Question about Sony VPL CS2 Multimedia Projector
Power up when i power my sony vpl-cs2 up the lamp/cover and fan/temp lights just flash
  • Anonymous May 23, 2008
    no light from lamp and LED nothing happens
    power is ok
  • amccomas Jun 18, 2008
    When I turn on the power, lamp/fan lights come on and it powers off. I switched out the bulb and it continues to have the same problem
  • 563 Answers
Hi mick1907
Take out your lamp and check for any irregularity like marks or discolouration.
If there is no visible damage - put back the lamp and take of the top cover - start the Projector and check if all your fans are running - that is if the machine starts at all.
If the unit doesn't start up at all you will have to replace the Mainboard.
Posted on Apr 24, 2008
I have sony vpl ex7 and the power button keeps on blinking?
If it blinks with 2 flashes, it's overheated. Check the filter unit.
If it blinks with 4 flashes, a fan is not working properly. see if any fan is not turning on, and check why.
If it blinks with 6 flashes, it's a system internal failure.
Jun 28, 2011 | Sony VPL EX7 LCD projector 2000 ANSI...
I have changed the lamp in a Sony VPL EX-1. I have fitted a YODN (LMP - C150) I cannot get the flashing light to go out which indicates `lamp,cover` and I cannot do anything with the projector.
When you open the lamp cover for replacement of lamp there is a switch in the projector is OFF
If lamp cover not fix proper after replacement of lamp the lamp/cover indicator flashing
SOLUTION: Open the lamp cover and fix proper and tight the screw
Feb 22, 2011 | Sony VPL-EX1 Multimedia Projector
Press the power button to switch it on, the sony logo lights up and it switches on as per normal operation, it then switches off after a few seconds and the temp/fan light flashes
hi,
may be your projectors lamp colling fan have some problem. may be it is get jammed due to dust or it may be faulty. without fan the lamp will get over heated. that's why the temp/ fan lights flashes.
jus check it . need further help feel free to contact.
ok
Dec 20, 2010 | Sony Projector Lamp for VPL-HS51
Lamp light on Sony VPL CX4 satys on
Check all In/Out fan and also check is it clean or not
Mar 13, 2010 | Sony VPL CX4 Multimedia Projector
When the projector is turned on, the green light
Sir it seems air in out problem.Clean all air filter or open lamp cover and give air pressure using with air blower or vacuum cleaner
Feb 25, 2010 | Sony Cineza VPL HS2 Multimedia Projector
Sony VPL-CS1 projector
Hi there
You should first check if there is any visible damage on your lamp. If not then it could be a faulty Ballast ( lamp powersupply )
Mar 14, 2008 | Sony VPL CS1 Multimedia Projector
FAN/TEMP light is flashing
maybe there is a problem with the lamp (bulb)
Jan 25, 2008 | Sony VPL CX1 Multimedia Projector
Sony CS5 Wont turn on
the cover switch is probably not fully made.
Ensure that the cover tangs are pushing the pin
on the miniswitches.
Try putting slight pressure on the fan or lamp cover to see if the lamp/cover light
stops flashing.
you will need to do a restart on the PJ to check this out
Jan 15, 2008 | Sony VPL CS5 Multimedia Projector
Sony VPL CS2 Multimedia Projector Logo
453 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
