Question about Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7420 Printer
I sent 4 jobs to the printer last night...The printer ran out of paper...The jobs remained in the queue until now...Can I avoid rebooting my machine to get the printer to accept jobs again??? I'm connected parallel be the way!!!
  • Discovery 3 Apr 25, 2008
    Sorry...I had tried that and nothing happened...I then tried to delete that job and it wouldn't do that either...I was able to delete the other 3 queued jobs alright...I shut off the printer and waited for 20 to 30 seconded and restarted it but that didn't help ...I eventually rebooted the PC...as I needed to move on but I would still like to know if there is a way around it...
    Genius:
  • 2,785 Answers
Just right click on document you want to print and select resume
Posted on Apr 24, 2008
Paper jams brother mfc 7420
Paper Jams are routinely caused by bad roller in the printer. The Heat of laser printers can render these rubber roller pretty useless in a couple of years or less if you print often. If you have recently replaced the drum (according to the recommended print output number), Then If an $80 dollar roller + labor is worth it to you, go for it, otherwise buy a new printer and Brother gives the best ink value per page. hope this helps.
Jan 28, 2013 | Brother MFC 7420 All-In-One Laser Printer
My Brother MFC-7420 still shows "Toner Low" as always and I cannot use the scan tool. Please help me as quickly as you can. Thanks
1) Pull out the cartridge and look on the right side of the it. You will see a small hole that has a glass like window in side (round window).
2) Turn off MFC-7420
3) Cover the hole on cartridge with a duct or a piece of paper. Basically block.
4) Replace the cartride back in the printer and turn on the printer.
5) The message should be gone and you should be able to use the copier functionality.
It worked perfectly.
What an unethical practice Brother is following? They want us to spend more money buying their cartridge unnecessarily.....
Apr 19, 2011 | Brother MFC 7420 All-In-One Laser Printer
Mfc-7420 says paper jammed/ and no feeding paper -all faulse messages-no paper there jammed
This is a huge problem, not only with the MFC-7420 printer, but literally every printer known to exist! The best way to solve this problem is to look at where the printer is connected. If it's connected to your computer, it may be trying to print something from there still, causing the information that the printer is receiving to become jumbled up and confused. I'm going to go step by step to try to help you out of your printer misery:
First: Unplug the printer from your computer entirely. Then unplug your printer's power source.
Second: Re-plug back in your printer's power source, and wait for it to turn on fully.
Third: Double check to make sure everything is working fine aside from the non-existent "paper jam."
Fourth: Re-plug back in the printer to the computer, and cancel all scheduled prints that are queued on your computer.
Lastly: Retry printing!
Hope this helps.
-Anonymity
Feb 24, 2011 | Brother MFC 7420 All-In-One Laser Printer
How can i make double sided copies on a brother mfc 7420 printer???
The manual doesn't say it will do double sided copies. it will copy two pages to one sheet of paper or 4 pages to one sheet of paper. you will probably have to make a copy of the document and then reload the paper back into the tray. experiment with it like put it in face down or face up then which is the top of the page. you can use a marker on a blank sheet of paper to see how it prints out.
hope this helps
Jan 28, 2011 | Brother MFC 7420 All-In-One Laser Printer
I have a Brothers MFC 7420 and it will not print, says Manually feed paper
that means the job you sent was larger than the paper size in the tray, to clear this put blank pages one by one in the front slot of the machine until it prints t out the job
Dec 13, 2009 | Canon S520 InkJet Printer
Model - MFC-7420 - FUSER ERROR
Is the paper that comes out of the paper warm or cool?
If "cool", then the fuser is not operating.
The job of the "fuser" is to generate heat to melt the powdered-ink into the paper, to make a permanent bond.
So, take the printer to a qualified technician, for trouble-shooting.
Nov 18, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7420 Laser All-in One Printer won't print.
Dont bother your self, just reinstall the printer again and let me no when done
Kaggwa Mozeh
Jun 09, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother mfc-7420 printer - manual feed instead of automatic
ok, thank you
you probably had a document that was not using 8.5 x 11 paper or the print settings were the printer to use the manual tray.
thanks adi
Apr 02, 2009 | Brother MFC 7420 All-In-One Laser Printer
Message on brother MFC7420 "back door open" when it's not
Actually, you need to double check the back cover and front cover, open them all to check all paper jam.
Besure to check the back cover, normally all paper jam is from the back.
be sure to close the front cover at the last cover to close.
Apr 01, 2009 | Brother MFC 7420 All-In-One Laser Printer
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
55 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
