????????
Mar 16, 2009 | Samsung HPN5039 50 in. Plasma HDTV
Color bad
You might want to check the component cables to make shure they are firmly seated.
Mar 04, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Projectile motion
Dear Sir,
I have NEC 42vR5 HW Plasma monitor, this plasma goes off with in 1 Minute, pls. give solution
thanks
pramod
Feb 24, 2008 | NEC - 42" Commercial Plasma Screen ****(no...
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television Logo
1,376 people viewed this question
Jerry Greenberg
Jerry Greenberg
