Question about Epson Stylus C42UX InkJet Printer
Both my red and green buttons are flashing and when trying to print something i get a message saying that i need a new part ???
    President:
  • 2,678 Answers
The ink counters are full and need resetting. You can get the reset app here
http://tricks-collections.com/adjustment-program-epson-download/
Posted on Jul 29, 2010
Various issues
do a reset by holding the brother go button and it should flash all the buttons which is a quick reset...
now the issue about the noise might be the drum unit thats why theres an light error message
Sep 24, 2013 | HP DeskJet Office Equipment & Supplies
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Red exclamation mark keeps flashing. No message on screen, just a bar going round and round the periphery of the screen. Printer will not work. The round green power button remains on, without flashing....
i've looked it up and seems that it's a common problem and you need to flicker the CD door up and down a bit till your printer recognizes it's fully shut!!!
stupid HP can't get their stuff to work properly
hope i did a better job
:D
Oct 23, 2009 | HP Photosmart D5160 InkJet Printer
Printer status screen is red and will not print Canon i560 Inkjet
You need to count the number of flashes, usually long green then a certain number of flashes, sometimes alternating red and green flashes. I need to know the number of flashes to tell you what the error is.
Jun 18, 2009 | Canon BubbleJet i560 InkJet Printer
Epson c48 printer
Reset your counter back to zero. But for some you must also check the waste bin status. Need disassembling this is to ensure ink will not overflow from your printer.
Reseting is only software base. Try this link
http://www.fixya.com/support/t1837800-step_step_use_resetter_software
Post again if you cannot still got it.
May 31, 2009 | Apple Epson Stylus Color 777i InkJet...
Kyocera Ecosys FS 920
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Not receiving faxes
there is an in/out button beside the number 3 , it needs to be bright green to be working. just press it a couple times
Sep 22, 2008 | Panasonic PanaFax UF-490 All-In-One Laser...
SERVICE ERROR 6000
Use this:
1. Turn off printer
2. Hold down Resume button and press Power button
3. Keep holding down Power button and let Resume button go
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more
8. Your printer should respond as normal.
May 07, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
Mar 30, 2007 | Maytag MSD2454G Side by Side Refrigerator
Epson Stylus C42UX InkJet Printer Logo
65 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
