My hp laserjet P2055d printer keeps showing this error message , "49 Err 64003D5. Turn off then turn on". It does not print anything. It is new printer. What could be the solution to this?
  • 52 Answers
Turn printer off cacel first job in print que power on if problem continues could be formatter
Posted on Jul 29, 2010
Scanner error 52 turn off and turn on
Sir/Madam
Unfortunately there's no troubleshoot with a 52 error. As it implies it's usually the scanner bad. It sits up top- under the top cover. It connects to the Formatted Board on the left side. and there's 2 connector s at the scanner itself.
So if Your HP Printer is Under warranty ( 12 Months ) Then I Suggest You Go To Official authorized HP shop for your HP Printer Problem and Troubleshoot or Go To Official HP Printer Website To Update HP Printer Software and Driver,Or You Update It From Official Below URL Link:
http://h30499.www3.hp.com/t5/Printers-LaserJet/HP-Laserjet-P2055d-error-message-quot-52-Scanner-Error-Turn-off/m-p/5905671#M207987
or
Or
In Case You Having Still Problem Then Follow Us On:
HP Printer Support
Feb 13, 2014 | HP LaserJet 3055 All-In-One Printer
I have PH Laserjet P2055 printer 49 err 4810E9E
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. 3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or print job, contact the software vendor for assistance.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. 5. Turn the printer off. 6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in the lowest DIMM slot.) 7. Remove all EIO devices from the printer. 8. Turn the printer on. 9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device. 10. Replace a DIMM or EIO device if you determine that it causes the error. 11. Remember to reconnect all cables that connect the printer to the network or computer. 12. If the error persists, replace the firmware DIMM. 13. Replace the formatter.
May 30, 2012 | HP P2055DN LaserJet Monochrome Printer
I got and error message on my printer hp p2055dn 49 err 6400444 turn off then turn on
You probably are printing with a newer version of adobe and have not upgraded the firmware on the printer. Go here and download the firmware update utility, first option for upgrades on the page. Once downloaded run this utility and it will ensure that your firmware is up to date. If you cannot get the printer to come to ready, you will need to clear any print jobs that are in the queue waiting to print first.
Apr 07, 2011 | HP P2055DN LaserJet Monochrome Printer
Model - HP Laserjet P2055dn. Issue - 49 Err 64003D5, Turn off and then on . Tried many times, keeps showing the same error after turning on. Change the network cable but no use
Had the same error. Turned out the pdf I wanted to print had an empty page. When I removed it, the error disappeared and I could print the document.
Mar 13, 2011 | HP P2055DN LaserJet Monochrome Printer
I had the same problem. The source of this problem, the USB printer port is broken, then I use network configuretion. The poblem is solve.
Dec 20, 2009 | HP P2055DN LaserJet Monochrome Printer
49.ff95 service error
You need to get a technician in. The code is suggesting the formatter board.
Note that make sure that the technician (or you if you are replacing it) that once you replace the board and turn on the machine, don't do anything for about 10 minutes. No printing, nothing. Take out the network/usb cord out to prevent anyone from printing. The reason is that the NVRAM (memory) is updating the new board with your information. If anyone prints (whether from a computer or a configuration page) then it will interrupt the update and you will get the same error again.
Dec 08, 2009 | HP LaserJet 2420dn Printer
LaserJet 4350n Error 49.C02
49.XXXX PRINTER ERROR To continue turn the printer off then on Description The printing operation has been aborted. The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications. Action
  1. Press Cancel Job to clear the print job from the printer memory.
  2. Turn the printer off and then on to clear the error message.
  3. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
  4. If the above action does not solve the issue, contact HP or authorized service provider.
Dec 05, 2008 | HP LaserJet 4350 Printer
Error message 49,ff81
it is temporary printing error, turn off the machine and wait 10 sec and turn it on again it should clear.
Oct 15, 2008 | Office Equipment & Supplies
2,866 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
