Question about Dryers
Hi My dryer had a loud squealing noise which turned out to be the fan which I have now repaired, but in doing so I removed the belt and steel cylinder and now I cant get the belt back into the correct position, its still too loose. Do you have a picture that shows exactly where and how the belt is supposed to be positioned so that I can put it back on correctly? Thanks heaps. Connie
    Problem Solver:
  • 8 Answers
Probably a cat went inside.
Posted on Jul 29, 2010
How do I stop dryer from squealing
the squealing noise is most likely a loose drive belt , the drum is powered by a large belt to a motor , the belt and idler pulley are most likeslyin need of replacement
Dec 11, 2014 | Dryers
Dryer heats however will not turn, prior to it stopping it was making a loud squealing noise for weeks
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Feb 12, 2011 | Maytag MDE308DAYW Electric Dryer
Dryer makes a loud squealing noise when I try to dry a load of clothes, towels, anything
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 11, 2011 | General Electric G.E. DBXR300EGWS 6.0 Cu....
Dryer making a loud squeaking noise
Hi, You probably will need the following parts to fix the squeal;
6-3705180 Idler arm $6.78
6-3700340 bearing $16.04
[2] 6-3129480 Drum roller shaft $5.53
[2] 12001541 rollers $22.04
33002535 belt $23.80
MAKE SURE DRYER IS UNPLUGGED BEFORE WORKING ON IT
Remove two screws at front bottom, pull front out toward you and remove wires from door switch and remove. Remove front bulkhead and drum. Check all of these parts I listed and replace as needed. Hope this helps
Jan 28, 2011 | Maytag Neptune MDE5500AY Electric Dryer
LG dryer was making a squealing noise, then suddenly started making a loud noise like gravel was being rolled around in the drum. Could this be a broken belt?
heatman101
dfhjdg
Aug 03, 2010 | LG DLE5955 Dryer
My Maytaag dryer has a loud intermittent squeal. It will often work for 10-15 minutes with a quiet squieak or no noise, then the loud squeak starts up. I can turn the dryer off, but the squeal immidately...
I think the drum drive belt is slipping because it occurs more with a large load. Other possibilities are: A drum support wheel bearing could need lubrication or be replaced. Also some drum support wheels have a rubber coating that wears off causing misalignment and noise. Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced. See the following for info about dryer repair including belt replacement:http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Sep 21, 2009 | Dryers
Loud squealing noise from Drum belt looks fine other solutions
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 06, 2009 | GE Dryers
Kenmore gas dryer 97273100 was drying, but making a loud noise
You need a belt. Here's a link to a site with a good set of instructions if you want to try repairing it yourself. (You should DIY. You can save a bunch on the service call and the belt is only about $20.)
http://repair2000.com/wpoolbelt.htm
Dec 08, 2008 | Kenmore 72982 Gas Dryer
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
