Memory stick Hi There Can you tell me if its possible for a usb stick to totally crash a laptop and a recordable dvd player, I had a new dvd player and was copying muisc to it when it just stopped woejing and wasnt able to do anything with it, now my son has just borrowed it and his laptop has crashed has just his recovery cd and still wont work so have put 2&2 together and guess the usb stick must be corrupted in someway so think it best to throw that one awy I always scan anything that I put onto the usb first for safe measure any ideas pleasr. Many thanks Amanda
Hi Benimur
Thanks for the advice will see what can be done with it have written down the info shall get another one to use for now.
Many thanks
Amanda
Posted on Apr 24, 2008
    Brigadier General:
  • 6,966 Answers
Hi Amanda,
All USB memory sticks/flashdrives uses the internal power supply of the device it is attached to (such as your DVD Rec/Player and your son's laptop). Having said that, once it is plug it is then made into an integral part of the device, if something is electrically wrong with it, the flashdrive will bring the whole device down. Technically, I suspect that the flashdrive has an internal short grounding the supply line. This is the "+5VDC rail" as we call it.
If you are seeking the services of an on-site repair person, it might help that this information be relayed to him/her as it will narrow down the diagnosis to the power supply section, fusible links/resistors, regulators and others of the sort.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
I am trying to make a dvd from a HDD video cam to a sony DVDirect recorder VRD-MC3 and a message saying non supported USB devbice keeps comiong up. Can you hellp?
The manual of the DVD doesn't say much for models, say's sony HDD, sony DVD, so maybe it's not compatible. Do you have a memory stick for the handycam ? If you stored the video on the internal storage, check the manual to see if you can move it to the memory stick, then put the stick into the DVD player. Or you will need a PC to transfer it with USB, then get a memory stick and put all the video on in and not internal storage, if the DVD is not compatible with the handycam.
Mar 30, 2013 | Sony DVDirect VRD-MC3 DVD Recorder
Purchased a Technika Model 19-220. 8 months ago never used the DVD recorder because we never had freeserve. Now we are connected to Freeserve the DVD will play DVD's but no accept blanks for recording...
Thanks for posting to Fixya and it is my pleasure to guide you.
"Will not accept blanks for recording it says No Disc."
from Technika manual: Start Quote
VCR/DVD Recorder; I have connected the TV to my VCR or DVD Recorder via SCART but it is not recording. In addition to connecting via SCART, you should connect the aerial cable from the wall socket to your VCR/DVD Recorder and another aerial cable from the VCR/DVD Recorder to the TV." Also; "Check the DVD is a region 2 disc - to change the region of the DVD player, refer to section 'Changing Regions'.
Note: USB record function is only avilable in Digital/Freeview TV/Radio mode. Due to copyright laws and illegal copying/recording it is not possible to record to/from any other input/output source.
DVD MENU: To access this menu, press [MENU] button on the remote control. TV System - Choose from the following options. NTSC; Normally used for discs from North America, Japan etc.
Auto; For both NTSC and PAL. This TV/DVD player is pre-set to play Region 2 DVDs.
Tip: This television contains one TV tuner, therefore it can only record the channel you are watching or record one channel while the television is in standby mode.
Tip: This TV/DVD player is pre-set to play Region 2 DVDs.
End Quote
You can not record to a DVD, according to their manual. That is why you get the no disc error. It does not have the play sector at the beginning of the DVD. You can record to USB Flash Drive however.
Quote:
USB RECORD - DIGITAL/FREEVIEW MODE
Built into this television is a USB record facility. This function is available in Digital/Freeview mode when used in conjunction with a compatible USB memory stick or USB Hard drive. The benefi ts of this are as follows:
• Pause live TV/Radio and then playback, fast forward and rewind (up to live TV)
• One button record, if you decide you want to record the current programme
• Easy programmable recording from the 7 day TV Guide
• Record TV/Radio and watch/listen back on your computer/laptop
Due to the nature of the product, it is necessary to use a high speed USB memory stick (as the TV reads from and writes to the memory stick at the same time, some memory sticks may not be suitable). You can purchase high speed memory sticks from some computer stores, alternatively, we have a selection of tested and compatible memory sticks available to purchase directly from the helpline/web site. These are available in 4GB, 8GB and 16GB. (Please check the web site/helpline for latest specifications and prices). End Quote
Good luck and please post back that you this has solved your problem and click thumbs up of your success or that I can be more helpful.
Jun 06, 2011 | Televison & Video
Hi, I have a Samsung DVD Player H1080 R. Nice player with sleek design. When I try to connect my Seagate Go Flex USB 2.0 Plug & Play (1 TB), it doesnt play. There is data in the external hard disk,...
Good day!
These are the 2 possible causes and solution on that problem:
  • The format of the file on U.S.B device is not compatible to the format requirements of the DVD player.For example your DVD player required A.V.I or MPG/M-PEG for the video while the file format of your U.S.B is F.L.V and when you try to insert it to the U.S.B port the file doesn't read.You have to do is convert the file that store on your U.S.B device depends on the format requirement of your DVD.Use a total video converter to convert the file on your U.S.B to the format you need to play on the DVD player.
  • Or the problem could be the U.S.B itself,because the U.S.B host on this product does not supported all U.S.B device.Please try to use other mass media device such as memory card or mp3 players.
I hope this solution will be helpful.Thank you.
May 02, 2011 | Samsung DVD-H1080R DVD Player
How do I get Handycam DCR-DVD305 to recod videos onto a memory stick duo pro?
It is not possible to record the videos onto a Memory Stick Duo or Pro Duo, as this Camcorder DCRDVD305 does not support video recording onto the Memory Stick.
To record the videos you may use 8cm DVD-R/DVD-RW/DVD+RW.
Aug 23, 2010 | Sony Handycam DCR-DVD305 DVD Camcorder
Recording on the Meos 20'' LCD-DVD Combo 2009 model
YOU CANT RECORD FROM A SCART TO USB, THE SCART IS IN ONLY AND ANALOGUE. YOU SHOULD HAVE A USB PORT ON THE TV TO PLUG IN YOUR STICK OR PORTABLE HARD DRIVE
Aug 31, 2009 | Televison & Video
Viewing avi file
This is a memory issue with the laptop- not enough RAM memory- unless you want to spend a fortune on upgrading your Lappie nothing you can do. Except maybe burn to CD and try on a domestic DVD player
Feb 09, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
