Question about Samsung Washing Machines
SAMSUNG SILVER NANO 5E FLASHING ON DISPLAY - Samsung Washing Machines
2 Suggested Answers
  • 330 Answers
SOURCE: I have Sumsung Washing Machine,
the drain pump is probably fine on the other end of the filter is a drain pump lean the machine back and take the kick plate off and you will see the drain pump you need to undo three screws holding it to the filter and when you pull it apart your problem will fall out ( normally coins or bobby pins or nails if not take the hoses off as well and check/clear them save you the money and the drama.
Posted on Jan 10, 2011
How to fix E5 code for Samsung Microwave
About 64,200 results (0.62 seconds) Search Results
    Fixing a broken Samsung Microwave - The dreaded 5E ...
    ? 4:30
    https://www.youtube.com/watch?v=_yWSU0kTkTg
    Mar 20, 2013 - Uploaded by Joe Devlin
    When my Samsung Microwave was just over a year old it failed giving me an "5E" or "SE" Error code which ...
    Samsung Microwave SE (5E) Error Fix - YouTube
    ? 9:23
    https://www.youtube.com/watch?v=YubSrHE7WFc
    Dec 7, 2012 - Uploaded by eric hatch
    I had pretty much decided to throw it away since the cost to fix it by a ... Fixing a broken Samsung Microwave ...
    Samsung Microwave SE Error FIX! - YouTube
    ? 1:33
    https://www.youtube.com/watch?v=oPQE2oLTR3o
    Jan 26, 2014 - Uploaded by jjthetechguy
    I am not responsible for any damage done to your microwave*** ***Do at ... Fixing a broken Samsung ...
Jan 27, 2016 | Samsung SMH8165B Microwave Oven
Dishwasher goes to se display during cycle
That's actually a 5E error code. The 5E error code on most Samsung dishwashers means a drain error. Most often this is caused by a clogged drain hose, or some foreign object getting caught in the drain pump impeller. But it can also mean you have a bad ECS sensor if the drain pump and hose are okay.
Dec 26, 2014 | Samsung Dishwashers
Flashing 5E
You have a "water drain" error. It may be clogged with ice or debris. http://appliancehelponline.com/samsung.html
The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Oct 03, 2014 | Samsung Refrigerators
Samsung dishwasher is flashing a code "5E"
5E which indicates a kinked or bent drain hose, Hope this helps you! or the water pump itself. just clean out drain hose good.
Jul 09, 2014 | Samsung Dishwashers
My SMH9151W Samsung Microwave displays a -SE- or a -5E- and will not operate. I unplugged over night and still will not operate
I had the same issue on a 2010 smh9151w samsung microwave after installing it and using it with no problem for 5 days. The second time we unplugged the microwave and turned the circuit breaker off and on we didn't reset the clock on the microwave so the display shows :0 and it has been working for 7 days straight now. Fingers crossed that this is a long term solution. Hope this helps. Thanks!
Mar 20, 2012 | Samsung Microwave Ovens
I have a samsung washing machine wf7600naw washing machine that won't spin and is displaying the error code SE. How can I fix the problem?
WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Dec 11, 2010 | Samsung Washing Machines
Samsung silver nano freezer fan blades broken due to ice build up. need new blades. Please tell me where can I get Them. And how to stop it happening again.
Samsung silver nano 5yrs old - trips main electrics - 13A fuse ok but everything trips when the fridge/freezer is switched on
Aug 14, 2010 | Samsung Refrigerators
My samsung washer is broken it reaches the last 5 minutes and than i have 5E flashing at me and it stops
5E is a water drain error so either a blocked filter, blocked outlet or faulty pump...
Dec 17, 2009 | Samsung Washing Machines
Ipod nano, white and silver, flashing the apple sign
I had the same problem and I just let it alone, plugged into the computer (even though it had plenty of battery) for about 10-20 minutes and it came back! I hope this helps you :)
Aug 07, 2007 | Apple iPod nano
Washing Machines Logo
275 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
